Like Tree1Likes
Old 04-20-2009, 01:45 PM   #16
RC MARKET's Avatar
around June release !
RC MARKET is offline   Reply With Quote
Old 04-20-2009, 01:58 PM   #17
tallyrc's Avatar
be interesting to see the price point they come in at.. there are already high end F1 cars i'd rather have like rcindycar's and corally's or hyperdrive's... but if it is still a fair price like the original 103 is...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 04-20-2009, 02:13 PM   #18
Solara's Avatar
Trader Rating: 16 (100%+)
Just simply observation....15th R version is about $220 USD...this one, hope they will throw in the alum heat sink motor mount...with almost the same upgrade like the 103R, with the revised body, revised tire set...I would guess it will be around $300 USD. And I think that is reasonable. But not higher...
Race tuned 12th scale is around $250 without tires and body.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-20-2009, 05:23 PM   #19
tallyrc's Avatar
$300 is not bad if it comes with tires and the body..
Old 04-24-2009, 02:24 PM   #20
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
I like the fact that the battery runs down the center... it allows for bodies that are narrower in the rear, like the real thing... the sculpting of the side pods is REALLY nice
BTW
$305
http://www.hlj.com/product/TAM58431?nav=rss
akura2 is offline   Reply With Quote
Old 04-27-2009, 06:15 PM   #21
Default F104 or HPI
Looking to buy. Why would I pick F104 or HPI.
Regards.... Steve
PIRONI is offline   Reply With Quote
Old 04-27-2009, 11:47 PM   #22
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Well, the F104 would probably be $100-150 more than the new HPI F1.
Dan is offline   Reply With Quote
Old 04-28-2009, 09:43 AM   #23
F104 and HPI... Let's see, you get CF chassis, aluminum tidbits, and a ball diff on the F104. With the battery layout of the F104, I see this as a better handling car.
But there is no need to pick these up unless you are into F1 or your club is going to have a F1 class.
redbones is offline   Reply With Quote
Old 04-29-2009, 07:23 PM   #24
Herc Driver's Avatar
I would/will get either if folks start racing them! I think they are both A+
Herc Driver is offline   Reply With Quote
Old 04-29-2009, 08:17 PM   #25
snoopyrc's Avatar
Are most of you guys TCS minded when it comes to these things? If there was a TCS race around here I would build a car for it. But without it I would rather go with an MLP car.
It seems like The Tamiya cars stay TCS legal as long as theres the hope of a race near by. As soon as Tamiya discontinues a car (which means no more TCS for that chassis) then 3Racing sells a bunch of hop ups for it.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-05-2009, 04:43 PM   #26
fat500's Avatar
Trader Rating: 29 (100%+)
need more info drooling
fat500 is offline   Reply With Quote
Old 05-05-2009, 04:53 PM   #27
Vyger's Avatar
Regards.... Steve
From what I can tell there are a number of differences between these kits, not just price. Theyíll both have plenty of hop-up support from each of their own companies and aftermarket. But comparing them straight across the board looks like comparing apples to oranges. Iím sure HPI will also come out with a pro kit, but this is an entry level starter kit. You need to keep that in mind when your shopping price. The HPI car is fiber reinforced plastic and the Tamiya has carbon fiber and aluminum and plastic.
HPI is stating they will have body and nose kits representing new and old F1ís (high and low nose cars). They havenít said anything about rear wings. Iím thinking theyíll offer what ever TRG is making, just a hunch. Tamiya seems to be struggling with their body sets, one can only hope there will be more options available. But both offer nicely detailed body and wings.
HPI is also using rubber tires, a big plus in my opinion. Theyíll have several types to choose from. And theyíll last a while for the budget minded racer. Where they struck out in my opinion is with the hex on the front wheels. I really think they should have stuck with a more universal bearing on axel config, like typical pan cars. It doesnít really make cense. Itís not like you can swap fronts to rears. I think they missed the boat on this one. The Tamiya car uses foams. The traction is probably a little better and the after market options are a plenty. Plus Tamiya will probably offer more compounds down the road like they use to, one can only hope.
HPIís car comes with bevel gear diff. While Iím sure they will have an option for a ball diff, the Tamiya F104 PRO car comes standard with one and ball bearings to support it. The HPI car comes with a solid rear axel made from steal, the Tamiya comes with a carbon fiber shaft (at least it looks that way from the pics).
The HPI car comes with an oil filled shock, plastic damper plate, and plastic damper disks. The F104 Pro comes with a TRF threaded body oil filled shock, carbon fiber damper plate, and teflon damper disks.
The HPI car uses 4cell battery's packs and the Tamiya uses 6cell packs. That means the Tamiya will be able to use a Lipo pack (assuming it will clear the upper deck).
These are some of the differences that I can think of off the top of my head, Iím sure thereís more. Good luck with your choice. Personally I plan on getting both.
Tamiya Road Wizard, F101ís, F102ís, F103ís, F103RSís, F103LM, F103RXís, F103RMís, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 05-05-2009, 07:14 PM   #28
lightfoot's Avatar
BTW
$305
What do you guys think about this battery down the center ? I was talking to someone at the track the other day and his opinion is that it's a bad idea... according to him, this will transfer less weight side to side an therefore less grip in the turns... Is there any truth to this ?
lightfoot is offline   Reply With Quote
Old 05-05-2009, 08:32 PM   #29
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Not in my opinion, as there are many on and off road cars with the battery down the center which work just fine. I believe that someone is confusing the center of gravity with the polar moment of inertia.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 05-05-2009, 08:56 PM   #30
Manny's Avatar
...and don't forget Cross and Tech have already tried this configuration, so it must have some merits!
Manny is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
