Old 01-14-2010, 02:28 PM   #1876
reenmachine's Avatar
Trader Rating: 26 (100%+)
Originally Posted by InspGadgt View Post
This is likely not a diff issue but a rear axle issue. When you tighten the set screw on the non-diff side hub you want a slight amount of play in the axle. Typically in pan cars we slip a piece of paper between the spacer/shim and the bearing when tightening down the hub then remove it after. This gives you the right amount of play in the rear axle. Because the diff is on one side of the rear axle bearings if the axle is too tight it will cause the diff to give uneven amounts of power to the left and right wheel.
Very good input. Now I have to run home to check this in my 104 which recently started snapping around uncontrollably after a rear end rebuild...
Thanks!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 01-14-2010, 06:12 PM   #1877
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
From the looks of things, everyone's set-up is different. My opinion along with my set-up is the opposite. I use no shim, along with no play (slack) in the rear of my 104. I personally have no issues. As I mentioned before a few pages ago, that nut that you tighten berfore the final hub piece on the diff side, should be tightened all the way- then back that nut off a bit. If it's grindy still- back it off some more. You should have a smooth roll yet a tight feel. If you set you 104 down and it doesn't move then obviously re-tighten that very nut a bit more. Not to mention I haven't used that trick were you sand down those diff rings yet either, and I still have no issues. That's my humble opinion.
zpmhinojosa is offline   Reply With Quote
Old 01-14-2010, 06:40 PM   #1878
fat500's Avatar
Trader Rating: 23 (100%+)
coming along nicely.....some bodywork still left to do
fat500 is offline   Reply With Quote
Old 01-14-2010, 07:51 PM   #1879
Originally Posted by WheelNut View Post
vonjet- I noticed the same thing when I built my car last week and I was a bit put off by it, but apparently that's just the way it is. If I had to guess I would say that maybe Tamiya made a change to the tire width after they finished the molds for the wheels. Perhaps they found that the handling balance of the car needed changing.
I just took my lexan trimming scissors and trimmed the excess of the wheel. Then sanded it flat and even with a sanding board. Now my wheels are flush and perfect with the tire.
vonjet is offline   Reply With Quote
Old 01-15-2010, 12:31 AM   #1880
Default BLACK BLASPHEME Progress.
Your's is lookin real tight! I've got the side pontoons and the induction pod left to cut, and I'm tellin you, they're BRUTAL!
Old 01-15-2010, 01:15 PM   #1881
gsxr0311's Avatar
Trader Rating: 18 (100%+)
just got my f60 today. wow the body is really detailed, looks good. they even give you an optional body wing thats on the top rear of the car that covers the engine like the redbull car and the 2008 kimi ferrari.
gsxr0311 is offline   Reply With Quote
Old 01-15-2010, 01:20 PM   #1882
Did you get that extra wing with the actual F60 kit or just the body parts kit?
Never mind, I just took a closer look @ the bottom of the side pontoon mold and saw it clear as day. I almost cut right through it. Luckily I cut around it. Just dug it outta the trash. Good save!!!!!
Old 01-15-2010, 01:26 PM   #1883
gsxr0311's Avatar
it comes with both the body kit and the 104 kit. its on the optional side pontoon part that you cut out.
Old 01-15-2010, 01:30 PM   #1884
gsxr0311's Avatar
if your not careful you can miss it. it almost looks like extra lexan. i dont know why they dont list it as an option on the body insrtuctions.
Old 01-15-2010, 01:31 PM   #1885
It would have been easy if they had mentioned it in the instructions. I guess I just got too excited and went to town. But now I can breathe cause I found it! All I have to do is mask it real good due to the fact that I dueced the film covering, no big!
Old 01-15-2010, 01:32 PM   #1886
gashuffer's Avatar
Trader Rating: 48 (100%+)
How's the chassis flex in the F60 compared to the pro?
T-Sal
gashuffer is offline   Reply With Quote
Old 01-15-2010, 01:37 PM   #1887
gsxr0311's Avatar
cool. i almost cut it also.
Old 01-15-2010, 01:39 PM   #1888
gsxr0311's Avatar
here is a pic so everybody knows what were talking about.
Old 01-15-2010, 01:40 PM   #1889
I already own the Pro so I took the cheap way out and just got the body parts kit. I would imagine it's not as stiff, just a guess though!
Old 01-15-2010, 01:43 PM   #1890
GOOD DEAL. I didn't even know there was one for the Pro! This WILL help out immencely...
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 08:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 03:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 06:59 PM
SEO by vBSEO 3.5.0
