Old 11-05-2010, 06:42 AM   #3661
gashuffer's Avatar
Trader Rating: 48 (100%+)
You can tape it in between the battery and servo.
gashuffer is offline   Reply With Quote
Old 11-05-2010, 06:45 AM   #3662
gashuffer's Avatar
Originally Posted by cyclone x View Post
rubber tires extra soft t bar no spring on the shock car handles as if its foam on carpet
Which rubber tires?
Old 11-06-2010, 06:15 AM   #3663
TOM NAVY's Avatar
Default f103
HIguys just got my 104 pro have noticed a lot of cars in photos from japan with a 103 front arms is it worth doin this mod has any one done it or am i just mistaken and im looking at the older cars but they are all current 2010 photos just want to no pros and cons of this mod thanks
|RUTHLESS RACING | I.F.R.C!!
|CAPRICORN LAB CO2 | "NO MORE BULLSHIT!!!"
"GENIUS HAS ITS LIMITS STUPIDITY HAS NO LIMIT"E.E
"MONEY TELLS NO LIES" SPONSOR WANTED
TOM NAVY is offline   Reply With Quote
Old 11-06-2010, 06:25 AM   #3664
gashuffer's Avatar
I haven't tried the 103 front end yet. I don't see the need. You should of just bought a 104W as it comes with the 103 front.
Old 11-06-2010, 06:36 AM   #3665
TOM NAVY's Avatar
Default ;
but its not a 104 pro
Old 11-06-2010, 09:14 AM   #3666
smracer31's Avatar
Send a message via AIM to smracer31
The f103 front end gives the car more front track width, i suggest getting one as a tuning aid, and play with it, if you like it, i would recommend the 3racing f103 front, its a bit more durable and has the ability to adjust camber.
smracer31 is offline   Reply With Quote
Old 11-06-2010, 02:12 PM   #3667
Chris Furman's Avatar
Trader Rating: 112 (100%+)
Ok, so I have been out of racing for about a year.
Have they figured out Rubber tires on Carpet yet?
Chris Furman is offline   Reply With Quote
Old 11-06-2010, 06:07 PM   #3668
kmas's Avatar
Trader Rating: 56 (100%+)
need some help guys, going to sell my 104 pro, and need to know what its worth, i have a nib body, nib tires/wheels, foam mounted tires, most the aluminum upgrades still in package, the car is clean, is 300 about right? I have more into than that easily. any help appreciated
kmas is offline   Reply With Quote
Old 11-06-2010, 08:11 PM   #3669
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Yeh, Pit Shimizu soft rear and Pit Shimizu #3 front for the F104.
Fastest drivers and cars had these today at the Ultimate F1 Winter Series Race, round #1 at TQ Raceway in Chino, CA.
These Pit Shimizu rubber tires mount on the Tamiya FOAM'S rims!!!!!!
check this link for pics, results and info on getting these tires from Sean at TQ Racing, he's the U.S. connection for the Pit Shimizu and Ride tires as well as many other of your racing needs.
Usually very well stocked, got run out of some cuz of this series starting up today. More said to arrive soon.
http://www.tqrcracing.com/forum/view...e=1&f_keyword=
The Rides soft for the rear also work on the F104 I'm told but you still need the Shimizus #3 for the fronts.
Ride A compound front and rear for the F103 is the ticket although I ran TRG Superions (couldn't get a set of Rides today and didn't actually need em after all) on my F103 front and rear and it was very dialed for the whole 8 minutes of each of the 3 mains.
Had some very competitive lap times on those too.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 11-06-2010, 08:52 PM   #3670
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I know you dont want to hear this, but you won't get $300 for it. You will be lucky to get $200 for it. It's just what the market will bear. I could almost put together a brand new 104 for $300. It may be in great shape, but it is used, the hop ups only run about $45 and the rims and tires dont really add any value to the car. I just picked up a used 104 with all the hop ups, essentially 2 cars, for $160 plus shipping. The car wasn't perfect, it was a bit rough in fact, but it was $160, so again, not tryin to be a jerk, just givin you an honest assessment.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 11-06-2010, 09:53 PM   #3671
gashuffer's Avatar
Guys at my track are just as fast with non pro kits. Setup, tires and driving is all you need. Actually you will need TRF shock and the gear adapter so you have more of a wider range to choose from.
Old 11-06-2010, 10:51 PM   #3672
F N CUDA's Avatar
The pro chassis is very stiff carbon fiber, the non pro F60 kit is fiberglass and more flexible, probably an advantage on bumpy and loose surfaces.
That's why the hi traction t bar is so much help, thinner, cut out to add flex for more rear bite.
Some guys even cut the front half of the upper deck off just like the F103 top decks used to be.
Craig Hammon
Old 11-07-2010, 01:12 AM   #3673
Yep, I paid $150 aud a couple of weeks back , for a clean 104 pro , with upgrades and spares...
MICHAEL BROWN is offline   Reply With Quote
Old 11-07-2010, 04:59 AM   #3674
kmas's Avatar
ok, thanks guys. thats what i needed to know.
Old 11-07-2010, 06:48 AM   #3675
gashuffer's Avatar
I'm running on a rug. Myself and one other run a 104. The rest are 103, 109's and none have a carbon chassis/top deck. We are all dialed in. It just comes down to tires and driving. I run the soft t-plate.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
