Old 06-07-2010, 10:01 PM   #2851
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by xterc View Post
I wonder if someone could help me find a dealer that might have part#13455372 (Wheel Stopper) in stock. I've tried Googling it but keep coming up short.
Tamiya is currently out of stock and I've stupidly sheared it while putting a wheel on.
Any help would be appreciated...
There's a 3racing brand "wheel stopper" over on rcmarket.com.hk
I couldn't find the Tamiya part anywhere either.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 06-07-2010, 10:13 PM   #2852
Thanks guys, I was hoping to find somewhere in the US, but I ordered from
rcmarket as suggested.
xterc is offline   Reply With Quote
Old 06-07-2010, 10:15 PM   #2853
Thanks guys.
Old 06-08-2010, 08:56 AM   #2854
Barry White's Avatar
That's the problem with the Tamiya parts. Seems like when you put an alu nut on the alu wheelstopper the parts destroy each other becouse of the same material softness (problem is as old as the first F103, so +15 years). Use a steel nut or put some grease on the treadz like mentioned in the F104 manual. Best off all is to use Qteq stoppers with a hollow titanium axle (of course not TCS legal). Those parts are lighter, stronger, better centered (and keep dust out better on diff side)and more expensive:
Barry White is offline   Reply With Quote
Old 06-08-2010, 09:04 AM   #2855
j.d.roost's Avatar
Trader Rating: 27 (100%+)
Slick setup.
j.d.roost is offline   Reply With Quote
Old 06-08-2010, 11:40 AM   #2856
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Or you could just order this part, it is a 103 part number, but identical to the 104, and it comes with the diff side for a 103
RC Diff Joint Bag: 58194/156
Item #9805524
MSRP: $9.50
and it is in stock at TA
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 06-08-2010, 12:11 PM   #2857
Item #9805524
MSRP: $9.50
The 103 diff is quite different in how the wheel bolts on on the diff side from the 104.
Old 06-08-2010, 12:22 PM   #2858
Item #9805524
MSRP: $9.50
Do you know if these are in steel or aluminum?
Sydewynder is offline   Reply With Quote
Old 06-08-2010, 12:25 PM   #2859
I think he broke the left side. 103 and 104 should be the same. You're right that the diff side are different.
Old 06-08-2010, 01:43 PM   #2860
reenmachine's Avatar
Trader Rating: 26 (100%+)
It's not that they're Tamiya parts, it's a simple matter of similar materials. The same could happen with a stainless axle coupled with a stainless nut, etc. Either use dissimilar materials or lightly grease the threads (AW grease works well).
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 06-08-2010, 01:58 PM   #2861
Fortunately I've never had a problem with this...bent axles yes but never a broken wheel hub in all the time I've been racing Tamiya F1 cars starting with the F102
Old 06-08-2010, 11:11 PM   #2862
BP SHADOW's Avatar
Im probably jinxing myself here, but I too have never had an issue with this.
and the part# i referenced is aluminum.
I just got 2 in to put a couple of 103"s back together
http://f1rclab.com
Old 06-09-2010, 02:33 AM   #2863
My understanding is that it is with certain similar metals like aluminum with aluminum...since aluminum oxidizes that seizes the metals together...likewise with titanium...but steel on steel shouldn't. Or so I've been told.
Old 06-09-2010, 02:39 AM   #2864
Maybe a dumb question here but....Has anyone tried using one of the mini 2s lipos in the F104? I would think you could get some handling benefits by moving the battery forward or back. Some sort of brace would have to be made but I'm sure it could be done.
Evoracer is offline   Reply With Quote
Old 06-09-2010, 07:11 AM   #2865
Aluminum can indeed oxidize, but anodizing does a good job of preventing that.
The culprit here is an effect called galling.
Pete Waydo
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
