Old 08-15-2010, 01:50 PM   #3136
GasGod's Avatar
Originally Posted by Foxxrocket View Post
What part of the car is bouncing?
mainly the front,it upsets the back too on cornering and gets loose on exit.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 08-15-2010, 09:42 PM   #3137
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by robk View Post
Out of the box, the Tamiya tires will get sticky and pick up all the carpet fuzz and junk, leaving you with no traction. I understand this is supposed to be helped by running the tires through a few heat cycles, as in a few asphalt runs. I do know that i have run asphalt used tires that did not pick up fuzz the last time I was at the carpet track. I do not know if this will be the same for everyone.
Would any kind of traction compound helps in not picking up the fuzz and yet give good traction on carpet then??
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-17-2010, 09:17 AM   #3138
Originally Posted by GasGod View Post
How do you get these cars to stop bouncing and chattering? -- stock 104pro setup except soft t-bar, on stock foams, Med grip asphalt ,silvercan.I have a 103 and 109 also, neither of these do it.
Mine actually rarely bounces (during cornering). It will bounce if i hit a bump going straight (mainly the rear being too stiff). In general though, the car is very drivable and definitely planted.
Try:
1) tightening the disc damper. i run this tighter than stock recommendation.
2) run a red spring. I have the old tamiya red spring, which is softer than current tamiya "red dot" white springs (ie: the kit spring). This is paired to a shock that has 40wt oil and 3 hole piston.
3) lube your kingpings. I put the stock shock oil on the kingpins. smoothed the front right out. The front works exceptionally well... I can see the front arms working over bumps as the tires stay planted.
EDIT: this is all on med traction tarmac.
boro92 is offline   Reply With Quote
Old 08-17-2010, 09:30 AM   #3139
MikeR's Avatar
Trader Rating: 14 (100%+)
Jack the Gripper is great for reducing pick up but those Tamiya tires are just a pain no matter what.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-17-2010, 01:17 PM   #3140
Foxxrocket's Avatar
I would say go with softer springs first.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 08-17-2010, 02:07 PM   #3141
robk's Avatar
Trader Rating: 22 (100%+)
The best thing seems to be breaking the tires in on asphalt. Otherwise, maybe try just cleaning with Buggy grip for example. I was able to run paragon at my home track with no issues, but I'm not sure if this was just my track?
Old 08-17-2010, 02:15 PM   #3142
robk's Avatar
I was having some problems with this as well, but with the rubber tires on high grip asphalt. This only appeared as the grip came up. I was not running any type of lube or diff oil on the kingpins, which I normally do for carpet and foam. I have not had that problem with the foams on carpet, which is definitely very high grip, so I assume it is the lack of front dampening. The other thing I wish i had tried was the softer springs, as I think the car was not rolling across the nose enough. It looked like it gripped and hopped over and over since it couldn't articulate. One other fix may be to space up the front of the upper arm to remove some dynamic caster effect. You will loose some mid corner front end grip, but it may help in that situation. These are all things I need to try as well
Old 08-17-2010, 03:38 PM   #3143
Raman's Avatar
Trader Rating: 49 (100%+)
Hello to all, I'm going to be receiving one of these tomorrow. Was wondering what "functional" hop ups you recommend for the Pro kit.. (I'm not looking for bling hop ups)
Thanks in advance
Raman is offline   Reply With Quote
Old 08-17-2010, 03:42 PM   #3144
robk's Avatar
Aluminum motor mount, aluminum camber plate, low friction suspension balls.
Old 08-17-2010, 05:23 PM   #3145
Raman's Avatar
Aluminum motor mount, aluminum camber plate, low friction suspension balls. __________________ Crush your enemies, see them driven before you, and hear the lamentations of their women I-Lap Scoring Systems http://www.rclapcounter.com/
Thanks!
Old 08-17-2010, 05:30 PM   #3146
Arahawak's Avatar
Thanks both.
robk, if you say breaking in the tires on asphalt, i prob try to do with a tire sander with scotbrite to get a more even break in .. you know how asphalts are..
Old 08-17-2010, 06:15 PM   #3147
robk's Avatar
Thanks both.
The first set I had I put on a tire truer, and it was about the same
Old 08-17-2010, 07:13 PM   #3148
Arahawak's Avatar
.. hmmz.. your track surface rocks then!
Old 08-17-2010, 10:59 PM   #3149
AndreC's Avatar
What up fellow F104'ers! Just got my car.
Does anyone have a recommendation for a good lipo battery? Good power but relatively cheap?
I purchased a battery with banana connectors only to find out it would'nt work.
AndreC is offline   Reply With Quote
Old 08-17-2010, 11:07 PM   #3150
J-VET's Avatar
If you get the F-60 top deck it will work as long as the battery fits in the space. The Bannana plugs go towards the back. Thats how I run my car for TCS. Much cheaper then a new battery. As for the Pro top deck I just cut the front back and used 2mm spacers where the top deck met the servo mounts.
Hope this helps
J-VET is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
