Like Tree4Likes
Old 07-28-2010, 03:15 PM   #3061
Andysan's Avatar
Originally Posted by kmichael View Post
Quick question:I'm torn between 3racing 109 & F104 pro,really leaning to the pro because tamyia has been doing the F1 thing for quite some and would think more R&D,any help on this? The track is carpet.
F109 beat off all competition in a 5-day series spread over 5 months that I race in. IMHO the F104 has better scale looks but its true to life - it has skinnier tyres and the battery is placed down the centre of the chassis to achieve this. Its a very ncie looking car and when setup will run well on carpet, but the F109 will beat it with ease. However, it looks nothing like an F1 car IMHO.
Andysan is offline   Reply With Quote
Old 07-28-2010, 05:06 PM   #3062
GasGod's Avatar
you ever see a 109 with a tamiya or chevron body?It looks quite nice-IMHO
and still performs as a 109; the stock body does leave a lot to be desired.
A guy I know is going to bolt up a 104 front end and run "skinny"tires.I don't think it will hurt it too much.And yes I have both-I prefer the 109 on both surfaces.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 07-29-2010, 12:15 AM   #3063
The f109 shell can look very tidy and scale check mine below
I have both, I think the F109 is great value and it is the faster car. I run brushless 13t in my f1's on a tight small circuit. (there are some vids on my blog)
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-29-2010, 02:23 AM   #3064
Foxxrocket's Avatar
If you think the F109 looks nothing like an F1 car, then you haven't seen Corally's F1 car.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-29-2010, 08:32 AM   #3065
cheehtae's Avatar
Trader Rating: 15 (100%+)
what kind of turnbuckles do you guys use? also will the rubber tire that came with the F60 kit be fine or would i need to get the soft tire for the rear? ( rubber)
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-29-2010, 09:12 AM   #3066
Foxxrocket's Avatar
I use Tamiya hard front rubber tires (54198) and soft rear rubber tires (54199).
Old 07-29-2010, 09:19 AM   #3067
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I like the soft rears pretty much everywhere I run it, even on carpet so far.
They get the "death groove" quickly tho, the foam shifts to the outside edge then the inside edge gets the groove worn into it.
You'll see but the tires work pretty nicely, especially on the very first run.
After that they settle in to a consistant tire for many good runs, then the groove.
Fresh set of soft rear and kit/medium fronts and it doesn't get much better than that so save a set for when it really counts and practice with the "scuffed" sets.
I stole Lunsford turnbuckles and Losi cups and balls from a retired buggy.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 07-29-2010, 10:25 AM   #3068
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ditto - works great on asphalt/parking lots
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-29-2010, 10:33 AM   #3069
cheehtae's Avatar
So the rubber tires that came with the kit are Medium tires? also will hpi tires fit the tamiya wheels?
Old 07-29-2010, 11:07 AM   #3070
Foxxrocket's Avatar
I know that RIDE, Shimizu Racing and RP Racing also make tires for the F104. But I'm not sure if HPI tires will fit on Tamiya wheels.
Old 07-29-2010, 11:29 AM   #3071
F N CUDA's Avatar
I've been calling the kit rubber tires medium cuz the option rears are soft and the option fronts are hard.
When I ran the option front hard tires with the option rear soft tires I had almost no steering but the tracks I hit have pretty good or even great traction.
Parking lots will be the difference I'm sure, unless Charlie B is layin down the magic traction sauce. His parking lot circuit tracks are hooooked up!
The hard fronts work better for me with the kit/medium rears, better balance but I also find the kit/medium rears don't have enough traction for me in most situations.
This may be the hot ticket on super hot surfaces, harder compounds but when it was pretty friggin hot here in So Cal at the Tamiya track (130* track temp) I still was quicker with the soft rear/medium front combo.
I think the idea was to use option tires to balance the kit tires on either end.
Option front/hard with kit/medium rear or
Option rear/soft with kit/medium front.
Anyone got change for a nickel?
Craig Hammon
Old 07-29-2010, 11:55 AM   #3072
Foxxrocket's Avatar
Would front spring rates change the handling on hard front tires? I use windtunnle baby springs. So maybe using a harder spring rate would keep the front tires planted. Or would that just compound the understeering problem?
Old 07-29-2010, 11:50 PM   #3073
tmkhaw's Avatar
Send a message via MSN to tmkhaw
Default Your default gear ratio
Hi guys,
Quick question, what is your preferred default gear ratio when you go to any new track. Assuming that the track is moderate in size with 50 - 70m straights and normal technical sections.
The stock ratio for F104 Pro is 104 spur and 25 pinion which gives 4.16.
I notice most guys at my track are running around 5 and above. ie. 105/21 or higher ratios.
Give give me your ratios will suffice. Thanks a lot.
tmkhaw is offline   Reply With Quote
Old 07-30-2010, 07:55 AM   #3074
lightfoot's Avatar
HPI tires will deform when mounted on Tamiya rims, Tamiya rims are larger in diameter...
In order to use HPI rubber properly on a 104 you need RIDE wheels...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 07-30-2010, 05:39 PM   #3075
cheehtae's Avatar
Also need gearing on a 21.5 motor?
Tried using the search button but still down for repair.
Thanks guys.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
