Like Tree1Likes
Old 12-09-2009, 03:32 AM   #1636
Just collected my F60 Birthday gift..
Ben.C is offline   Reply With Quote
Old 12-09-2009, 07:17 AM   #1637
Arahawak's Avatar
Trader Rating: 32 (100%+)
picture!!
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 12-09-2009, 11:34 AM   #1638
Originally Posted by Arahawak View Post
picture!!
Lazy to build ...!!!
Old 12-09-2009, 12:53 PM   #1639
forum fodder's Avatar
Massive favour please. Could you measure the wheels for me. I am trying to find out if the HPI 'Bridgestone' tyres will fit them.
forum fodder is offline   Reply With Quote
Old 12-09-2009, 02:53 PM   #1640
ckaspar's Avatar
Hey guys, I just picked up a 104 and I am having an issue with stripping spur gears. I have mashed 2 of them now. It appears the motor keeps moving. I have wrenched the motor screws down as hard as I can but it still seems to move enough to strip.
I am using the plastic bulkhead and have the the aluminum bracket on the outside. The spur seems a little "wobbly" in the diff. Is that normal? What can I do to stop stripping spur gears?
Thanks in advance.
Chris Kaspar
West Coast R/C Raceway and Hobby Garage--www.westcoastrcraceway.com
RnCPhotography--www.rncfoto.com
ckaspar is offline   Reply With Quote
Old 12-09-2009, 03:04 PM   #1641
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
I wanna see the parts... tires, front and rear wings...etc....
do the tires feel soft and usable or hard and toylike?
akura2 is offline   Reply With Quote
Old 12-09-2009, 04:12 PM   #1642
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
Thanks in advance.
I'm not sure why I keep reading about stripped gears, but here's what I know.
The "wobbles" are normal, what I've done was fine tune that inner nut. Not too tight, but enough to minimize my "wobble". To insure I did just that, I press against the spur gear, give the motor a little gas and just repeat pressing until you see it straighten out. I have my wheele off for all these tests. Next is my pressure between the spur gear & the pinion. I was taught that you only need like .005 in between gears. Press your trigger & you should hear just a fine hum (not from your motor). Fine tune that by just snuggin down the first motor bolt, Leaving the top bolt loose you should easily be able to move back n forth the motor, hence, fine tuning your gap between gears. Once you got your desired hum & bite (tire wise), just tighten up that top bolt, follow through with that second, DONE. Follow?
With this you should'nt have any issues. I'm still running my kit spur gears. I just follow the above EVERY TIME I get done running. In fact, my opinion is I'm just warmming 'em up, cause now I'm a true contender, just carvin my lines and have'nt even thought about burnin my gears. So I hope this helps my brotha F104er.
zpmhinojosa is offline   Reply With Quote
Old 12-09-2009, 05:11 PM   #1643
Trader Rating: 35 (100%+)
I haven't had any spur gear issues with my F104. I never used the plastic motor mount, so that may make a difference.
To get a good mesh between the spur and the pinion, some people place a piece of paper between the two, then tighten down the motor.
Geppetto is offline   Reply With Quote
Old 12-09-2009, 06:49 PM   #1644
MaxSp97's Avatar
Default F104 with 1S Lipo
Here are the pictures of my F104 with 1S Lipo...
Next is 13.5 or 10.5
Tamiya F104 Pro!-dsc00579.jpg   Tamiya F104 Pro!-dsc00580.jpg   Tamiya F104 Pro!-dsc00581.jpg   Tamiya F104 Pro!-dsc00582.jpg
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 12-09-2009, 07:02 PM   #1645
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Ooooh, where'd you get that!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 12-09-2009, 08:27 PM   #1646
Casey's Avatar
I seem to have accidently purchased an open wheel car as well.... Mr Sharpe.... Game On ! Old School Xipp style blue and white !
Casey is offline   Reply With Quote
Old 12-09-2009, 08:32 PM   #1647
There's nothing accidental about you purchasing Tamiya cars.
Old 12-09-2009, 10:57 PM   #1648
forum fodder: Front and Rear diameter 42.5mm, fronts are 30mm wide, rear are 35mm wide. Not sure whether they are a fit for the HPI. I've not seen them before.
akura2: Parts are like the normal 103 kits. Fibre chassis top & bottom. Plastics are like from the F104Pro. Tires wont give you the best grip, compound feels like those from the stock TA05 tires. But for bashing around, they are ok. Lets wait for the type A & Bs.
Greg Sharpe: Got it from the Singapore distributor.
Definitely a kit for the Ferrari fan.
Oh and some pics for your enjoyment.
Old 12-10-2009, 04:19 AM   #1649
Thanks for that. I have a set of the HPI Bridgestone tyres, so i can work out if they will fit from that.
Old 12-10-2009, 08:55 AM   #1650
ckaspar's Avatar
Thanks for the tips guys. I have been doing all of that, unfortunately. Perhaps I should have also said that from time to time the motor will also move toward the spur gear and bind it up. I have run a lot of offroad and taken some big hits and never had the motor move so much. With the F104 it seems that if I even roll the car the motor moves one direction or the other and either destroys a spur or binds the mesh up so bad that I can' drive it.
I am considering getting the Aluminum bulkhead to try. I fear that the plastic one is so smooth and is has trouble providing enough friction to stop the motor from moving. All my offroad cars all had an aluminum motor mount.'
We'll see and I will let you guys know.
Thanks again.
Chris Kaspar
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Tamiya F104, HPI F10 and POPULARITY bxpitbull Electric On-Road 28 07-22-2011 07:13 AM
HPI F10 vs Tamiya F104 Pro daygoVR6 Electric On-Road 38 12-03-2010 02:19 PM
FS: Tamiya F103RM and F104 Pro! SerpentCT4S R/C Items: For Sale/Trade 42 09-12-2009 05:59 PM
