Old 09-10-2010, 01:49 PM   #3271
tamiyalover74d's Avatar
This is next on my list after I buy a ff03 pro. I think I hear a rumor about my local track actually running a F1 class.
tamiyalover74d is offline   Reply With Quote
Old 09-10-2010, 08:46 PM   #3272
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by FREAKAH View Post
I would get the Tamiya aluminum motor plates(blue-#54166, black-#84115) and either of the soft T-plates(soft-#54165, high traction-#54222) and maybe an aluminum pivot post(blue-#54169, black-#84116) just to put more weight at the rear.
A steel axle from the F60 kit(#3555152) can also help you get a handle on the car in loose conditions.
Agree 100%
Run the rear T bar, pivot plate and shock/spring as soft as possible with out freeplay in anything i.e. T bar center screw just barely seated, pivot plate adjuster nut just touching spring and minimal preload on shock spring (soft gold one if you can get one) with lite oil and 3 hole piston.
Diff grease on pivot plate and a thick diff oil on the upright posts up front for some dampening.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 09-10-2010, 09:36 PM   #3273
kdeselms's Avatar
Good info guys, thanks...this will definitely help. The parts are shipping to me now, but I'll have to wait a couple weeks before I can put it all together.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 09-12-2010, 09:12 AM   #3274
GasGod's Avatar
Is there an aftermarket rear pod lower plate( the cheapo plastic plate that attch. to the t-bar)?I have cracked or broken 3 this summer.Would like to see something stronger,maybe alum.or graphite.I don't have this prob.with my 103 1 piece t-plates.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 09-12-2010, 09:20 AM   #3275
Barry White's Avatar
http://www.rc-square.com/
Barry White is offline   Reply With Quote
Old 09-12-2010, 10:59 AM   #3276
tunerjetta29's Avatar
Just ordered my f104 pro and yeah racing conversion set from rc mart! Can't wait to put it together!
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
tunerjetta29 is offline   Reply With Quote
Old 09-13-2010, 03:58 PM   #3277
spring71's Avatar
Smile
Attention all pan car racers !!
1st TQ Pan Car Grand Prix will be held on October 31st, Sunday.
Detailed rules and classes will be announced on www.tqrcracing.com
If you have any idea, comment and advice, please post a reply.
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 09-16-2010, 08:01 PM   #3278
Anywhere to find a good setup sheet PDF?
Currently Running:
Ko Propo EX-1 V3
Old 09-16-2010, 08:15 PM   #3279
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
http://www.tamiyausa.com/articles/ln/442/setup.pdf
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-19-2010, 08:58 AM   #3280
cheehtae's Avatar
Trader Rating: 15 (100%+)
Is the steel rear axle better than the CF axle for high grip (carpet) surface? Use with rubber tires.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 09-19-2010, 09:45 AM   #3281
Foxxrocket's Avatar
A carbon fiber axle is going to make the car a few grams lighter, and create less rotational mass.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 09-19-2010, 11:56 AM   #3282
spring71's Avatar
Smile
Due to the Halloween, the schedule has been changed.
TQ Pan Car Grand Prix will be held in October 17th Sunday.
Hope it works for everyone
TQ RC RACING
Online Shop
tq@tqrcracing.com
Old 09-19-2010, 06:00 PM   #3283
hanzo3's Avatar
Trader Rating: 55 (100%+)
Had a chance to run my 104 today. My car spins out alot. Is that the nature of direct drive? Or is it my setup? I am running stock components w/ rubber tires. I am using a QC3 esc too.
hanzo3 is offline   Reply With Quote
Old 09-19-2010, 06:13 PM   #3284
Welcome to the club. Rear grip is the challenge with the F104. The solutions are to go as soft as you can with the rear suspension. The Tamiya super soft T-bar is a help. Make sure you use the o-rings and leave the center screw loose. Soft rear tires are also part of the deal. Get the Tamiya super softs and use them with the hard fronts. I've also had good luck with the Ride super soft rears, but you have to go to Hong Kong to get them. A slow steering servo also helps. I use a QC2 and it works fine.
One more thing, it also helps to get a super soft trigger finger. let off the throttle slowly, brake in a straight line and ease the throttle back on.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 09-19-2010, 06:19 PM   #3285
lightfoot's Avatar
Default September 25th F1 race
Ultimate F1 Day
Saturday September 25th
Camarillo California , track opens at 7AM for practice
3 min , fast lap Qualifying 10:00 AM
3 15 minute races
2 mandatory pit stops
http://www.charleslightfoot.com/UF1SD.html
Raffle prize #1
Professionally built, F104 Pro, with Tekin RS ESC, Novak 21.5 motor,
2.4 receiver, Orion 3200 lipo, Shimizu rubber, Calvinization modification, custom painted F60 body from F1 Paint-lab...
Ultimate RTR F1... just bind to your radio and
go... estimated cost $920
Raffle prize #2
Tamiya F104 Ferrari Kit
Each racer will have their name placed in a container... after each race, if you did NOT receive a penalty your name
will be placed again in the container, increasing your odds of winning... Also after each race, the announcer and the
pit marshal will each choose one person who they felt was the cleanest driver of that race, regardless of how they
finished and there name will be added again to the container... Basically the cleaner you drive all day, the better
your chances of winning the prize Also, in case of a tie, the driver with the least amount of penalties win...
Love and Peace...
lightfoot is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
