Old 12-15-2009, 12:49 AM   #1681
Originally Posted by timmig View Post
At the KO Propo race at Westcoast RC Raceway here in Calif this past weekend- the 104 cars were the equal of the fastest 103 cars.
The top F103's weren't performing at their full potential, they were battling with too much traction on the front wheels. It was tricky not to traction roll. This track was perfect for F104's, the traction was high enough where off power push wasn't an issue.
If Tim's car had less bite on the fronts, he would have put a severe beat down on the whole field.
DirtyRacer is offline   Reply With Quote
Old 12-15-2009, 08:59 AM   #1682
kyle3333's Avatar
Questions?? What electronics are commonly used with this Car?
What electronics are commonly used with this car without having to modify the chassis or the body? I was hoping to fit an LRP SXX in this thing. Also, what lipo batteries fit the chassis?
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 12-15-2009, 09:13 AM   #1683
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Just look back a few pages, pictures and all.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 12-16-2009, 05:53 AM   #1684
clittle's Avatar
Default Should I be concerned.
I've just finished building my F104 Pro, put the electronics in and I'm going to go and run it any day soon. Happy times.
Now, I have a question. I have mounted the kit body and I have noticed that the back of the body is higher than the start of the wing? (I've currently mounted the wing at the "technical track" setting from the manual). Should I be concerned about this? Am I losing downforce with this?
Again, I haven't run it but It's just something I've noticed. Anyone have any thoughts on this? Cheers.
clittle is offline   Reply With Quote
Old 12-16-2009, 10:39 AM   #1685
toybreaker's Avatar
I personally use the Spektrum receiver, s3100 i think and the Tekin RS Pro ESC. all are pretty small so they fit well. for the servo i use a normal size servo. it all fits well.
Rob Barrett
RnC Photography - www.rncfoto.com
toybreaker is offline   Reply With Quote
Old 12-16-2009, 10:42 AM   #1686
toybreaker's Avatar
Check your wiring, that is usually what holds it up. On mine i pin the body at the 3rd hole down on the rear posts. That places it right at the level of the technical setting on the wing. I am with you, with the body up it has to make the air around the wing act not normal. after seeing how effected onroad cars are by the body i have to think it would cause an issue or at least not the desired amount of downforce that setting can provide. Wish i had a little wind tunnel, i would test it.
Rob Barrett
Old 12-16-2009, 11:13 PM   #1687
doriftu's Avatar
beside the alu motor mount, what other parts do I need?
what about tires? should i go rubber or foam route?
im new to direct drive...
thanks
six-shifter.blogspot.com
supercharged-e36.blogspot.com
doriftu is offline   Reply With Quote
Old 12-16-2009, 11:33 PM   #1688
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
Mine's simular, Traxxas rec., Tekin Fx, normal servo. I agree, all fits awsome.
zpmhinojosa is offline   Reply With Quote
Old 12-16-2009, 11:38 PM   #1689
thanks
Your kit foams might be good on carpet, but on road even with sauce they're junk. If you're on road you might want to throw some rubber on the back. Or slap some 103 foams on, they're wider. You might hook then. You'll more than likely run foams all day up front, the 104 sweet due to the adjustable susp. You could run foams to the rims! LOL.
Old 12-17-2009, 03:33 AM   #1690
Oortael's Avatar
Has anybody tried the new rubber tires (#51400 and #51399) on a parking lot?
I'm not sure if I get more grip instead of the foam tires.
Oortael is offline   Reply With Quote
Old 12-17-2009, 03:58 AM   #1691
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Got some on order to try at my home track (medium grip asphalt). However, with the warmer weather here down under now, I'm finding the Tamiya B foams to work pretty well. The seasons might delay my testing, but I'm hoping the rubber ones might help on the cooler evening meets where the foams really struggle.
Here's a clip of one of the F1's (F201) circulating at the track. It's a good social class in our club, so there's a variety of car/motor combinations.
Switched back to the stock T-bar (from the soft one) recently and dropped about another .5 seconds off each lap. Tyre wear on the front seems a bit better too.
One of the local suppliers is getting stock of some Spice foams, so will look to try those too.
Phil.
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 12-17-2009, 05:26 AM   #1692
clittle's Avatar
Thanks for your reply. I've managed to squeeze it down to the 4th hole. It's tight, but from sighting it, the air flow should be ok. (I'm guessing)....
Old 12-17-2009, 12:46 PM   #1693
RC MARKET's Avatar
Arrived Ferrari F60 Nice body !
RC MARKET is offline   Reply With Quote
Old 12-17-2009, 08:29 PM   #1694
COuld you post the link? I was on that site and did not see it.
Old 12-17-2009, 09:33 PM   #1695
MaxSp97's Avatar
The F60 kit.
http://rcmarket.com.hk/product_info....vmv4rtia78rv96
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
