Like Tree4Likes
Old 05-24-2010, 06:34 AM   #2761
I wonder if the new left wheel hub will work on the F-103,I belive the two axles are the same except for the length? I have destroyed a couple of shafts by over-tightening them
TheOtherBill is offline   Reply With Quote
Old 05-24-2010, 07:13 AM   #2762
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Metla View Post
Can anyone comment on the T-bars from 3racing?
They don't seem to be discussed or even mentioned so far, and one of the sets listed as for the f104 doesn't even look like it would fit.
I am using the 1.3 bar on my 103/104 and love it.
It's REALLY soft so make sure you like that sort of setup
or buy a stiffer plate.
j.d.roost is offline   Reply With Quote
Old 05-24-2010, 07:15 AM   #2763
j.d.roost's Avatar
You need the 104 left/diff assy.and the f104 axle.
Works like a champ.
Old 05-25-2010, 12:17 PM   #2764
Hey Guys, I'm a total noob and I just finished building my f104 pro. I have a question that I am hoping someone might be able to answer.
I seem to have a very bad vibration on the left rear when under power. If I hold the car up ad give it full throttle I can feel it. If I hold the left wheel and let the right spin, it is smooth. If I hold the right and let the left spin it vibrates badly.
First I thought It might be a tire imbalance (bad glue job) but I tested it with foams ad the problem was still there. Not as bad as with the rubber tire, but still there none the less.
Any ideas as to what might be the cause?
caveryis is offline   Reply With Quote
Old 05-25-2010, 12:29 PM   #2765
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I would check the axleshaft itself, and then check the hex with the wheel off
check to see if there is any visible wobble to the axle or the hex. Also check to make sure you have the hex seated correctly on the axle
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 05-25-2010, 12:51 PM   #2766
Oortael's Avatar
Since my last crash i've got some camber problems. On the left side it is ok at 2.5 (impact side, but all parts changed) and on the right hand side there are 4 degree. What am I doing wrong?
Oortael is offline   Reply With Quote
Old 05-25-2010, 01:00 PM   #2767
reenmachine's Avatar
Trader Rating: 26 (100%+)
crashing.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 05-25-2010, 01:02 PM   #2768
Just kidding. My F104PRO has been crashed more than probably any of them built!
What parts have you replaced? Small tweaks to the front plastic pieces can equate to good-sized differences way out at the wheels.
Also, how are you measuring the camber?
Pete Waydo
Old 05-25-2010, 06:04 PM   #2769
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I have seen the threaded part of the left hex hub bent, with the left wheel off check to see if this is true.
Remove the pinion and spin the rear axle assembly, it should spin freely.
The entire left hub should spin true.
If it's a bad glue job, then the problem will switch sides if you swap wheels left to right.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-26-2010, 07:24 AM   #2770
Barry White's Avatar
Works like a champ.
No, you don't.
Barry White is offline   Reply With Quote
Old 05-26-2010, 07:35 AM   #2771
j.d.roost's Avatar
Was thinking diff. side.
Hey,it's left if your looking at the front of the car....DOH
Figured he figured that out by now.
Yes the non diff.side is the same as the 103.
Old 05-26-2010, 09:08 AM   #2772
Yes I did, thanks fellas.
Old 05-26-2010, 03:00 PM   #2773
Oortael's Avatar
I've replaced everything of suspension on the left except the kingpin and the spring.
I bought me the hudy pan car setup system some weeks ago.
Old 05-27-2010, 07:28 AM   #2774
Ive put together my first kit F1 Pro which includes the ball diff that I have zero experience with. My question is, How do you know how much grease to put on the ball bearings for the diff?
I found out after a small electronic / motor test that I put way too much. The grease went flying all over the workbench and car. Instant conclusion: too much grease. Should I take the diff apart and clean it up and start over?
I know your having a laugh over this cuz its a NOOB mistake
Any response is appreciated
2Revos 3.3/ 4Tec
Rustler VXL / HPI Flux
F1Pro CC4600 / TT01 CC5700
2XRevo is offline   Reply With Quote
Old 05-27-2010, 08:49 AM   #2775
Default Advice from the Diff Dude
I built the diff in my 104 using Dave Irrgang's (via Garry Owen) diff method. Works really well. The key is to dull the diff rings with 600 grit sandpaper, clean them well and use very little lube.
Here's the full description:
http://www.teamirsrc.com/techtips.html
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
