Old 06-30-2009, 02:58 PM   #286
Suspended
Cool
Anyone tried F103rs rubber tires in the F104 PRO ?
bertran is offline   Reply With Quote
Old 06-30-2009, 03:40 PM   #287
Trader Rating: 26 (100%+)
One more question (not really, I am sure I will have a lot more). If I convert to 64 pitch, what might be a good starting point for Spur size/pinion size when running 17.5. I might aleady have the gears I need.
svines1972 is offline   Reply With Quote
Old 06-30-2009, 04:39 PM   #288
robk's Avatar
Trader Rating: 22 (100%+)
roll out the car pretty high. I would get a 80-88 t spur. you're gonna need a good sized pinion. In 12th scale, they have run as high as 80mm rollout, but that is with 4 cell. Try around 50mm and work your way up.
Old 06-30-2009, 06:03 PM   #289
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
When I was with my F103GT, I raced with 7.5R. It's a matter of getting used to.
In my opinion for gearing ratio for your 17.5R, you can do 75T (Spur) with 24T (Pinion) for a start. Try it on the straight at your preferred track and see if the car reaches top speed (by listening to the sound, or by the feel of your throttle) right after the halfway point (Straights only, do choose the longest straight, if there are a lot of it at your track). If your car reaches top speed before the halfway point, gear up in your pinion gear. Reason being that if your car reaches top before the halfway, over a period of time, the motor will give way. So nurse your motor, as well as your ESC.
Try asking your friends to see if they lend you the pinions to test-drive, before you commit to the gear ratio by buying the pinion you like. Oh yeah, Go get those Spur Gear Adaptor (ring thing) and that allows you to fit any 64p or 48p spurs in the market. If you get the 3Racing ones, remember to shave a fraction off the width. They are too broad to make the diff work.
Hope it helps!
Alfie
94eg - Do you know what spur the kit will have? And what pinions would be a good starting point for 17.5?
Originally Posted by Core Creations View Post
104t and 93t spurs and a 25t pinion...same as the F103R. Gear for your straight. The 17.5 is a LOT of motor in this car and can be a bit much if ogeared to high. Just make sure you gear it to stop pulling about 3/4 or so down the straight...anymore and it will be difficult to drive consistently.
F103Kª • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 06-30-2009, 07:25 PM   #290
Metla's Avatar
What's the advantage of the aluminium motor mount?, Looks liek a lot of people are fitting them right from new.
Is it just looks?, Is the motor mount a weakness? (and how would anyone know at this stage?)
Metla is offline   Reply With Quote
Old 06-30-2009, 07:32 PM   #291
Alfie's Avatar
The easier and "no-money-involved" method is to make a hole big enough for the 1280 bearing to be fitted in the centre, with a reamer or a drill bit.
But of course, you will have to be able to part with the fact that this method defeats the use of the spur gear for other cars.
Just make sure that the hole that you make is not too big. A little loose is fine, because ultimately, it's the diff plates that's holding on to the diff balls, and not a solid axle setup.
Alfie
Originally Posted by Solara View Post
Yo...see the link below, the little plastic O-RING is the adaptor, with that O-RING, you can use all the 64P spur gear from robinson or kimbrough...etc
http://www3.towerhobbies.com/cgi-bin...?&I=LXN136&P=7
Or use the 3-Racing one..
http://rcmarket.com.hk/product_info....oducts_id=4652
http://www.rcmart.com/catalog/rc-f10...1-p-27621.html
Old 06-30-2009, 07:34 PM   #292
Alfie's Avatar
It warps, under direct heat (which is coming from your motor, if not from your local climate).
Alfie
Old 06-30-2009, 10:55 PM   #293
I checked Gearchart.com and with a 78/27 the gear ratio is 7.51. Does this sound about right? Rollout will have to wait until i can get the measurement for the tires.
Old 07-01-2009, 02:28 AM   #294
Alfie's Avatar
For me, I find that the rollout is too much to catch up on. The diameter is constantly changing every single pack of runtime. So I use the track to gauge my gearing, and at the same time, check to make sure that the motor does not overheat at all, though sometimes I tend to overgear to get the high-speed adrenaline.
Alfie
I checked Gearchart.com and with a 78/27 the gear ratio is 7.51 using. Does this sound about right? Rollout will have to wait until i can get the measurement for the tires.
Old 07-01-2009, 03:11 AM   #295
alan1467's Avatar
Has anyone fitted the cheap tamiya brushless TBLE-01 speedo? does it fit ok?
Or what brushless speedos are people using?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 07-01-2009, 05:44 AM   #296
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I've put a Novak GTB in mine. The wiring is tight (and might need to be fine tuned), but definitely manageable. It's driving a 17.5T brushless, so I've removed the fan to keep the profile down a bit. I haven't fitted the side pods, since I decided I liked the slimline look and the fan would have been largely ineffective against the side of the body.
Had it's first run last night at our club track (smaracing.org) with a field of F1's, mostly F201's. It's an outdoor track and I was a bit terrified about a lack of grip in cooler air (well, cooler for Sydney), but it hung in quite well for it's first public display. I was under-driving it quite substantially, but the main thing: it was a lot of fun!
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 07-01-2009, 08:36 AM   #297
Alfie's Avatar
Hi!
Did your GTB protrude out? I tried putting my GTB but it's like not meant for that tight space.
Alfie
Old 07-01-2009, 08:45 AM   #298
Vyger's Avatar
Has anyone else tried adjusting the ride height at the front end of the car? I lowered the front of the chassis by rearranging the spacers on the king pins and it really through the steering links up to a steep angle. The result was major bump steer. I was thinking of using the shorter/smaller servo horn but I know this will change the ackerman. Does anyone have any comments or suggestions?
Tamiya Road Wizard, F101’s, F102’s, F103’s, F103RS’s, F103LM, F103RX’s, F103RM’s, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 07-01-2009, 09:45 AM   #299
Vyger's Avatar
Here is a picture is what I’m talking about. This shows the steering links at the recommended stock locations. By lowering the chassis this raises the front axel and makes the links attach at a steeper angle.
Old 07-01-2009, 09:47 AM   #300
JayL's Avatar
maybe spacers under the steering linkage mount at the knuckle end
JayL is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
