Like Tree1Likes
Old 12-25-2009, 04:43 PM   #1711
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default F-104 Pro 17.5 1S
Something a little different...
Old 12-25-2009, 06:18 PM   #1712
Sauber F1's Avatar
This looks great. With that thin appearnce, somebody should produce old F1 bodies like a Lotus 49, Ferrari 312, or even cars from the 70s.
As a newby, what battery are you using?
Roland
Sauber F1 is offline   Reply With Quote
Old 12-25-2009, 06:21 PM   #1713
Question that may have been answered already. The F104 comes with foam tires and I know there is rubber but I personally think that the foams will work better to the most part. What are you guys using to true the tires down after they are mounted? What arbor or is there another one that works?
xspower is offline   Reply With Quote
Old 12-25-2009, 06:45 PM   #1714
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
I have the arbor that ddrive sells, I cant remember who makes it, but it works for 103 and 104 wheels
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 12-25-2009, 07:27 PM   #1715
robk's Avatar
Trader Rating: 22 (100%+)
Eagle makes the Ddrive unit I believe, but TRG has one as well I think.
Old 12-25-2009, 09:39 PM   #1716
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
Are those F104 wheels/tires?
akura2 is offline   Reply With Quote
Old 12-26-2009, 02:57 AM   #1717
aussierevo's Avatar
Trader Rating: 14 (100%+)
Finally was able to have a run with the tamiya rubber tyres for the F104.
I've run the car in the past with foams at my local outdoor low to med grip track with the formula tuned motor. While the setup is far from perfect, I've been able to run 19.2's and do 18 laps while using tire compound on the rear only. Many of the local racers have been surprised by it's performance as they feel foams are better for this car.
Ran tonight with no changes to the car other then rubber all round, and was able to in the first heat run 19 laps and 18.4' while using tyre grip.
The car was very loose for the first couple of laps, but then ran quite nice after the tire grip came in to play.
In the second heat, I again had trouble in the first handful of laps with rear grip. Was able to run 18.5' and again the car performance ok.
I had hoped to run again without using any additive, but alais, the clouds opened and the night of racing came to an end.
I will next weekend give them another go and try various amounts of additive and make some set-up changes, but the comments from a couple of drivers afterwards was positive to say the least.....a good start in my book.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 12-26-2009, 04:12 AM   #1718
NiMo's Avatar
RedBullFixx
That looks like a 1s set up?
What size motor?
And how does it perform with the different weight balance?
NiMo is offline   Reply With Quote
Old 12-26-2009, 08:41 AM   #1719
Oortael's Avatar
Originally Posted by aussierevo View Post
Finally was able to have a run with the tamiya rubber tyres for the F104. [...] I will next weekend give them another go and try various amounts of additive and make some set-up changes, but the comments from a couple of drivers afterwards was positive to say the least.....a good start in my book.
Do you remember how hot it was today. On my homeplace air temperature gets seldomly over 25 degree Celsius (77 degree fahrenheit).
I might get more grip with the rubber tires if it's "cold".
Oortael is offline   Reply With Quote
Old 12-26-2009, 12:31 PM   #1720
Blueman Austria's Avatar
Hy there!
Is it possible to fit a F104 pro Body on a F103?
I think if you only cut out the body (without the sitd cooler parts) the battery should fit.
But fit the front wing?
Greets Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 12-26-2009, 01:22 PM   #1721
aussierevo's Avatar
The temperture when i ran was 25 degress Celsius, with humity of 85-90%. It was very overcast most of the day here in our local area.
I'm told had I warmed the tyres up in tyres warmers, that would have helped stop the skating around I got for the first 3-4 laps while the tyre additive kicked in.
Speed Passion F1.
Old 12-26-2009, 01:50 PM   #1722
Thanks I will try to locate one.
Old 12-26-2009, 03:51 PM   #1723
Hi,
I wanted to ask if this battery will fit in the car: http://www.rcplanet.com/Reedy_5000mA...o_p/asc709.htm
fishymamba is offline   Reply With Quote
Old 12-26-2009, 06:45 PM   #1724
avs
avs's Avatar
where did the tbar go? it doesn't seem like there is enough space below the battery
Tony Shimko
avs is offline   Reply With Quote
Old 12-26-2009, 07:56 PM   #1725
dildil's Avatar
My f104, work in progress, NIGHT RACER
dildil is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
