Like Tree5Likes
Old 06-21-2010, 04:26 PM   #2926
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by RC MARKET View Post
I try to become a member on your site and it wont let me...It keeps going back to the sign in screen
hairymuffin is offline   Reply With Quote
Old 06-21-2010, 04:37 PM   #2927
If you are running a cookie blocker you will need to allow cookies.
Old 06-21-2010, 04:55 PM   #2928
3Racing has new suspension arms coming out for the F104. They have an angled leading edge rather than the stock straight one.
http://os.3racing.hk/products.php?products_key=4105
Old 06-22-2010, 01:55 AM   #2929
Jay_P's Avatar
[QUOTE=InspGadgt;7571391]3Racing has new suspension arms coming out for the F104. They have an angled leading edge rather than the stock straight one.
Anyone know how this will effect the way the suspension works, if at all?
As the pivot points look to be in the same place
Shame they haven't made the top arms with adjustable castor
Jay_P is offline   Reply With Quote
Old 06-22-2010, 06:24 AM   #2930
Have you tried using Microsoft Internet Explorer??
I have same problem when using FireFox..
hansenhon is offline   Reply With Quote
Old 06-22-2010, 08:32 AM   #2931
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Originally Posted by aussierevo View Post
Got to have a run with the new T Bar from Tamiya. I must say initial impressions are good.
rubber tires all round and the middle screw kept out...
I didn't make any adjustments to the roll adjustment screw...
middle screw kept out?
where the o ring sits?
roll adjustment screw?
I have the new T bar and also like it.
Thanks David
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-22-2010, 12:08 PM   #2932
eevul's Avatar
Thanks David
I am also interested to know which screw to leave out. Any pics?
eevul is offline   Reply With Quote
Old 06-22-2010, 01:44 PM   #2933
aussierevo's Avatar
Trader Rating: 14 (100%+)
Using the Tamiya Soft T Bar I had good result's with not using the roll adjustment screw. I left it out altogther to help with grip. So where you would insert 3 3x10mm screws to attach the t bar to the diffuser, I only used 2
With the new Hi Traction T Bar, I've installed it as per the instructions so have used all three screws in the rear of the t bar and set it as per the manual setting with 1mm. I will need to see what changes small adjustments will make to the set-up, if it improves the car more, or even removing this screw altogether helps.
Hope this clears things up. Apologise for any confusion.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 06-22-2010, 01:58 PM   #2934
[QUOTE=Jay_P;7573470]
It shouldn't affect it at all except maybe different flex in the arms. The pivot points are all the same. It is more of a cosmetic change to make it look more like this year's F1 suspensions.
Old 06-22-2010, 11:52 PM   #2935
Arahawak's Avatar
Trader Rating: 32 (100%+)
So you are using the previous soft t-bar without the middle screw and o-ring.
and that with the new high traction t-bar, you are using it as per instructions and if grips is not there, removing the centre screw may help, is that what you are saying?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 06-23-2010, 12:29 AM   #2936
dodo's Avatar
Send a message via Yahoo to dodo
if the new T-bar is of the same material as the older soft T-bar, removing the centre screw on the new T-bar will give the same setting as using the older soft T-bar without the centre screw, right?
dodo is offline   Reply With Quote
Old 06-23-2010, 12:39 AM   #2937
Arahawak's Avatar
If so, i would have wasted my money on it.
Old 06-23-2010, 02:50 AM   #2938
aussierevo's Avatar
thats correct.
I felt the high traction t bar is actually not as stiff as the standard soft t bar. It was a noticeable difference the movement it allowed once installed. I don't know if it was the due to the u shape notch that is cut from the new t bar, or if it is actually a softer material then the soft t bar.
Speed Passion F1.
Old 06-23-2010, 05:30 AM   #2939
Jay_P's Avatar
From what I've noticed, the soft T bar and the high traction T bar are the same material. The extra cut out in the high traction provides more forward/aft flex but the side to side is about the same as the soft with the small O ring on both
I run foams on tarmac and 27t motor, the new T bar has helped a lot with straight line stability and getting the power down out of the corners for me
Old 06-23-2010, 01:35 PM   #2940
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
well i like the sound of the more stability and ability to get the power down out of a turn guess it time to order one
are you running the center screw or not?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
