Like Tree4Likes
Old 01-13-2010, 10:42 AM   #1861
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
Originally Posted by Markus View Post
who makes those wheels in the picture above?
TRG, and they're sweet too because I thought I was going to have to waite for those (special) rims.
zpmhinojosa is offline   Reply With Quote
Old 01-13-2010, 10:55 AM   #1862
Originally Posted by Barry White View Post
Can anyone owning the F60 show how the front wheel covers are mounted, also the size of the screw holding it down?
I hope this works???
3x6mm screws
Old 01-13-2010, 04:04 PM   #1863
Sauber F1's Avatar
New to this hobby, I purchased a F103 RM and this F104 Pro. Since I love F1 cars.
The F103 became the Sauber C12 while I used the F104 as a BMW Sauber F1.07 driven by R. Kubica.
The F104 is out of the box except for the Tamiya rubber tires which I use right now for photo ops.
I posted a few more pictures in the in the F1 topic.
1/10 R/C F1's...Pics, Discussions, Whatever...
Roland
Sauber F1 is offline   Reply With Quote
Old 01-13-2010, 07:35 PM   #1864
Arahawak's Avatar
Trader Rating: 32 (100%+)
Originally Posted by jonest View Post
That's what I did but the car tends to swerve to left whenever full throttle... I gotta slip the diff a lil bit then this problem goes away....thou the diff is slip, the speed is still ok.... oh btw, I'm using ceramic ball.
If you have done the diff properly, it shouldn't behave like that. More likely something is binding.. check if the wheels are touching something like wires or if the bearings are ok or any misaligninment to the steering rods, knuckles..
I really dun think its the diff..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 01-13-2010, 08:33 PM   #1865
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
+1
Sounds like a diff assembly issue.
The right wheel is driving more than the left.
Old 01-13-2010, 09:07 PM   #1866
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Originally Posted by RedBullFiXX View Post
+1
I suffered from this recently - check that the screw that holds the diff assembly to the rear shaft is nice and tight. In my case, it has a tendency to loosen if you're not careful.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 01-13-2010, 09:51 PM   #1867
Arahawak's Avatar
Especially on carbon shafts which is why i changed to the original steel ones..
Old 01-13-2010, 10:04 PM   #1868
old-man's Avatar
Could be also caused by the wires from the ESC to motor hanging up the rear pod.
Post a picture here of the rear assembly. Picture tells a million stories.
old-man is offline   Reply With Quote
Old 01-13-2010, 10:48 PM   #1869
Default Progress
F60 in the works....
Old 01-13-2010, 10:55 PM   #1870
Default Progress cont...
Old 01-14-2010, 01:28 AM   #1871
WheelNut's Avatar
Send a message via MSN to WheelNut
Wow, the F60 wings are huge! The rear one looks especially large with the body off. Those two helmets look wicked as well.
I think I just might have to order an F60 body set tomorrow. As well as a set of rubber tires. Won't have to worry about chunking then.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 01-14-2010, 10:03 AM   #1872
Thanks, I plan to take my time on this one. When I get back on it, I might spend 3 straight days, but I'll take my time.... LOL.
Old 01-14-2010, 11:35 AM   #1873
Default Front Tire and wheel width
Hi Guys,
Newbie here to the F1 world. I'm building my F104pro right now.
Question: Why are the foam tires not as wide as the plastic wheel? Anybody have this issue? My front plastic wheels are about 1/8" wider than the foam tire when mounted. Looks pretty cheesy.
The rear wheels and tires are perfectly flush when mounted.
vonjet is offline   Reply With Quote
Old 01-14-2010, 12:47 PM   #1874
WheelNut's Avatar
vonjet- I noticed the same thing when I built my car last week and I was a bit put off by it, but apparently that's just the way it is. If I had to guess I would say that maybe Tamiya made a change to the tire width after they finished the molds for the wheels. Perhaps they found that the handling balance of the car needed changing.
•Brad Comis
Old 01-14-2010, 01:26 PM   #1875
How tight u guys lock ur diff? I can't lock it tight, otherwise the car will swerve to left side when I throttle fully... I have to loosen the diff to counter the problem.... any1?
This is likely not a diff issue but a rear axle issue. When you tighten the set screw on the non-diff side hub you want a slight amount of play in the axle. Typically in pan cars we slip a piece of paper between the spacer/shim and the bearing when tightening down the hub then remove it after. This gives you the right amount of play in the rear axle. Because the diff is on one side of the rear axle bearings if the axle is too tight it will cause the diff to give uneven amounts of power to the left and right wheel.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
