Like Tree4Likes
Old 01-19-2010, 04:58 PM   #1966
fat500's Avatar
Trader Rating: 29 (100%+)
I used to true the foams down on my early f103 days to change roll out...get more punch out of the corners, get better gearing options, play with ride ht. and more. Most of the fast guys used to true them down so low they would be 2-3 heat tires at the most. sick I know I have gone rubber long ago.
This foam thing is Tamiyas marketing gurus working overtime.
Remember when they switched to rubber on the f103....foam went away and you could not even buy foam for a long time until they re-released the f103 anniversary chassis. Now they started again with the f104. As soon as the different compound rubber tires come out we will start the cycle all over again. Tamiya has to make those $$ somehow.
foam will fade again. It is new for a new crowd. Let the tire chunking begin
fat500 is offline   Reply With Quote
Old 01-19-2010, 05:41 PM   #1967
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by gtypecanare View Post
Item Man. Yen Description
4373443708212 AMS 1800 8212 1/10 MAR WES MIL WIN BEN 5 RC STICKER
4373443708283 AMS 2100 8283 1/10 DRIFT KING TUNE UP STICKER BLACK
4373443708285 AMS 2100 8285 1/10 DRIFT KING TUNE UP STICKER WHITE
4373443708302 AMS 2300 8302 1/10 RENAULT R25-23 M.7 STICKER
4373443708315 AMS 2300 8315 1/10 JUST FIT RED CAR STICKER
4373443708316 AMS 1600 8316 1/20-28 F1 STICKER FOR SMALL SCALE 1
4373443708317 AMS 1600 8317 1/20-28 F1 STICKER FOR SMALL SCALE 2
4373443708319 AMS 2400 8319 1/10 2006 F1 STICKER F/S/M
4373443708320 AMS 2400 8320 1/10 '06 F1 STICKER(LUCKY/BULL)
4373443708322 AMS 1600 8322 1/20-28 DRIFT STICKER FOR SMALL SCALE(BLACK)
4373443708323 AMS 2300 8323 1/10 JUST P STICKER
4373443708324 AMS 2400 8324 1/10 SCHU FIRST STICKER
4373443708325 AMS 1600 8325 1/24-28 P STICKER FOR SMALL SCALE
4373443708326 AMS 1800 8326 1/24-28 F STICKER FOR SMALL SCALE
4373443708329 AMS 2400 8329 1/10 '07 R/W STICKER
4373443708330 AMS 2400 8330 1/10 AGU/B/TO STICKER
4373443708335 AMS 1800 8335 1/20-28 DRIFT STICKER PART-2 FOR SMALL SCALE(BLACK)
4373443708336 AMS 2400 8336 1/10 HISTORIC SPONSOR STICKER
4373443708338 AMS 2400 8338 1/10 W FW-11 / R JS-41 RC STICKER
4373443708339 AMS 640 8339 1/24-28 '07 F1 STICKER 1(F)
4373443708340 AMS 640 8340 1/24-28 '07 F1 STICKER 2(T/R/P)
4373443708341 AMS 640 8341 1/24-28 '07 F1 STICKER 3(S/M)
4373443708342 AMS 640 8342 1/24-28 '07 F1 STICKER 4(W/B)
4373443708343 AMS 1400 8343 1/24-28 SAKE STICKER FOR SMALL SCALE
4373443708344 AMS 1800 8344 1/10 76J-F/312T STICKER
4373443708345 AMS 1800 8345 1/10 76J-M/23 STICKER
4373443708349 AMS 2200 8349 1/10 C-CAR STICKER
4373443708350 AMS 2300 8350 1/10 LEYTON RC STICKER
4373443708351 AMS 2400 8351 1/10 FW07-08C RC STICKER
4373443708352 AMS 1600 8352 1/10 77J-WR1 RC STICKER
4373443708353 AMS 1500 8353 1/10 FOR-INDI RC STICKER
4373443708354 AMS 2300 8354 1/10 GT-2T RC STICKER
4373443708355 AMS 2400 8355 1/10 F1-FE-RED/WI-BLUE STICKER
4373443708356 AMS 2400 8356 1/10 GT NSX RC STICKER
4373443708358 AMS 2400 8358 1/10 GT-M TYPE RC STICKER
4373443708359 AMS 2400 8359 1/10 MC TOYO 09' RC STICKER
4373443708360 AMS 2400 8360 1/10 '09 WIL/BRA/B STICKER
4373443708361 AMS 2400 8361 1/10 '09 REDB F-1 STICKER
4373443708362 AMS 2400 8362 1/10 '09 TORO F-1 STICKER
4373443708363 AMS 1600 8363 1/10 NEW JAPAN POLICE STICKER
4373443708364 AMS 600 8364 1/20-28 NEW JAPAN POLICE STICKER FOR SMALL SCALE
4373443708365 AMS 2400 8365 1/10 TG183BTG184 RC STICKER
4373443708366 AMS 2400 8366 1/10 OLD LOTU F1 RC STICKER
4373443708367 AMS 2400 8367 1/10 ANNES F1 RC STICKER
4373443708369 AMS 1600 8369 1/10 '09 FOR-INDI RC STICKER
4373443708370 AMS 1800 8370 1/10 '09 F1 RC STICKER
4373443708371 AMS 2200 8731 1/10 F1 SPONSOR RC STICKER
4373443709225 AMS 2000 9225 1/10 BEER RC STICKER
4373443709240 AMS 2300 9240 1/10 MAR WES MIL GAU LUK BEN STICKER
4373443709244 AMS 2300 9244 1/10 Mxraxen B STICKER
4373443709255 AMS 2300 9255 1/10 JxRDxN&WxLLIxMS STICKER
4373443709261 AMS 2300 9261 1/10 S & J RC STICKER
4373443709272 AMS 2400 9272 1/10 02' F1(Taku) RC STICKER
4373443709280 AMS 2200 9280 1/10 2002-03 FE F1 STICKER
4373443709286 AMS 2300 9286 1/10 F1/2003 STICKER
4373443709299 AMS 2200 9299 1/10 TAKUMA STICKER 2
4373443709300 AMS 2100 9300 1/10 FE F2004 STICKER
4373443709327 AMS 1800 9327 1/10 L-97/98T RC STICKER
4373443709398 AMS 1886 9398 1/10 DRINK STICKER[/SIZE][/SIZE]
This is the easy part. Invoicing is the nightmare. Back and fourth.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-19-2010, 05:44 PM   #1968
gashuffer's Avatar
Originally Posted by zpmhinojosa View Post
Don't take this the wrong way guys, but why do you guys bother with trueing your tires? When I get a fresh set of foams or rubs, I just slap 'em on and RUN! I've NEVER had an issue... Just curious. Sounds like alot of work just to get the same results I get just by putting my tires on and run.
