Like Tree1Likes
Old 05-27-2010, 03:43 PM   #2776
lightfoot's Avatar
Default UF1 Series
8 days till the TQ UF1 race...
And then June 20th were back at WCRC for a UF1 race...
That's a total of 92 points maximum I believe this month alone... so no matter where you are in the series standings, you can make up a lot of ground this month... and also don't forget that the lowest 2 UF1 races will be dropped and 3 lowest Supplemental races will be dropped before the final race late September in Camarillo, which will be an ALL F1 day...
http://www.charleslightfoot.com/UF1/UF1_home.html
Love and Peace...
lightfoot is online now   Reply With Quote
Old 05-27-2010, 07:09 PM   #2777
yourstruly22's Avatar
[QUOTE=lightfoot;7464981]8 days till the TQ UF1 race...
http://www.charleslightfoot.com/UF1/UF1_home.html[/QUO
What's the best foam tiers combo for West coast.
Pass me clean or don't pass at all
yourstruly22 is offline   Reply With Quote
Old 05-27-2010, 07:10 PM   #2778
[QUOTE=yourstruly22;7465800]
For a f104
Old 05-27-2010, 08:34 PM   #2779
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
[QUOTE=yourstruly22;7465806]
Originally Posted by yourstruly22 View Post
For a f104
The 104 rolls best on B's at WCRC
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-27-2010, 09:13 PM   #2780
B's all round?
Old 05-27-2010, 10:37 PM   #2781
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
B's all round?
yeah it helps if they're round
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 05-28-2010, 02:56 AM   #2782
few pics of my f104 f60 after painting:
http://www.imagebam.com/image/3f3dd182269652
http://www.imagebam.com/image/3311a582269655
http://www.imagebam.com/image/f336ce82269665
total3d is offline   Reply With Quote
Old 05-28-2010, 06:57 AM   #2783
Trader Rating: 29 (100%+)
Default Lipo Battery
Looking for a suggestion on a good Lipo for the F104 while keeping the weight down. Our A main is 15minutes using a silver can motor.
RSTECH is offline   Reply With Quote
Old 05-28-2010, 08:08 AM   #2784
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Don't know bout that, I hear Fred Flintstone used to TQ his races and never had to true his tires.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 05-28-2010, 08:24 AM   #2785
Default lipo-suction
I use less than 1000 for an 8 minute main, so twice that is probably a good guess. I don't know about you, but I use an LRP Q2 speedo, since it's so small and light, but it doesn't have a lipo cutoff. To keep on the safe side, I use an Orion 3800. A lower capacity will be lighter -- the 3800 is 50 grams lighter than my 5000. The lipos that look like a stick pack fit better than the bricks. My Orion is a brick and I install it with the bullet plugs towards the rear of the car. I had to cut 1/4" diameter notches in the top plate for the plugs to clear, but the wire runs to the speedo are short. That's about all I know on the subject.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 05-28-2010, 08:37 AM   #2786
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i got a peak 4000 pack in mine, and like jeff said, i think the most I used out of it was around 1000-1200 mah - but that was for 6 minutes...i think i might have use closer to 2000 for a 8 minute main
with a silver can and a tekin b1 speedo
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-28-2010, 11:59 AM   #2787
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
doesn't answer the question... but REALLY funny... ROTFL
nice one BP!
akura2 is offline   Reply With Quote
Old 05-28-2010, 06:17 PM   #2788
spookyrduch's Avatar
Send a message via Skype™ to spookyrduch
Default F 104 pro High Speed Twitchyness
Hello,
I must admit I am quite desperate and confused about my F104 pro at the moment.
At my local outdoor track ( fairly low grip) my car will handle ok with either foams or option rubbers. However, I experience incredible high speed instability on the straights. And I find no cure.
I am currently running the car with following settings:
Camber 1°
Toe In 0.5°
Ride Height front 4 mm
Ride height rear 5mm
Springs hard black front
soft T-bar
I would be very thankfull for quick suggestions since I am competeing at a Tamiya Euro Cup event this weekend in Southern Germany.
Thanks!
spookyrduch is offline   Reply With Quote
Old 05-28-2010, 06:38 PM   #2789
Default F104 pro High Speed Twitchyness
Hello,
I am quite confused about my F104 Pro I was sure to have a solid understanding of.
While running at my local outdoor track today ( low grip conditions) my car handled fine... EXCEPT on the straights. No matter what I tried, the car was so twitchy, I wouldn't even dare to go full speed.
I tried foams, rubber, mix but no cure.
my basic set up data are:
Camber 1°
Toe-in 0,5°
hard springs front
Ride Height Front 4mm
Ride Height Rear 5mm
Soft T-Bar
The car isn't tweaked and I am running out of ideas. I would be happy for quick answers since I am competing in the German Tamiya Euro Cup Race in Southern Germany this weekend. Any improvement to my basic setup is highly welcomed.
Thanks !
Old 05-28-2010, 07:26 PM   #2790
Originally Posted by spookyrduch View Post
Hello,
Camber 1°
Toe-in 0,5°
hard springs front
Soft T-Bar
Thanks !
Try smaller dia tires, 60mm or less even
Front ride height 1mm higher than rear
and 3.5mm offset upright, if you can find them.
"Truly22"
Yes front & rear B's
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
