Old 07-07-2009, 09:36 PM   #376
horizon644's Avatar
Default Tyre Arbor for F104
Anyone knows where i can purchase a tyre arbor for F104? I've been looking for one but to no avail...
Acorn Innovations
- From Little Acorns; Mighty Oak Trees Grow.
Acorn Racing
www.acornracing.com
Email: enquiries@acorninnovations.asia
horizon644 is offline   Reply With Quote
Old 07-08-2009, 12:13 AM   #377
Arahawak's Avatar
Trader Rating: 32 (100%+)
try this bro..
http://d-drivesportsenglish.com/inde...a8f5cdff4e1a4d
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-08-2009, 02:06 AM   #378
horizon644's Avatar
Bought and thanks!
Acorn Innovations
Acorn Racing
www.acornracing.com
Old 07-08-2009, 09:51 AM   #379
fatboy's Avatar
Send a message via MSN to fatboy
hi, will the kawada 64 pitch spur able to fit in the F104 ? I have the adaptor as well.
Anyway, anyone able to provide wht pinion to start with if i'm running the stock tamiya tyres and the 64 p Spur.
fatboy is offline   Reply With Quote
Old 07-08-2009, 03:50 PM   #380
Vyger's Avatar
Here is a cool article about downforce generated on RC F1 cars. I don't know exactly what it says but I understand the numbers they're posting. If anyone wants to translate and post what's written I'm sure everyone would appreciat it.
1/10 R/C F1's...Pics, Discussions, Whatever...
Tamiya Road Wizard, F101s, F102s, F103s, F103RSs, F103LM, F103RXs, F103RMs, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 07-08-2009, 06:45 PM   #381
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
can anyone confirm if an orion 3800 will fit with or without modification? pix will be most welcome, too.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-08-2009, 11:00 PM   #382
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
I'm not sure what pinion has been included in the kit box stock, but you can use that (number of teeth for pinion) against the 93T (if I remembered correctly). And with that gear ratio, do a math on your 64p Spur that you want to use to find the pinion. This is a method of subsitution, so anything fast will you have to buy bigger pinions from there.
Remember to file down the width of the 3Racing Adaptor to as wide as the width of the 1280 bearing.
Alfie
F103K F104PRO Universe Spektrum GTB GTX Trakpower Orion
Retired Fleet: DDM F103GT-R F103LM TRF F103LM RC10L3 Team Touring YR4M2 Type J PRO YR4M YR-F2 SP Boomerang Mountaineer JPS Clod Bullhead TLT-1 Avante 2001
Alfie is offline   Reply With Quote
Old 07-09-2009, 11:14 AM   #383
Trader Rating: 26 (100%+)
Default Rubber Tires
My understanding is that the only rubber tires available are the F103 tires and wheels. I would like to mount Rubber on the F104. If I install the front arms for an F103 on the F104, would the front have a wider footprint. Any opinions on how this would effect the handling? With the push I am reading about, this may help.
svines1972 is offline   Reply With Quote
Old 07-09-2009, 11:51 AM   #384
Vyger's Avatar
Yes, by using the F103 front end it would be much wider than the F104 rear. I could be wrong but, I'm pretty sure this would make the car really push in the corners.
Just an FYI, regarding the article from rc-japan.de on wind tunnel testing rc F1 cars; I've got part of it translated and posted at the link below.
Old 07-09-2009, 11:58 AM   #385
Vyger is correct--wider front track = more push. This alters ackerman angles.
The narrow your front end is and the wider your rear is, the less push you will get.
boro92 is offline   Reply With Quote
Old 07-09-2009, 12:59 PM   #386
Ok, then can someone tell me what the difference is with the F104 that the F103 wheels or tires will not work? Maybe I can look for a modification that will allow them to be mounted on the F104.
Old 07-09-2009, 01:37 PM   #387
Vyger's Avatar
Front = The F104 uses a larger kingpin than the F103, hence the larger diameter wheel. Since the F103 wheels are smaller they will rub when mounted on the F104.
Rear = The F104 uses a one piece wheel because you dont need to mount the thrust assembly in the wheel anymore. It also uses a shorter wheel hub for the same reason. As far as mounting the F103 wheel on the F104 Im not sure you cant. The offset maybe different but Im not exactly sure.
I hope this helps.
Old 07-09-2009, 02:19 PM   #388
robk's Avatar
Trader Rating: 22 (100%+)
I'm pretty sure if you put the 103 rears on the 104, the car would be much wider in back.
If you put the old suspension up front, with 103 tires on all corners, it's a Tech car
Old 07-09-2009, 03:40 PM   #389
cheROK1212's Avatar
Default Funny as usual Rob
cheROK1212 is offline   Reply With Quote
Old 07-09-2009, 07:11 PM   #390
magerp's Avatar
Do you follow the instructions regarding the orientation of the cone washers in the thrust bearing? Has anyone (if necessary) reversed them?
magerp is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