Trueing tires allows you to change your roll out/drive. I'm not so sure with 2wd cars but with 4wd your splits are noticeable.
T-Sal
Old 01-19-2010, 10:32 PM   #1969
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
Thanks Fat, pretty insiteful, but one more question. What's "Roll-Out"? Do tell...
zpmhinojosa is offline   Reply With Quote
Old 01-19-2010, 10:35 PM   #1970
O.K., now a question for you. What is "Splits"? In laymens words please, I'm trying to understand these terms...
Old 01-19-2010, 10:48 PM   #1971
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Roll out is the distance your wheel travels per one revolution.
The formula is as follows:
Roll Out Formula: Pinion x Tire Diameter x 3.142 / Spur = Roll Out
Hope this helps
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 01-20-2010, 12:16 AM   #1972
Hope this helps
BP Shadow comes thru again...
Old 01-20-2010, 02:42 AM   #1973
gashuffer's Avatar
Splits are the size you true your tires to.
For example having a 6 split means 6mm size difference between front and rear. Allowing one tire to spin faster than the other. One tire is pulling faster and the other is pushing whereas if both tires are the same size they are spinning together. Think of it as overdrive. Finding the right split for your track/gearing is essential. Makes you go faster more efficiently. To early need Coffee
T-Sal
Old 01-20-2010, 03:02 AM   #1974
clittle's Avatar
I had a rather frustrating night the other night. I think I know what my problem(s) were but I'd also like to run it by you to see if anyone else can give me some more insight.
I was running my F104 Pro the other night. It was about 3degs c so it was cold, and I had forgotten my warmers and traction compound... problem 1. So yes, there wasn't much grip to be had.
The problem I had was that the diff appeared to be slipping after turning. It's a strange thing to try and explain so please bare with me.
If I held the car at a stand still, turned the wheels left, gunned the throttle, the car would spin out, as you would expect. Drop the throttle and the car stops almost instantly.
From a stand still, turn the wheels right, gun the throttle. The car hardly turns or spins out at all. The motor powers up, but there's not the same action from the car. Drop the throttle and the motor slows down a lot slower than when the car is turned the other way.
The result of this is that when I come out of a left corner, I can drive away. When coming out of a right, there's times when you can gun the trottle and the car hardly increases in speed at all, certainly doesn't spin out.
I think the problem is in the diff, and will be rebuilding that soon enough, but does anyone else had some other ideas?
Note: holding both wheels, there is no slip in the spur....
It's quite a hard problem to describe. Cheers.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 01-20-2010, 05:44 AM   #1975
Don't take this the wrong way guys, but why do you guys bother with trueing your tires? When I get a fresh set of foams or rubs, I just slap 'em on and RUN! I've NEVER had an issue... Just curious. Sounds like alot of work just to get the same results I get just by putting my tires on and runnin.
beside the roll out, truing tires also affects handling characteristic..
like the other said, they suffer traction rolling on carpet because stock foam is too big. i also feel the same on asphalt. even though i always adjust the ride height to be same all the time, there is some diameter range which i feel the car handling is better..
60mm something, i dont remember. yes it is a bit complicated, thats why i prefer rubber on asphalt since the tire wear is very significant.
TOP Racing
krat is offline   Reply With Quote
Old 01-20-2010, 08:50 AM   #1976
jrxs-r's Avatar
Front wheels turn fine? Maybe rebuild the diff again making sure that the breville washers are in the correct orientation.
Good luck!
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 01-20-2010, 09:45 AM   #1977
gashuffer, that was perfect, and made perfect sence. Thanks brotha!
Old 01-20-2010, 10:03 AM   #1978
BP, and gashuffer made it un-complicated, I'll have to give it a shot!
Old 01-20-2010, 11:14 AM   #1979
gsxr0311's Avatar
Trader Rating: 18 (100%+)
Originally Posted by aussierevo View Post
d.drive seem to be one of the popular places, but your right, out of stock so often. I have come across someone on ebay in italy, and I sent them an email as they produce all sort's of decals for various scales. I asked if they would be producing 1/10 for the Tamiya F60, particularly the Bar Code and they plan to do them within the next couple of weeks. I will keep an eye out for them and if they are any good I'll let you know. If you want to have a look yourself at what they do, the shop name in ebay is TonyBay ModelShop
thanks. ill check em out
gsxr0311 is offline   Reply With Quote
Old 01-20-2010, 12:22 PM   #1980
mac853's Avatar
Questions??
Could anybody tell me if the F104 foam wheels could really fit in RP and Shimizu slick tires?
Best regards
mac853 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
