Like Tree12Likes
Old 12-18-2009, 04:02 AM   #1366
dsyed1's Avatar
Default tc setup
just started testing the new 1.32 programmer software and 091107Stock esc profile.
The following is my esc setup
ESC: SP GT 2.0 (PRO)
Software: 091107Stock
DRRS: 6
FDR: 4.53
Battery: Thunder Power 7.4v 40C
Motor: SP V3 17.5R
Track: 90~100 Foot Straight away total 100/50 foot
SP ESC Timing: 26.5
Motor Timing: Max
Drag Brake: 10%
The car is running great and I am getting decent laptimes, please note the track still has the layout from the recent NEGS race.. I am happy with the esc setup/gearing etc however still need to work out the car setup..
dsyed1 is offline   Reply With Quote
Old 12-18-2009, 05:52 AM   #1367
Redwood's Avatar
Originally Posted by Stein Tumert View Post
You can get it from Toni
http://www.speedpassion-europe.de/
Thanks, I tried that though, they cannot sell to UK since they don't want to step on the toes of Schumacher who distribute SP in the UK.
I am currently happy with my Hobbywing box, but I appreciate the help.
regards
Neal
Redwood is offline   Reply With Quote
Old 12-18-2009, 09:43 PM   #1368
Trader Rating: 8 (90%+)
So the message I am getting is that this esc is now capable to have a timing increase with a new download and to get this download you have to have the previous 312? I am anxious to run this new profile in my F1 and WGT. Also what is the RPM of a stamped black can 13.5?
Houston,Texas
Serpent 733 EVO
Mikes Hobby shop-Porter Texas/ Gulf coast Raceway"Electric Is For Hairdryers"..Eric Koger
Chris Totcky@facebook.com
Tha Skinny is offline   Reply With Quote
Old 12-19-2009, 01:06 AM   #1369
razzor's Avatar
what is the difference between the 110stock and 107stock software as well as the 731c_t ?
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 12-19-2009, 02:51 AM   #1370
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I know this is a stupid question but does SP have a trade up policy? Like trade in your V1.1 with some cash to get the GT2.0?
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 12-19-2009, 03:30 AM   #1371
Stein Tumert's Avatar
regards
Neal
I am sure Daniel at RC Car Shop will send one to you
http://www.rccarshop.ch/
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-19-2009, 05:09 AM   #1372
AGNO's Avatar
Originally Posted by abailey21 View Post
No, one is the Speed Passion box, and one is the Hobbywing box?
But I've seen update ESC speedpassion With LCD Box Hobbywing ...
AGNO is offline   Reply With Quote
Old 12-19-2009, 08:26 PM   #1373
RTR canada's Avatar
Does anyone know why you cant adjust some of the settings when using the latest program?
RTR canada is offline   Reply With Quote
Old 12-19-2009, 09:00 PM   #1374
Houston,Texas
Serpent 733 EVO
Old 12-21-2009, 01:31 AM   #1375
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Just to be sure, rotors from v2 can they be used with v3 motors?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 12-21-2009, 02:13 AM   #1376
lastsun's Avatar
can anyone here provide the ESC softwares that are available for the GT2 PRO for stock spec or 11.5T motor
Serpent 966 EVO / OS MAX
lastsun is offline   Reply With Quote
Old 12-21-2009, 04:12 AM   #1377
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
I use the Turnigy LCD program box from hobby city, same as hobby wing, same as speed passion. Works no problem with the SP speedy.
mild seven is offline   Reply With Quote
Old 12-21-2009, 05:38 AM   #1378
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Had a good weekend with speed passion ESCs. can't say the same for the other brand motors I was running, had 2 21.5 fail.
Guess its time for some speed passion ones! LOL
As a side question that probably could apply to any motors, what would cause a motor to not rotate unless you gave it alittle push? Also, this motor would rotate if I turned off my transmitter and it went into fail safe mode on the spektrum receiver (setup in correctly to "go forward"). no issues on ESC, tried with a different motor, worked fine.
And another general motor tech question, what would cause a motor to sound like its "whirring" up, sort of like when as a kid you put little plastic strips in your wheel spokes on your bike. Just not as loud.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-21-2009, 05:56 AM   #1379
TryHard's Avatar
Yup, they use the same rotor, Purple ring, 12.3mm outer diameter with a 7mm core.
I've been using a Red ring rotor recently in club races (12.5mm outer, 5mm inner... so more magnet volume ). Lots of extra grunt, just need to gear up a couple of teeth to make it work best.
Anyway, just got back from my first running with the new stock software. Started out running the 110, before switching to the 107 later in the day. If anything, I prefered the 110 version, but need to do a bit more experiementing I think. There is a noticeable increase in revs over the 312 software I was using before, so had geared down quite a bit over previous
Unfortuantly, I had to drop back to a v2 motor, as my v3 10.5 had a problem with the sensor board plug vibrating itself loose... and the speedo then dropping into sensorless mode. But even then the car felt good, but could have done with the extra revs of the v3 for a bit more top end.
Anyway, settings...
Drag Brake; 5%
Low Voltage; 3.0v/cell
AMTS Timing; 26.25
Start Mode DRRS; Level IX
Max Brake; 100%
Initial Brake; Drag Brake
Neutral Range; 6%
Overheat protection; disabled
Motor; Speed Passion v2 10.5t (purple/12.3mm rotor)
FDR; 5.9 - 6.0
Overall, very impressed...
Ed
Old 12-21-2009, 06:17 AM   #1380
abailey21's Avatar
Trader Rating: 36 (100%+)
Depends on your ESC settings, I've seen ranges between 36,000 and 72,000
Only the stockers, the V2 mod rotors have fans that wont fit the V3 mods
All of them?
what settings can't you adjust?
OK????
K.C.C.O.
abailey21 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
