Old 05-13-2010, 11:16 AM   #2686
Originally Posted by RedBullFiXX View Post
While offset axles do shorten the wheelbase by 3.5mm, that is not the point of their use in tuning.
Offset axles locate the axle behind the kingpin to change the way a car turns, and have a profound effect on handling and added stability.
One can expect mid corner, to corner exit under-steer with this option.
Don't ask why, but this got me thinking about geometry. With offset axles, the effect of caster is amplified when turning. There is no caster difference when going straight.
To see what that meant to weight transfer, I threw my 104 with offset axles on the gram scales and got this:
LF RF
224 221 -- wheels straight
205 241 -- wheels right lock
259 188 -- wheels left lock
Obviously, I have more travel to the left than to the right. Guess I'll address that later. The point is that there is considerable weight transfer -- more than I'd expect from caster alone. If anyone has scales and a 104 with inline axles, we can see those numbers as well.
So the effect is that as I steer right, the right front loads up, but also sends weight to the left rear. As this dynamic happens, you'd expect the car to turn smartly to the right. As I exit the turn and reduce steering lock, the weight gets more neutral and the car wants to go straight, bringing on the corner exit understeer that RedBull mentions.
I'm new to pan car setup, but an experienced friend of mine tells me that you can never have enough caster. He may be on to something. The offset axle is a clever way to add needed caster effect when you can't get it otherwise.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 05-13-2010, 01:36 PM   #2687
JayL's Avatar
Anyone done chassis/top deck testing with rubber tires(F104pro CF vs fiberglass F60)?
JayL is offline   Reply With Quote
Old 05-14-2010, 12:27 AM   #2688
Arahawak's Avatar
Trader Rating: 32 (100%+)
Back to back testing nope, but the fibreglass chassis/top deck combination provides more traction/flex on asphalt.
On carpet, might want to revert back to CF.
Personally, before the fibreglass chassis/top deck was available, i ran CF on asphalt and the car is abit washy even with foams. Crazy stuffs you need to do to find grip. With the fibreglass chassis/top deck, i have better traction/flex generally and lesser stuffs to do to find the grip.
In theory, soft setup for asphalt and hard setup for carpet.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 05-14-2010, 12:30 AM   #2689
alan1467's Avatar
Anyone know where to get the fibreglass chassis and top deck?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 05-14-2010, 05:37 AM   #2690
cheROK1212's Avatar
Wondering the same. For now we may have to part out a F60. Not bad when you think you get the frp chassis, F60 bodyset, a crappy set of rubber tires and spare front end parts and a metal axel
...hold my 'stones.
cheROK1212 is offline   Reply With Quote
Old 05-14-2010, 05:47 AM   #2691
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I ordered mine through Tamiya America directly. I realize you guys aren't in the States, so that wouldnt be an option for you. I am just finishing up the build of my FG car, although I am running the carbon top deck because I won it in the raffle at the TCS race.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 05-14-2010, 06:06 AM   #2692
j.d.roost's Avatar
Trader Rating: 28 (100%+)
While we are on the topic of top decks,I need some help.
I can't get a satisfying fit for my bullet style lipo packs (checkpoint and and zippy).
I have my upper deck notched in the rear but can not get my -,+ wires in the pack in a way that does not either hit the friction plate (full deflection) or rub the underside of the body..(unless I rase the rear of the body up high on the posts).
I have tried standing the connectors straight up and also at a 90° bend and just can't get it to fit right. Sloppy wires and too close to the graphite for my liking.
I have thought about chopping off the front half of the upper deck and just taping the pack to the chassis. Could use some pics of you setups if you are using bullet connectors.
Thanks for any help.
j.d.roost is offline   Reply With Quote
Old 05-14-2010, 06:17 AM   #2693
reenmachine's Avatar
Trader Rating: 26 (100%+)
Here's a pic of mine -- Orion 3600 lipo. I cut a section of the top deck completely away (I race on outdoor asphalt so the flex is welcome). I left the front portion of the top deck there to hold the battery retainer piece. Works perfectly!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 05-14-2010, 07:19 AM   #2694
cheROK1212's Avatar
Thanks, just ordered also.
...hold my 'stones.
Old 05-14-2010, 07:21 AM   #2695
j.d.roost's Avatar
That helps.
Thanks.
I notice that you are running your steering servo vertical.
Any benefit to this?
Old 05-14-2010, 07:30 AM   #2696
That helps.
Thanks.
It's a low-profile servo so I tried it this way. My steering is so incredibly twitchy I'm starting to think this may be a factor, so I'm going to try it the regular way next. It packaged nice this way though. I'm also thinking about trying a good ol' $13 sloooow servo to calm things down.
Pete Waydo
Old 05-14-2010, 08:00 AM   #2697
bl4
bl4's Avatar
Hi are you using the red touring soft spring?
bl4 is offline   Reply With Quote
Old 05-14-2010, 06:08 PM   #2698
Arthur Burns's Avatar
Anybody have any tips for gluing the F104 rubber tires? (Tamiya ones).
Thanks!
X-Ray T2 '06 - Novak GTX/Spektrum 3100
Tamiya F103 RM - Novak XBR/Spektrum 300 (currently with Protoform Mulsanne body)
Tamiya F103R - Tekin FX Pro/Spektrum 3000
Tamiya F104 Pro - Tekin Fx/Spektrum 3500
Axial SCX10 - HPI Bronco Body - Tekin FX-R/Tekin 45T / Ubiquitous Slash - Stock
Arthur Burns is offline   Reply With Quote
Old 05-14-2010, 06:14 PM   #2699
It's more of a bright orange...don't remember where it came from but it's soft.
Whatever you do, don't look to my pics for setup hints. My car is all over the place right now.
Pete Waydo
Old 05-14-2010, 07:47 PM   #2700
rtypec's Avatar
Thanks!
I can answer that one...considering I just glued up 3 sets of rears I use Panther tire bands to hold the tire to the rim...sometimes, I use extra rubber bands. That and a fine tip glue attachment with uber thin CA works.
rtypec is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
