Old 11-12-2010, 12:29 AM   #3706
Mitch-e4fs's Avatar
I just purchased a F104 pro and while i wait for it to arrive it thought i'd ask what tyres work well on low grip carpet? im only interested in foams as i cant use traction compound and its hard enough to race vintage with the rubbers on this carpet.
Also any setup tips?
Mitch-e4fs is offline   Reply With Quote
Old 11-12-2010, 12:39 AM   #3707
aussierevo's Avatar
I believe he has used a smaller lipo to cleverly locate the esc at the rear. Might be wrong, but the lipo looks smaller.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 11-12-2010, 01:35 AM   #3708
Arahawak's Avatar
Trader Rating: 32 (100%+)
Seriously.. The f1 kits are mainly very tires dependent.
Generally a harder front and softer rear should set you in right direction. With foams, it is good to true the tires down to about 58-60 mm and run a 1-2mm split, depending on your roll out.
Soft / high traction t-bars helps.
Other than that minor tweaks to suit your driving will do.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 11-12-2010, 01:48 AM   #3709
Mitch-e4fs's Avatar
Ok thanks. Any particular brands? Are the stock Tamiya foams ok or should i change straight away?
Old 11-12-2010, 02:04 AM   #3710
rc_square24's Avatar
Just try out the stock ones unless F104 tire availability is low at your area or you're really on a hurry for something.
The kit tires from the pro hooked up well on the club carpet track I run.
rc_square24 is offline   Reply With Quote
Old 11-12-2010, 03:15 AM   #3711
Mitch-e4fs's Avatar
I have the pro version so thats good to know that i have a decent set to start with and there is no availability of F1 tyres where i live so if i want something different to try it'll be coming from HK.
Old 11-12-2010, 05:39 AM   #3712
abailey21's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Arahawak View Post
Question... Why is the esc place behind the battery?
Is it in the instructions?
Like Aussierevo said I am running a micro lipo and the guys at my track that have run it need to add a lot of weight to the rear. I decided to put the esc in the back for cleanliness but keep the lipo, and esc in the center line of the car
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 11-12-2010, 07:19 AM   #3713
are there any companies making premounted rubber tires for the F104?
Stone Adams is offline   Reply With Quote
Old 11-12-2010, 07:32 AM   #3714
Arahawak's Avatar
Interesting... i guess this way gives you more room to play the ballast then?
Old 11-12-2010, 07:56 AM   #3715
abailey21's Avatar
Yeah. I have a ton of extra room now and being my receiver is 5 grams on one side, and the transponder will be 7 on the other I go in almost perfectly balanced
K.C.C.O.
Old 11-12-2010, 08:47 AM   #3716
gsxr0311's Avatar
Trader Rating: 18 (100%+)
which micro lipo are you running?
what motor are you running?
how much run time do you get?
sounds like i may try that, thanks.
Special Thanks to: RC Target, Ko Propo USA, O'Donnell glow plugs, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, and TE03. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. CRC 235mm Pro-10, Top Rebel 12
gsxr0311 is offline   Reply With Quote
Old 11-12-2010, 08:49 AM   #3717
gsxr0311's Avatar
also, does anybody know where to get F1 decals from that are for the f104 other than d-drive and ebay? ebay and d-drive are always out of stock and only offer limited teams. thanks.
Old 11-12-2010, 08:54 AM   #3718
abailey21's Avatar
I'm running the team scream micro 1800mah and I get on or about 12 minutes of runtime out of it.
I'm using the Novak Ballistic 21.5 and the Keyence Tachyon ESC
Spectrum Mirco receiver and I'm going to run one of the new mylaps transponder once my money shifts down from paypal
K.C.C.O.
Old 11-12-2010, 04:02 PM   #3719
gashuffer's Avatar
Trader Rating: 48 (100%+)
I run the mylaps PT and it weighs nothing practically and is so tiny! Great purchase.
I still didn't try my micro pack yet. I should my car weighs 1042! and works really well. I'm afraid to have to chase another set up for the small pack.
gashuffer is offline   Reply With Quote
Old 11-12-2010, 04:19 PM   #3720
spring71's Avatar
Smile
Shimizu Front tires are in stock now.
Click Here to check out
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
