Like Tree4Likes
Old 10-10-2010, 11:53 AM   #3421
abailey21's Avatar
Trader Rating: 36 (100%+)
Would you guys recommend the Ride Super Soft tires for indoor carpet (ozite) for those of you that have used them.
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-10-2010, 12:45 PM   #3422
MantisWorx's Avatar
Trader Rating: 28 (97%+)
MantisWorx is offline   Reply With Quote
Old 10-10-2010, 12:47 PM   #3423
MantisWorx's Avatar
Originally Posted by Blueman Austria View Post
Where is the issue? still to wide? The F014 pro kit body also does not fit?
the 103 has a very short wheelbase and the 104 is very long wheelbase.
Old 10-10-2010, 10:01 PM   #3424
gsxr0311's Avatar
Trader Rating: 19 (100%+)
Originally Posted by aussierevo View Post
it looks like quite a bit needs to be taken off the back of a 104 body.....i wonder how much then will be needed for the f60.
hopefully mine arrives this week as well, will post pics with both bodies.
its not too much. only about a little over 1/4 inch squared.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 10-10-2010, 10:04 PM   #3425
gsxr0311's Avatar
i gotta tell you, the exotek was great in practice. its like a totally different car. im not sure how it compares to other cars, but it felt good when i was driving it. seem to rotate better, and definitely had traction. i will race it next week, so ill have more then.
Old 10-11-2010, 12:11 AM   #3426
Default lipo for F104 chassis
Hi all,
what lipo battery do you run in your F104 chassis?
Mine lipo battery doesn't seems to fit in..
thanks in advance
hansenhon is offline   Reply With Quote
Old 10-11-2010, 12:54 AM   #3427
aussierevo's Avatar
Trader Rating: 14 (100%+)
that's not too bad then...thanks for that.
glad to hear inital testing went well, keep us posted.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 10-11-2010, 01:12 AM   #3428
Arahawak's Avatar
Trader Rating: 32 (100%+)
Nice to hear that it is working better than in standard form.
Waiting to hear more!
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 10-11-2010, 08:34 AM   #3429
Trader Rating: 45 (100%+)
Raced my F104 Pro on a parking lot track yesterday. Started out with DJ's Tamiya track setup (except for tire size 60mm instead of 57mm). During practice I was using JTG for traction compound and suntan lotion (I know I should have been using Paragon GE - but didn't have any) and the car was still way too loose. Thought maybe it was the B type foams not hooking up so went back to stock foams. JTG with stock foams was still to loose on and off power. Took the diff lube off the damper plate, put less tension on the damper plate and backed out the t-bar screw as much as possible and was still spinning out. Luckily, a guy I was pitting next to recommended to try some Red Dot and the car finally hooked up.
I used Red Dot on the rear tires only since the car seemed to be steering well without any traction compound up front. However, the car did wear the front tires alot more than the rear. Started out with 60mm tires front and rear. Ended the day with 58.5 rears and 55.5 fronts. Was very happy I could adjust the front end ride height as the tires wore. Need to get the front end working to get the tire wear a little more even. Maybe try red dot up front or put on the B type foam. Maybe just go back to the DJ base setup use with Red Dot or Paragon GE and start from there again. Ended up TQ'ing and finished 3rd in the main.
For radio settings (M11x), ended with -25 for steering expo, -20 for throttle expo, and brake epa at 90 percent to keep the rear end from swapping ends under braking. Endpoints for steering were set to 100 and D\R at 40. Rollout was 58 to 59mm on a 140 foot straight.
Had a great main with cars 1-2-3 finishing about 1 to 2 seconds. Two F103's and an F104 were on the podium.
Plan to continue my F104 development at an indoor track for this fall\winter and will share whatever I learn. If you don't know where to start I highly recommend starting out with the DJ setup and tuning from there.
Apex is offline   Reply With Quote
Old 10-11-2010, 10:58 AM   #3430
danthrc's Avatar
Originally Posted by hansenhon View Post
Hi all,
thanks in advance
Any Stick Pack will work. One of our guys found a hard shell battery that would work, but then you had to trim out the top deck to get the bullet connectors to work.
The stick packs fit just right though.
danthrc is offline   Reply With Quote
Old 10-12-2010, 01:23 AM   #3431
aussierevo's Avatar
i've been meaning to ask with the new chassis if we are now able to fit most lipo's...is that the case?
Speed Passion F1.
Old 10-12-2010, 05:26 AM   #3432
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
i dont know if anyone may have tried this, but i will ask anyway.
other than the vintage f1 bodies (Wolf, Lotus) of tamiya, has anyone tried to use the vintage bodies from ZEN, TRG, and D-Drive Sports on their F-104?
if so, which bodies fit? and did you have to make major modifications to it?
thanks in advance.
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 10-12-2010, 07:37 AM   #3433
gsxr0311's Avatar
yes, it will take any battery. im using a thunder power 5400, which is a square pack. the chassis has two screws on the top deck which are like set screws. you can adjust those screws to the height of your battery so it doesn't move up and down.
Old 10-12-2010, 11:43 AM   #3434
abailey21's Avatar
Anyone??
Or can someone recommend some decent carpet tires?
K.C.C.O.
Old 10-12-2010, 11:56 AM   #3435
smracer31's Avatar
Send a message via AIM to smracer31
Anyone??
i was testing the ride super softs on the rear and liked the traction they provided on carpet, they would hop a bit on fast corners but very controllable and manageable, still testing to find a good front tire to give the car optimal balance. One thing i noticed about the ride tires is they dont seem to pick up carpet debris, and therefore stay pretty consistent over long runs.
smracer31 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
