Old 11-25-2010, 02:07 AM   #3841
Originally Posted by Mitch-e4fs View Post
You should try shipping from the US. i bought a dizzy for a car for $10, it cost $50 to get it to Australia. Wolf hobbies minimum shipping rate is $30, even if it's just a set of arms.
That has to do with the type of shipping used and what they are willing to use. I've shipped to Australia for less with the F1 parts I sold in the past.
Old 11-25-2010, 02:21 AM   #3842
Mitch-e4fs's Avatar
Yes I have had some stuff shipped for less, however that may be only 1 in 50. Seriously shipping from the us is a joke. Ems is maybe a day quicker than the super cheap alternative.
Mitch-e4fs is offline   Reply With Quote
Old 11-25-2010, 05:05 AM   #3843
gashuffer's Avatar
Trader Rating: 48 (100%+)
Overseas shipping is a PITA regarless. Some shops if not most even charge bank fee's on top of it. Oh well, the price we pay for fun.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-25-2010, 05:15 AM   #3844
gashuffer's Avatar
Originally Posted by gsxr0311 View Post
yes, shipping will be insane. i like foam and currently run it on an indoor carpet track, but i do like rubber because they are cheaper and last longer. i bought some spice f1 foams, which are good, but cost a small fortune. my nitro foams are cheaper and better, why do they cost so much?
They probably have a higher rubber content or it could just be the name brand. Luckily for me I am happy with my stock kit foams. They hook up great. I just go through fronts like crazy. I cut them, glue them and toss them usually after a race day.
T-Sal
Old 11-25-2010, 08:38 PM   #3845
Another question, How much room is there under the F60 body for electronics? I have a normal size RX and an older bit larger ESC (novak 410-MXC, its older than me yet likely better than most at my LHS). If the dimensions are too tight ill need a new esc for this.
kb525 is offline   Reply With Quote
Old 11-26-2010, 05:42 AM   #3846
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
if you don't use the pontoons and just leave the sides uncut, there is plenty of room for electronics under the shell from what I've heard... I wouldn't know because I use the realistic add-on pontoons and small electronics... but I would assume that it why they give you the option of cutting the body or not....
akura2 is offline   Reply With Quote
Old 11-26-2010, 06:34 PM   #3847
gashuffer's Avatar
Does anyone run a 103 front end on the Exotek chassis? If so what are your thoughts on it? I already have a 103 but I would like to hear some feedback before I start wrenching. Thanks
T-Sal
Old 11-26-2010, 07:02 PM   #3848
gsxr0311's Avatar
Trader Rating: 18 (100%+)
i dont run the exotek with the 103 front, but i got smoked by a exotek with a 103 front. it was dialed. he smoked everybody, 103's, 104's, 109's & exotek 104's. i run the exotek 104. this was on the asphalt track.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 11-26-2010, 07:05 PM   #3849
gsxr0311's Avatar
if anybody cares,
my exotek is now dialed for the carpet. all i had to do is change my rollout and change the side springs to stiffer ones. keeping up with the 103's. its now neck and neck.
Old 11-26-2010, 07:22 PM   #3850
aussierevo's Avatar
gsxr0311......would you be able to share any setup tips for asphalt track using the exotek.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-26-2010, 09:03 PM   #3851
robk's Avatar
Trader Rating: 22 (100%+)
The real question is why you have not done this already. 103 front end + 103 tires = pwnage
Old 11-26-2010, 09:53 PM   #3852
tunerjetta29's Avatar
Funny, in so cal the 104/exotek seems to be the car to have.
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 11-26-2010, 11:33 PM   #3853
F N CUDA's Avatar
Trader Rating: 30 (100%+)
May be more that Jonathon is the guy to beat and he is drivin the Exotek/104.
What if your brother was driving a 103?
Do you guys think he would smoke us even worse than he is now cuz he was killin us even before he changed to the Exotek chassis?
Exotek has surely helped him go even faster with the 104 tho, without a doubt the 104 is a much, much better set up than the standard chassis!
I want one!
So, question is:
Is the F103 finally rivaled by the Exotek/104?
I'm still thinkin that same driver with each car, the 103's wide and short footprint is gonna still rule.
Even if the 104 is sportin the 103 front end and sneakers to equal the width, not feelin the extra length will be an advantage but will the lengthwise battery be the equalizer?
Just thinkin out loud and wondering.
I realize that the F104 is where we, out here in So Cal want to be, due to the fact that it is the modern F1 config. but it still seems as tho the 103 is the "cheater" chassis pound for pound.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-27-2010, 12:42 AM   #3854
Well a big part of it is what tires are going to work best. On our surface for some reason the rubber tires for the F103 just do not work well and foam gets no grip at all...yet the F104 tires get pretty good grip. Now if the tires were equal then yes the F103 would be the better setup as it is in most cases.
Old 11-27-2010, 07:30 AM   #3855
gashuffer's Avatar
Is this on carpet of assfault?
T-Sal
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
