Like Tree4Likes
Old 11-13-2010, 05:18 AM   #3721
energyracing's Avatar
I Have a question for you all, if you had the choice between a 15th anniversary F103 or and F104 pro which one would you pick and why?
They will be used in TCS.
George B.
[email protected]
Sponsored by Serpent / SRX2 MM, RM, SC / Serpent SRX4
MoFo paints
energyracing is offline   Reply With Quote
Old 11-13-2010, 05:25 AM   #3722
rc_square24's Avatar
I would choose the 103, but they have changed the rules for TCS F1 this year to limit the chassis to F104 only. This is for BC at least, but i'm pretty sure everywhere else as well.
Correct if I'm wrong, which I hope
rc_square24 is offline   Reply With Quote
Old 11-13-2010, 05:41 AM   #3723
Canadian TCS allows for bothsee below:
However i'm interested in knowing why you picked the F103.
From what I have heard the F103 performs better on Carpet and the F104 is better on Asphalt, I never drove an F104 so I need your feedback.
Thanks.
"FORMULA ONE
Tamiya F103, F104 chassis only.
Tamiya Silver Can Motors. Item# 53689. No "4 hole" silver can or Black Can motors!
Tamiya Foam or rubber Tires.
Driver Helmut must be installed.
No extra aero aids, this includes adding or enlarging wings/winglets.
Air intakes can be cut out to bring airflow. (Example the air intake above driverís head.)
Spec Battery rules apply.
Modifying or lightening chassis and or suspension parts is not allowed. (i.e. geometry)
Tamiya Hop-ups only. "
George B.
[email protected]
MoFo paints
Old 11-13-2010, 05:44 AM   #3724
Wow just looked at US TCS and you are correct they only allow F104.
Damn.
George B.
[email protected]
MoFo paints
Old 11-13-2010, 06:02 AM   #3725
Damn.
I wonder why they did that, I have an F104 to race with but I also picked up a F103 15th anniversary recently. For $150
It was a while ago when I had my F103RS, it always felt more stable and planted on carpet than the F104. Never had it traction rolling too. Maybe due to the wider trackwidth?
Old 11-13-2010, 07:50 AM   #3726
Foxxrocket's Avatar
Who knows. But it would make sence from a business point of veiw. If people were still buying and racing the 103s, there would be a stockpile of 104s still sitting in their warehouses. The 104s look and handle nice, but they're slow. Banning the F103 would force people into buying the F104 for the TCS races.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 11-13-2010, 09:36 AM   #3727
robk's Avatar
Trader Rating: 22 (100%+)
The 103 is better everywhere. The 104 is narrower and longer, and the t bar doesn't have the articulation of the 103.
Old 11-13-2010, 10:28 AM   #3728
F N CUDA's Avatar
Trader Rating: 31 (100%+)
[QUOTE=robk;8204540][QUOTE=energyracing;8203935]Canadian TCS allows for bothsee below:
No contest, same driver with each car, 103 kills it.
So you will need both cars just because.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-13-2010, 12:57 PM   #3729
Thanks for the info, I guess I'll keep the F103 that I have and buy a F104 in case I make it to the TCS finals. ()
George B.
[email protected]
MoFo paints
Old 11-13-2010, 03:51 PM   #3730
dzstr's Avatar
Trader Rating: 20 (100%+)
Have you guys compared the 103 to the 104 running rubber tires on carpet?
dzstr is offline   Reply With Quote
Old 11-13-2010, 05:32 PM   #3731
F N CUDA's Avatar
yep, same story.
same driver on each car, 103 wins.
Craig Hammon
Old 11-13-2010, 06:28 PM   #3732
robk's Avatar
Cuda droppin' mad science
Old 11-13-2010, 09:06 PM   #3733
gashuffer's Avatar
Trader Rating: 48 (100%+)
104's are still great cars. Mine is on rails on carpet and I run with both 103's and 109's all on the same pace.
I just need to loose about 100g. She's a pig
gashuffer is offline   Reply With Quote
Old 11-13-2010, 11:13 PM   #3734
aussierevo's Avatar
Trader Rating: 14 (100%+)
a question of those running the exotek conversion with lipos.
i've been running mine for the past couple of weeks, and I can't seem to get it as 'planted' on the track as I had my F104 running nimhs. It is loose at the rear, that does tend to break traction on turn in into a high speed corner, so off course, I need to ease of power to get it to be smooth
the car currently weighs 1135 grams, i run the steel diff shaft, but it seems very twitchy at over half full speeds. I run the offset at the front, ride height is 6.5 mm front 5.5 mm rear. I run on a low grip dusty track with rubber tires.
what other changes can I gradually try to make the car handle better in the high speed corners, without adding more weight if at all possible.
Any suggestions would be appreciated.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-13-2010, 11:27 PM   #3735
FREAKAH's Avatar
Reduce you rear droop. The nimh packs were much heavier so the main chassis didn't rise as much off power so some weight still stayed on the rear pod. The Exotek chassis's pivot suspension also articulates much easier than the "T" plate so droop comes easier and more suddenly.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
