Like Tree4Likes
Old 06-23-2010, 02:22 PM   #2941
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Originally Posted by dodo View Post
if the new T-bar is of the same material as the older soft T-bar, removing the centre screw on the new T-bar will give the same setting as using the older soft T-bar without the centre screw, right?
That's what I was thinkin.
Anyone tried both of the option t bars with and without the center screw?
Also thinkin the t bars are more drastic on the graphite/pro chassis?
My F60 (rubber kit tires front and options rear) was pretty good with the kit t bar but did see some improvement with the new one on.
Might just be pushin into the corners too much but feels better comin out.
Only got to run it for a short time tho.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-23-2010, 09:25 PM   #2942
PeeTee's Avatar
Hi Guys ..... anyone interested in sharing some set up tips for the F104. Just getting into F1 after many years in Touring Cars and have no idea where to start with a pan chassis. What adjustments do what .... We run on medium traction asphalt and intend to run rubber tyres.
Hope I can get some answers ...... Thanks,
Serpent S400 Tamiya F104
Southern Tasmanian Model Car Club
www.stmcc.com.au
PeeTee is offline   Reply With Quote
Old 06-23-2010, 11:38 PM   #2943
Jay_P's Avatar
Originally Posted by k_bojar View Post
well i like the sound of the more stability and ability to get the power down out of a turn guess it time to order one
are you running the center screw or not?
I'm using it with the centre screw and just the small O ring with 1.5 - 2mm of thread poking through the nut
Jay_P is offline   Reply With Quote
Old 06-24-2010, 05:39 AM   #2944
j.d.roost's Avatar
Trader Rating: 28 (100%+)
The 3-racing f109 shock comes with a VERY soft clear o-ring.
I use this in the center spot with a few mm of thread showing past the nut.
j.d.roost is offline   Reply With Quote
Old 06-24-2010, 08:34 AM   #2945
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I ran with the screw in place, but backed it WAY out, something to the tune of 3mm. I would have just removed it, but didn't want to run afoul of the TCS rules which read, "Any modification not called out specifically in these rules is not legal", "No chassis lightening allowed", as well as "The F104 chassis must be built per the instruction manual. Altering its basic structure and design is prohibited." Granted, I was being extra cautious and the guys in tech were simply looking for the bigger issues like high RPM motors and non-Tamiya tires. But I figured better to be safe than sorry. Moral of the story, the car worked better with more pod articulation.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 06-24-2010, 11:36 AM   #2946
Trader Rating: 24 (100%+)
Where's the best place to buy replacement parts for the F104's that have them in stock? I lost the c-clips and can't find them.
Thanks,
Jody J.
JodyJ is offline   Reply With Quote
Old 06-24-2010, 01:48 PM   #2947
Default F104 roll out
Hopefully you guy's can help me ,can a rs sport tuned black can handle a 50.6 roll out with out frying the motor , tire 50mm pinion 30 spur gear 93t or should I gear it down I'm running this weekend in a TCS race it's a pretty big track.
Faroh of RCTV is offline   Reply With Quote
Old 06-24-2010, 01:59 PM   #2948
2CARTEAM's Avatar
Thanks,
Jody J.
Try SpeedtechRC.com. There in the city of san gabriel
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 06-24-2010, 02:57 PM   #2949
Thanks, they had what I needed
Jody J.
Old 06-25-2010, 09:09 PM   #2950
lightfoot's Avatar
Default wet weather tire
Is anyone aware of a wet weather rubber tire for the 104 ?
For those truly adventurous drivers who race F1's in the rain, what tires do you use ? I would really love to race in rain one day
Love and Peace...
lightfoot is offline   Reply With Quote
Old 06-25-2010, 09:17 PM   #2951
Back when our F103 series was still going strong we found the normal rubber tires we ran in the dry also worked better in the wet than the treaded Pro-Line tires. With both the capped rubber tires and the B compound rubber tires grip would actually get better once the track was wet enough. When it was just starting to get wet it would be very slippery but once the track was quite went the grip was good. I would imagine the same would hold true for the F104.
Old 06-25-2010, 09:25 PM   #2952
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That is exactly what I found too.
The Soft capped tires were magic in the wet, the car had far more grip than in the dry.
You would aim for the damp parts of the track, if the water was too deep the car would hydro-plane on the chassis, you had to be careful where to put it.
Good times when the rain would stop and start during a run
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-25-2010, 09:56 PM   #2953
lightfoot's Avatar
So basically go with the softest compound , and that should do it right ? ...
Love and Peace...
Old 06-26-2010, 04:38 AM   #2954
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i recently ran mine in the rain, during a rain delay at the track...
it hooked up pretty good, was running the optional soft rears - kinda hooked up better then in the dry
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-28-2010, 05:48 AM   #2955
Oortael's Avatar
Is there any difference between the titan and the alloy turnbuckles? Except from the material...
Oortael is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
