Old 10-21-2010, 07:45 AM   #3511
Originally Posted by Tommi Makkinen View Post
for the TCS rules, they mandated the use of the same wings on the same body (i.e. Ferrari F60 body = Ferrari F60 front and rear wings.)
but in the Tamiya Asia Cup series, even though the same rule was implied, it was still a grey area. while some of us ran the generic F-104 bodyshell with matching wings, we noted a few racers using the Ferrari F60 body but with the F-104 rear wing.
during the 2010 Tamiya Asia Cup Finals, since the surface was indoor carpet, the ideal body setup used by the majority in the A-Final was the F-104 body and wing combo. a few used the Ferrari F60 body and wing. but one of the F60 runners used an F-104 rear wing.
Thanks for the info!
What downforce settings of the rear wing do you guys use, standard or max....on the 104 body?
Does this setting really make that much of a difference?
mr lee is offline   Reply With Quote
Old 10-21-2010, 12:33 PM   #3512
InZane's Avatar
I'm halfway through building the EXO104 - so far I'm very impressed with the quality. Hopefully I can make the first test this week end (carpet/rubber tires).
So many wires so little space ... ... but I will work it out!
InZane is offline   Reply With Quote
Old 10-21-2010, 12:42 PM   #3513
robk's Avatar
Trader Rating: 22 (100%+)
You're gonna like it!
Old 10-21-2010, 03:05 PM   #3514
gashuffer's Avatar
Trader Rating: 48 (100%+)
Being that the Exotek chassis is not TCS leagal which class does it fall under? or you just run them all together?
gashuffer is offline   Reply With Quote
Old 10-21-2010, 03:18 PM   #3515
tunerjetta29's Avatar
TCS legal isn't an issue for most F1 races unless you race at the Tamiya track. So Cal runs the F104, F10, F109, Exotek F10 and 104 etc all together.
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 10-21-2010, 03:59 PM   #3516
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Our basic rule, is that is has to be an F1 kit car, with F1 tires and wheels.
That keeps it pretty simple.
i.e. no Corally or CRC Pan type Cars.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-22-2010, 12:15 AM   #3517
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
go with the max setting on the 104 wing. but then again, either setting on this wing seems to have less effect...
but even on max setting, the 104 seems to still have less downforce than the Ferrari F60 rear wing.
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 10-22-2010, 01:43 AM   #3518
Ok cool, so either way when I get a new body I will have to get the F60......
Old 10-22-2010, 06:43 AM   #3519
bakaguyjean's Avatar
Tamiya Japan lets you mix and match F104 bodies and wings,so if you win the trip here bring a few wings with you.
My body projects blog http://rcbodyproject.wordpress.com/
bakaguyjean is offline   Reply With Quote
Old 10-22-2010, 06:48 AM   #3520
Thanks dude!
Going to give it a miss then as I do not have time for detail.....it will only get banged up anyway and I am sure the body will have a little more strength if left as is!
The side pieces add strength,but make the body heavier,so you have a trade off there. But not using the side piecesis that really F1
Old 10-22-2010, 07:37 AM   #3521
if you meant getting an F60 rear wing, maybe so...
when i compared the F-104 body and the F60 body during the Tamiya Asia Cup finals, this is what i found out. and this was confirmed by the notes of the TCS North America champ:
F-104 body and wing set had less rear downforce and more front downforce = slight oversteer.
Ferrari F60 body and wing set had less front downforce and more rear downforce = slight understeer.
i figured if i will run in the F-1 class on a non-Tamiya race, i will be inclined to use the F-104 body and front wing plus Ferrari F60 rear wing to maximize the downforce on either end. a potentially good setup for tight tracks.
Old 10-22-2010, 07:47 AM   #3522
As you said the ideal setup would be to combine the two but if the TC rules state otherwise then the best bet would be to use the F60 body set......understeer is better than oversteer
Well I do not have a 104 as yet....just gathering some info for now. Will use the 104 body to start with and get the F60 later once the original has some scratches on it
Old 10-22-2010, 09:53 AM   #3523
Mike: Any idea when D-Drive will have the 104 kits in stock? Or did the ones they buy from you go on their cars to race? Looking forward to buying the conversion kit as soon as you or they have them in stock!
Currently Running:
Ko Propo EX-1 V3
Old 10-22-2010, 10:33 AM   #3524
yes. as a start it would be best to have the F60 body and wing set as it does have a bit of understeer. then move to the F104 Pro body and wing set if you feel that you have the confidence to let the back step out a bit.
but since you already have the 104Pro body, just set it to max downforce and get a feel for that...
but having said that, i wonder how will the new Vodafone Mclaren MP4/24 body and wing set react?
Old 10-22-2010, 10:52 AM   #3525
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi- I wonder if they sold out already as they received them last week. Yesterday they were asking when the next batch would be in which is looking like Nov 1. I will probably do pre-orders again a few days before
the release.
Thanks!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
SEO by vBSEO 3.5.0
