Like Tree1Likes
Old 11-27-2010, 09:18 AM   #3856
robk's Avatar
Trader Rating: 22 (100%+)
I have the Exotek with the 103 front end, the 104, the 103 in a couple configurations, the 3Racing 109, and HPi Super F1. I wanted to go to Cleveland (didn't make it due to $$), but I tested all those cars back to back on carpet over several weekends.
With the exception of the HPI, I used the same tires. To make a long story short, the 103 was the fastest car until I got the Exotek with 103 parts together. To be honest, I never bothered with an Exotek/104 front end and tires because the stock 104 has never even been close to a 103. Like .5 sec a lap slower, foam tire to foam tire, even with no center screw on the 104 tbar.
The Exotek with 103 parts was on pace of the F103 which I have been dialing in for 2 years on the first battery pack. Granted, I used this knowledge for the initial setup of the Exotek, but I felt the Exotek was better overall. It was also easier to drive. The wheelbase may actually be a bit of help on carpet, as the car is very smooth but still steers. Until the car starts chattering or losing traction, harder side springs are going to make it turn harder. A CRC red spring made my car rotate very hard.
Old 11-27-2010, 11:59 AM   #3857
gsxr0311's Avatar
Trader Rating: 18 (100%+)
With the exception of the HPI, I used the same tires. To make a long story short, the 103 was the fastest car until I got the Exotek with 103 parts together. To be honest, I never bothered with and Exotek/104 front end and tires because the stock 104 has never even been close to a 103. Like .5 sec a lap slower, foam tire to foam tire, even with no center screw on the 104 tbar.
i used a speedmerchant red side spring and it also made my car turn very hard. the car can totally take it on the carpet track. its way better, and im only using the f104 front end and 104 style tires.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 11-27-2010, 12:11 PM   #3858
gsxr0311's Avatar
Originally Posted by aussierevo View Post
gsxr0311......would you be able to share any setup tips for asphalt track using the exotek.
exotek 104 chassis
2deg camber in front
silver front springs
0deg toe in front
stock center roll shock oil
kit recommended center shock, oil and spring setup
ride height front is 3.5
rear is 4.0
tires are made by square med 35 shore for front & tamiya options rear
tires are cut to 54mm front and 56mm rear
speedmerchant red side springs
rollout is 71 for a med size carpet track
for asphalt the setup was the same except i was running the spice f1 tires that were hard front and soft rear. these tires were pretty good and i didnt cut them because they cost so much. my wallet wouldnt let me cut them. i was also running the kit sidespring. i didnt try changing them to see if any would work any better.
Old 11-27-2010, 03:06 PM   #3859
aussierevo's Avatar
Trader Rating: 14 (100%+)
thats for the input....other then the tires I'm pretty close to this setup so will keep plugging away.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-27-2010, 04:03 PM   #3860
gsxr0311's Avatar
no prob. how is the car working for you?
Old 11-27-2010, 04:53 PM   #3861
aussierevo's Avatar
i'm reasonably happy with the car. I haven't been able to get much run time with it, but when I have i just can't seem to get that planted feel that I had with the F104 pro.
Into high speed corners I tend to lose the rear on entry. I've yet to run it after playing with the rear droop, so wait to see what effect it will have, but it feels a very 'twitchy' car is that makes sense. I run on a low traction track which can get quite dusty due to the offroad track beside the onroad. Straight line is stable, so I'm wondering if a bit of weight to the rear would also help.
I'm persisting with tamiya rubbers purely out of loyality to the scale looks, b ut I have ordered some Shimizu rubber tires to give those a try.
I need to have a fair amount of track time to simply get my head around what works and what doesn't. I do like the exotek conversion and I'm hopefully that I see similar results to others using it.
Speed Passion F1.
Old 11-27-2010, 04:59 PM   #3862
gashuffer's Avatar
Trader Rating: 48 (100%+)
Yeah I guess I am going to try both front ends next weekend. I also have a 103 thats why I am sceptical about setting up the Exo to a 104W. I really want to keep it for outdoors and with rubbers and the narrow width the cars look amazing.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-27-2010, 07:54 PM   #3863
superspeed's Avatar
i'd like to see tamiya hosting an exhibition race where older f1 chassis competes in mini f1 endurance race
superspeed is offline   Reply With Quote
Old 11-27-2010, 09:35 PM   #3864
MikeR's Avatar
Getting the correct droop is make or break for pan type cars- so very critical that even 1 turn on the shock end or 1 turn of the spring collar will make the car planted off power... or not. Now you know how to get extra off power steering if you ever need it
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-28-2010, 12:25 AM   #3865
gsxr0311's Avatar
my 104 pro was twitchy, so i added -60 in expo on the radio. i also got the tamiya optional uprights. both calmed the car down a lot in the straights. sometimes having too much travel will cause the car to spin as well. my travel is at 70% and my steering rate is at 50%.
Old 11-28-2010, 09:09 AM   #3866
iknowjoe's Avatar
Trader Rating: 40 (100%+)
Send a message via AIM to iknowjoe
To strart, I apologize if this specific question has been asked, but my search did not show up the answer I'm looking for.
F1 at my local track is blowing up.
I have a F104 with Exotech upgrade, but I'm still at a clear disadvantage compared to the 103s and 109s wider stance.
We don't want to separate the classes by chassis, so we run together.
I'm looking to change my front end to the 103 and the rear to the wider 103 tires.
I have a healthy stock of tires and parts for the 104 and need to know what I can still utilize for the conversion and what I have no choice to buy.
I know I need the rear tires, no choice there.
I know I need the suspension arms and longer turnbuckles.
I know the steering knuckles are compatible.
I know the springs and c-clamps are compatible.
This is the real question.
I want to try and utilize the front 104 tires I have.
Has anyone used all the same components from the 104 (kingpins and tires) on the 103 front end and made it work properly?
I know if I want to use the 103 tires, I need different kingpins because the wheels are smaller, but I want to use the 104 tires I currently have.
It would save me some loot on this conversion.
If I need the 103 kingpins , what is the Tamiya part# I'm looking for?
Anybody got the scoop?
Thanks in advance.
http://StrongmileMovers.com
iknowjoe is offline   Reply With Quote
Old 11-28-2010, 09:35 AM   #3867
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Joe,if you want to use your 104 fronts you can use the stock pins.
there will be some extra pin sticking out of the top of the 103 arms but the 104 rims should clear the pins.. Just set the grub screws on the knuckles to proper ride height and use any needed shims under the knuckle to control knuckle droop.
Or you can run the spring on top of the knuckle (under the top of the arm) like the current 103 upright set uses.
http://www3.towerhobbies.com/cgi-bin...?&I=LXGJ85&P=Z
I would suggest buzzing down the front tires to get them closer to 103 size.
Btw.. Mark has been running 103 front width and 104 rear width (rear tires) to much success. The key is getting the foam small enough to control the traction roll issue.
j.d.roost is offline   Reply With Quote
Old 11-28-2010, 09:39 AM   #3868
iknowjoe's Avatar
Charge your phone beotch and call me!
Old 11-28-2010, 09:41 AM   #3869
2-Bad's Avatar
Trader Rating: 24 (100%+)
Hi, is the latest kit the Pro Black Edition?
What is the difference between these t-bars? Which provides the most rear traction?
54165 F104 Soft T-Bar
54222 F104 High Traction T-Bar
Also, Is there a single part number to convert over to the F103 front end?
Thanks.....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 11-28-2010, 02:57 PM   #3870
robk's Avatar
54222 F104 High Traction T-Bar<<<<<<<
Also, Is there a single part number to convert over to the F103 front end?NO
Thanks.....
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
