Tamiya F104 Pro!
#2506
Originally Posted by Steve Pertuch
its really weird that everyone recommends to run higher in the front than in the rear. What really happens when you run like this? I mean how does it affect the car?
more rear traction because of weight transfer....
... thats what I thought...so why do guys recommend it to me if I write my car is pushy...this will make my car even more push in the corners.
#2507
I'm also looking for the spur gear adaptor so I can run a 48p spur. Tower is on back order. So, to make a long story short, I don't like wating. Is there anyone else in the US that has them? I've looked at UltimateHobbies and I have no clue where it is! Or if anyone has 2 they would sell me, let me know thru a PM!
#2508
If you have an F-104 it doesn't cost anything to try it, then you can make your own decision based on first hand experience.
Having been around racing machines of all scales, I have found very little that is "weird" about finding things to save 10ths of a second.
Every car can go faster given more time to test.
#2510
#2511
I ended up picking one up on ebay. I had to buy the gear to get it. Haha sooooooooo anyone need a 100t HPI spur 64p? lol
#2512
Hi will this #53259 3.5mm offset upright fit on F104 thks.
#2515
hi, i strip my spur gear twice. on my f104. I am using the 96t spur. It was fine before..untill i changed the bushing at the back to 2 (lower). Any ideas?Could be a drive shaft error or anyting?Couldnt be scraping the floor cause its way higher than the chassis.
thnks in advance
thnks in advance
#2516
If you changed your ride height adapter you need to reset the gear mesh. If you did not that is probably why you stripped the gear.
#2518
What's the current 'hot' rubber tire and insert setup, Tamiya Only, Asphalt?
option F&R using inserts?
#2519
I found those Spur Gear Spacers on Ebay, from the seller Dinball. Tamiya #54215 F104 Spur Gear Spacer. I bought 3. The guy had RC Mart plastered all over the auction and his feedback was really good. Just figured I'd give you guys a heads-up..
