Like Tree5Likes
Old 07-01-2009, 09:54 AM   #301
strodedawg's Avatar
Trader Rating: 54 (100%+)
can you mount under the knuckle and shim the the inner ball to remove bump steer
Team Whiteknuckle-Jim Mastroddi
TLR 5B-e 8s Hitec/JX/HW/Poseidon RC/SMC
Roche P10W 235 Hitec/JX/SMC/SMC/SMC (FOR SALE PM ME)
GRP/Dynamite/Grafil/Punched RC/RC Monster/Protoform
strodedawg is online now   Reply With Quote
Old 07-01-2009, 09:56 AM   #302
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Have you tried mounting the ball stud on the underneath of the knuckle instead of on top. I am planning on doing this as the car has a lot of bump steer in the stock configuration.
Originally Posted by Vyger View Post
Has anyone else tried adjusting the ride height at the front end of the car? I lowered the front of the chassis by rearranging the spacers on the king pins and it really through the steering links up to a steep angle. The result was major bump steer. I was thinking of using the shorter/smaller servo horn but I know this will change the ackerman. Does anyone have any comments or suggestions?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 07-01-2009, 11:49 AM   #303
Vyger's Avatar
Thank you all for your quick replies.
I've looked at trying to mount the ball stud on the bottom side, this is exactly what I have on my F103. If you do this with the F104 the steering links rub on the lower a-arms.
The only option I can see is using the smaller servo horn with F103 ball studs attached to it. It might not be so bad when the tires are cut smaller and I can raise the chassis, but for kit size tires and lowering the chassis this is a BIG problem.
Tamiya Road Wizard, F101’s, F102’s, F103’s, F103RS’s, F103LM, F103RX’s, F103RM’s, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 07-01-2009, 02:47 PM   #304
Default Body Pods
Hiya
Was wondering if there was any advantage to installing the body pods?
They look to have a tight fit onto the body sides and around the chassis bottom plate.
I havnt seem these before are they for aerodynamics?
Cheers
Si
sijorg is offline   Reply With Quote
Old 07-01-2009, 03:11 PM   #305
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Alfie View Post
Did your GTB protrude out? I tried putting my GTB but it's like not meant for that tight space.
I have it mounted vertically and it clears both the sides and the top of the body comfortably. I'm more concerned about the motor wiring, but an confident that with some slightly lighter gauge wire routed differently, it should be a lot tidier.
Here's some pics
Tamiya F104 Pro!-f104a.jpg   Tamiya F104 Pro!-f104b.jpg   Tamiya F104 Pro!-chassis.jpg
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 07-01-2009, 04:36 PM   #306
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Here's some pics
why did you cut off the bottom pan?
akura2 is offline   Reply With Quote
Old 07-01-2009, 04:40 PM   #307
Does anyone know where I can get a tire truer arbor that will fit both the F-104 wheels and a Hudy tire truer?
Crashby is offline   Reply With Quote
Old 07-01-2009, 04:52 PM   #308
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
....in addition to that question, do the front rims have tc-style hex drives or do they carry a bearing?
What are the Length, width (track f/r), wheelbase, and dry weight of the F104?
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 07-01-2009, 06:31 PM   #309
The only option I can see is using the smaller servo horn............
Which is exactly what I did. Just drill out the hole so you can use the kit ball studs. The small Kimbrough servo saver will also work.
Depending on the servo you use, you may need to mount the servo back further in the chassis and put the ball studs on the front of the saver.
The long servo saver allows to much bump steer no matter what ride height you run. I've only done a couple of shake down runs in front of the house, but the difference was noticable after I made the change.
Shoot for the best, expect the worst and be willing to accept anything in between.
MADHAT is offline   Reply With Quote
Old 07-01-2009, 07:08 PM   #310
Trader Rating: 19 (100%+)
Hey just out of curiosity where is everyone getting those cool blue hop-bits from? In particular the motor mount?
I've looked at a few sites but can't seem to find them.
bee200sx is offline   Reply With Quote
Old 07-01-2009, 07:41 PM   #311
Metla's Avatar
rcmart.com and stellamodels.net both have the blue bling.
Metla is offline   Reply With Quote
Old 07-01-2009, 07:58 PM   #312
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
Hey PDR,
Thanks for the pictures and your reply.
Just one question: does your ESC and motor get hot after you run for a pack?
I'm not so comfortable with a GTB not having its fan around. It thermalled on me once when I run it at a bigger track on my F103GT. I don't want that to happen again.
Alfie
Here's some pics
F103Kª • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 07-01-2009, 09:15 PM   #313
Thanks for that guys. I am about to get the car so I just need to confirm what to get and what not to get with it. Now as far as blue bling goes what should I get as in what comes with the kit and what doesn't. I'm not bothered as to whether it will improve handling or not. I just want to hop up the car. So far my list is as follows:
54159 F104 Aluminum Horn for Hi-Torque Servo Saver
54166 F104 Aluminum Motor Mount (Right & Left)
54169 F104 Aluminum Pivot Post
84058 F104 Titanium Screw Set
54161 F104 Low Friction Suspension Ball Set - I'm not sure whether this already comes with the kit or not, can someone please confirm.
54158 F104 Aluminum Diff Housing Set - I'm not sure whether this already comes with the kit or not, can someone please confirm.
Also can anyone tell me if the 3Racing Servo Mount for the F103Rm will fit in the F104?
What do you guys think? Anything else?
Old 07-01-2009, 10:04 PM   #314
robk's Avatar
Trader Rating: 22 (100%+)
If you have a 1/12/1/10 arbor, that will do the fronts very nicely.
The drive hex off of the left side of the axle will fit over the threads on the Hudy truer. Just tighten the grub screw down and go to work on the rears.
Otherwise D-Drive Sports has arbors from Eagle racing for about $25
Old 07-01-2009, 10:18 PM   #315
MaxSp97's Avatar
54161 F104 Low Friction Suspension Ball Set - I'm not sure whether this already comes with the kit or not, can someone please confirm. "KIT CAME WITH ALUMINUM BALL SET"
54158 F104 Aluminum Diff Housing Set - I'm not sure whether this already comes with the kit or not, can someone please confirm. "YES"
Also can anyone tell me if the 3Racing Servo Mount for the F103Rm will fit in the F104? "NO"
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
