Like Tree4Likes
Old 06-02-2010, 10:00 PM   #2821
Trader Rating: 24 (100%+)
It's been mentioned on this thread before but no one responded. That site is www.rc-trg.com. Be prepared...its all Japanese
Evoracer is offline   Reply With Quote
Old 06-02-2010, 11:49 PM   #2822
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by j.d.roost View Post
As said above the 103 front will be a direct bolt on.I am running that setup right now.
I would suggest running the 103 rear tires so you don't have a
crazy offset thing going on.
The 103 pins have notches to hold the knuckle in place and hold the spring at the bottom of the arm.
Thanks for all the hints guys. I ordered some kingpins, but inadvertently, not the standard ones
I picked up the 53119 "special" ones and I've attached the instruction sheet for people's benefit. The spring does indeed fit between the knuckle and the upper arm.
Cheers,
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 06-03-2010, 03:12 AM   #2823
cyclone x's Avatar
Originally Posted by Evoracer View Post
Newbie question here. Seen this TRG setup mentioned in this thread before but no answers were offered. Anybody tried this on the F104 and what is the effect ?? Any other TRG chassis or suspension stuff that is working well ??
i know its TRG but looks similar to a 3Racing setup
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 06-03-2010, 03:39 AM   #2824
tmkhaw's Avatar
Send a message via MSN to tmkhaw
Hi,
Could you advise at what point are you getting your understeer?
On turn-ins/off-power or on-power?
If it is on-power, How is your diff setup?
If it is off-power, have you tried 0.5 degree of toe out?
Is the problem equal on both left and right turns?
Thanks.
Originally Posted by Steve Pertuch View Post
Hi guys I have a setup question to everybody. It seems like I have the opposite problem like most of you guys. My car seems to push/understeer a lot. We are driving on a carpet indoor track and it seems like I can't keep up with all the others in the infield. To get arround the corners I have to drive slow and have to take the corners wide. It seems like I get not enough weight on the front tires.
Here is my setup:
F104 Ferrari F60
http://www.tamiyaclub.com/showroom_m...8023&sid=20068
- Type A foam tires
- soft gold M chassis spring
- 200 weight Tamiya Oil
- 3 whole shim in damper
- teflon friction plates with no grease
- kit springs on the front
- 1 degree camber
- 0 degrees toe (neutral)
- jack the gripper for saucing ... half on the fronts/full on the rears
- kit T-bar
- rideheight in the fron 4mm 5.5 in the back
I don't know what the problem is but I need more corner speed to be competitive. Can it be that because of the soft setup in the rear not enough weight gets transferred to the front while breaking? The other problem is this track is bumpy as crazy and so the car should be soft in the rear otherwise you loose contact on the fast straight.
The car is also really twitchy for that I will try more Expo the next time like most of you guys recommended.
Anyone ideas about the problem?
Steve
tmkhaw is offline   Reply With Quote
Old 06-03-2010, 05:12 AM   #2825
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by geeunit1014 View Post
He saw what a good 103 does against a good 104, and its not pretty
Like I am one to talk anyway...What car did I end up running in the main last week?(103)
j.d.roost is offline   Reply With Quote
Old 06-03-2010, 06:55 AM   #2826
cyclone x's Avatar
im getting f104 set up for a race in two weeks hopefully i could get it done with this car
Chase Chandler
Old 06-03-2010, 07:08 AM   #2827
Oortael's Avatar
If I start racing, which kind of stuff (spare parts, tires, tools, oils, etc.) do I need for a whole race weekend (tamiya cup germany)?
Oortael is offline   Reply With Quote
Old 06-03-2010, 09:23 AM   #2828
MikeR's Avatar
Trader Rating: 15 (100%+)
They are side damper tubes much like you see on 1/12pan cars except they are lever actuated when the rear pod moves left or right. They do not actuate when the pod moves front to back. Simple yet ingenious
Damper tubes are generally more consistent then damper pucks.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 06-03-2010, 08:48 PM   #2829
F N CUDA's Avatar
Hey my Homies!
What setup tips can you give me for my new F104 (F60) with rubber tires to get around the carpet at TQ?
I've got kit tires for front and rear + a set of options for the rear too.
So, are F1s running in the 24?
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-04-2010, 06:08 AM   #2830
cyclone x's Avatar
Originally Posted by F N CUDA View Post
Hey my Homies!
you might wanna go with a harder rubber tire up front. or could even put f103 tires on
Chase Chandler
Old 06-04-2010, 07:28 AM   #2831
RC MARKET's Avatar
limited black option parts
Tamiya F104 Pro!-ta-84114.jpg   Tamiya F104 Pro!-ta-84115.jpg   Tamiya F104 Pro!-ta-84116.jpg
RC MARKET is offline   Reply With Quote
Old 06-04-2010, 10:08 AM   #2832
FREAKAH's Avatar
Great!
Now I gotta get the pod plates and diff hub parts just to match my MP25 scheme.
The Tamiya blue pretty much clash with every F1 team livery out there lol.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 06-04-2010, 10:50 AM   #2833
dodo's Avatar
Send a message via Yahoo to dodo
hahah!
i just finished my F60 earlier (minus the bodyshell) and mentioned to my friend how sexy the F104 is without any blue aluminium upgrade attached. especially with that red front and rear wings.
seemed that tamiya heard me and quickly put rcmarket to post the limited edition black anodized alum upgrades.....
oh no.....
dodo is offline   Reply With Quote
Old 06-04-2010, 11:46 AM   #2834
Oortael's Avatar
What gearings do you use?
Old 06-05-2010, 06:51 PM   #2835
Metla's Avatar
I see the new T-Bar is now available from retailers.
54222 F104 High-Traction T-Bar
Metla is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
