Like Tree1Likes
Old 06-13-2010, 02:55 AM   #2896
hi.
can you share some setups for carpet racing using foams or rubbers for the f104?
thanks.
bosschick is offline   Reply With Quote
Old 06-13-2010, 07:29 AM   #2897
cyclone x's Avatar
Originally Posted by bosschick View Post
hi.
thanks.
sorry cant help now my track is ashpalt we put carpet on top in winter
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 06-14-2010, 12:04 PM   #2898
alan1467's Avatar
Default Pit Shimizu Rubber Tyres
Is anyone using the F104 Pit Shimizu that fit on the foam rims?
If so any problems with grip/wear and side walls ripping?
Went through 6 sets of rears yesterday with ripping side walls or zero grip on the second run. It was not just me but a lot of people
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 06-14-2010, 01:06 PM   #2899
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I had one set, the sidewall over the plastic edge of the foam type rim design is not a good idea for racing near barriers.
Touch anything and the wheel is sucked into the barrier instead of glancing off.
RIDE tires are much better, and have a unique wheel for their tires.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-14-2010, 02:18 PM   #2900
Part of the trick to foam tires is how you mount them...if the method used doesn't adhere really well they will be more prone to chunking of the edges. You can't avoid that happening totally unless you never hit anything. But a good gluing procedure will reduce it a lot.
Old 06-14-2010, 02:53 PM   #2901
The Pit tires are rubber type, but they use the standard F-104 Foam rim.
An odd setup to say the least.
Old 06-14-2010, 02:58 PM   #2902
ah i missed that...thought you were talking about foam tires.
Old 06-14-2010, 05:47 PM   #2903
cyclone x's Avatar
i see your avatar is redbull now i love monster but the shop i work at just got redbull stickers in pretty sweet
Chase Chandler
Old 06-16-2010, 10:55 PM   #2904
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default F104 Racing on rubber too!
We continue with the Le Mans 24 Minutes after F1 so bring your cars!
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-17-2010, 03:28 AM   #2905
Oortael's Avatar
Has anybody tried the SANWA SDX-801 Low Profile Servo on a F104?
Some friends use it for their touring cars and it works pretty fine in their cars.
Oortael is offline   Reply With Quote
Old 06-17-2010, 06:45 AM   #2906
cyclone x's Avatar
i use a low profile futaba
Chase Chandler
Old 06-17-2010, 07:20 AM   #2907
Oortael's Avatar
How does it work? Is there any play at the mount points?
Old 06-17-2010, 09:35 AM   #2908
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I had play when mounting my servo, didn't want to double up the servo tape to fill the gaps and the extra mounts were too tight.
I used one of each of the mounting plates and the fit was perfect, a couple thousandths off center but the fit was tight.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-17-2010, 01:06 PM   #2909
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Looks like HPI is catching on to the 2009/2010 season stuff...
HPI F10 new bodies
as WE only get Ferrari F60s
akura2 is offline   Reply With Quote
Old 06-17-2010, 02:22 PM   #2910
Oortael's Avatar
Did you use the aloy servo mount point or the kit ones.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
