Old 05-17-2010, 01:13 AM   #2716
FREAKAH's Avatar
I also ran my Pro on track for the first time today. My first impression was the car is alot more nervous than my 103. The car is also jittery over small bumps, kinda like it's skipping over them. Did some changes to calm things down a bit but I think I gotta do a test & tune on an off day at the track to sort things out. A friend's F60 aint nearly as jittery as mine, so maybe the fiberglass chassis/brace absorbs alot of the shock. As for traction it was pretty good front and rear although it could use a stiffer front spring to cure a hook on some turns.
My car is just a basic F104 Pro upgraded with a soft T-Plate, Tamiya aluminum pod plates, and a Tamiya aluminum pivot post with a stick-on 1/4 weight so I can get more weight toward the back. I also have the offset steering knuckles which really helped to calm the steering at high speed. For tires I ran F60 kit front rubbers and option soft rear rubbers. Motor is a silver-can.
Upcoming changes:
More weight out back. My 4000 lipo is way lighter than a nicd/nimh stick pack.
Might cut away front portion of upper brace for more flex.
F60 kit rears(for longer wear)
Reduce bump-steer
Thicker shock oil, or thinner oil(shock might be packing)
Anyways, I had a fun first race with my Pro but some of the problems made me miss my 103 lol. I'll still keep plugging away with the 104 however as i'm sure i'll eventually figure things out.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-17-2010, 06:34 AM   #2717
j.d.roost's Avatar
Trader Rating: 28 (100%+)
One thing I noticed with the longer plates and the new battery location is the car had both some push and would snap spin at the same time.(if you pushed it on corner exit).
With the standard 103 chassis it would be twitchy but not spin out.Sort of did the 103 "dance" in a the fast sweepers.
I could never get push with the 103 and could use rocks as front tires and still have too much steering.
j.d.roost is offline   Reply With Quote
Old 05-18-2010, 08:00 AM   #2718
fullout's Avatar
Send a message via MSN to fullout
Default rear rubbers
Has anyone tried running them minus the inserts?
I'm hoping the added side wall flex will be a little more forgiving when applying throttle.
Please post feedback is you have tried this already.
fullout is offline   Reply With Quote
Old 05-18-2010, 08:18 AM   #2719
inconceivable's Avatar
Originally Posted by k_bojar View Post
Has anyone tried the HPI F10 tires on their F104s? do they mount on the Tamiya rims? Since i know HPI uses wheel hexes on the front/rear of the F10, I assume those rims are outta the question
thanks
They fit ..... BUT ..... not well. The F104 rim is just a hair off which causes the HPI tire to be higher on the side walls than the center of the tire. I mounted some of these up and for the rears, after several runs, I've only worn the outer edges of the tire, like 20% of the tire. The fronts eventually ground down to even wear, however developed a wicked pinch groove on the inner edge. That said, even with the above problems, these tires were much better than the Tamiya kits or softs at my particular track (high bite asphalt). I've since ordered the Ride F104 rims and am going to mount another set of these HPI's to those. It's my understanding that the Ride F104 and HPI rubber tires are actually the same ?
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 05-18-2010, 09:51 AM   #2720
Barry White's Avatar
New T bar at 1m59 mark:
+ YouTube Video
Similar as the Squat one for the F103:
Barry White is offline   Reply With Quote
Old 05-18-2010, 11:04 AM   #2721
MikeR's Avatar
Trader Rating: 14 (100%+)
+ YouTube Video
Badly needed for the F104 Should help out for medium/low grip tracks.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-19-2010, 12:27 AM   #2722
FREAKAH's Avatar
Good eyes. Had to pause it perfectly to see the cut in the T-plate. That should really help the 104's handling. I wonder if that T-plate is Tamiya's response to handlling complaints or if it was already in the pipeline at the 104's release. In any case I will get one when it's released.
However, i'm starting to think that the Pro's 3mm carbon chassis and 2mm upper plate is just too darn stiff. Like I said in an earlier post, a friend's F60 F104 looks fine on the track without skipping and jiggling over the bumps and he's running the stock stiff black T-plate. My cars rear traction is OK but it does hook on some turns. I just might chop the front portion of the upper plate and see how that goes.
Second-Hand Racing
RACE WORLD HAWAII
Old 05-19-2010, 02:22 AM   #2723
MikeR
Making anything for the F104?
Sydewynder is offline   Reply With Quote
Old 05-19-2010, 07:32 AM   #2724
F N CUDA's Avatar
Trader Rating: 30 (100%+)
You might try unbolting the front of the upper plate, let it slide around before cuttin one up?
Seen it done on the F103 before.
I just built my F60, my swag for winnin the TCS Regional (I know,still blowin my own horn ).
Guess I'm gonna have my hands full gettin it dialed but at least I have the TQ guy in my corner givin me tips on F104 rubber setups.
As a matter of fact, he listed his whole setup on the TCS thread and it's pretty thorough.
Look up RtypeC over there, he was fast with his.
By the way, what's up with the F104 in the video above using the F103 front end and wheels/tires?
It shows the F104 tag below the car.
That setup has to be the hot ticket but kinda blows the whole scale, car of right now thing don't cha think?
Is that the new Wolf release or will that one have even fatter tires all around? (yeh, diggin those fatties of the old days!)
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 05-19-2010, 09:39 AM   #2725
Man, I wanted to bring out the same T bar as this 4 months ago. Bummer, Tamiya will walk away with my money. Still now we can use it in TCS.
Old 05-19-2010, 09:50 AM   #2726
cheROK1212's Avatar
I was wondering with the Wolf release will you be able to run a 103 hybrid @ TCS?
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 05-19-2010, 10:01 AM   #2727
RC MARKET's Avatar
+ YouTube Video
Yes more soft for low grip track or carpet !
RC MARKET is offline   Reply With Quote
Old 05-19-2010, 03:38 PM   #2728
fullout's Avatar
You mention the TCS thread, where do i find that? i tried searching this sight and nothing came up. I've been trying to setup my f104 with rubber for tcs also, but i find as soon as you apply throttle she spins. I glued up a set of optional rubbers without the insert, to test, i'm hoping the added flex in the sidewall will help with throttle induced oversteer.
Old 05-19-2010, 03:55 PM   #2729
F N CUDA's Avatar
Here ya go, scroll down this page and you'll find it.
Tamiya Championship Series
Craig Hammon
Old 05-19-2010, 04:03 PM   #2730
fullout's Avatar
Thanks for that F N CUDA
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
