Old 12-14-2009, 09:48 PM   #1321
Trader Rating: 22 (100%+)
Originally Posted by 29TC View Post
Anyone using the Speed Passion V3 motors, feeling under powered compared to other similar turn motors?
A am running 11.5T SP V3 with SP 2.0 esc. All settings at max and gearing down to 4.4 FDR. But still slow compared to ORCA & Team Powers 11.5T motors.
Tried adjusting motor timing to max.....did not feel any increase in rpm or power??
Anyone have any feedback or advise to squeeze more juice out of the V3 motor?
Only thing great about the motor is the wiring plugs and damn the motor runs way cool.
Shim the rotor closer to the sensors
bjspinner is offline   Reply With Quote
Old 12-14-2009, 09:53 PM   #1322
29TC's Avatar
Send a message via ICQ to 29TC
Thanks for the tip.
29TC is offline   Reply With Quote
Old 12-14-2009, 09:59 PM   #1323
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Runs cool...Gear up!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 12-14-2009, 10:08 PM   #1324
tom_chang79's Avatar
Thumbs up
Originally Posted by Solara View Post
Yes...more timing increase RPM, however, that will decrease the torque. Like a power screwdriver, you want to turn it to SLOW (low RPM) to drive a screw into a stud wall, same idea....
You cannot have BOTH at their peak...but you can have both with average power, its about balance...you can have high speed on the straight but losing torque at the turns. Or you can have punch on the infield and OK speed on the staight...for me, I would choose the 2nd choice...each track has more turns then the straight, INFIELD speed makes fast lap time, not the straight line speed...
Well-stated... However, I consider the straights "car breaker."
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-15-2009, 03:16 AM   #1325
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Why is this beneficial?
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 12-15-2009, 03:38 AM   #1326
29TC's Avatar
I don't think i can gear up anymore. If i do, my acceleration out of corners will suffer. Besides 4.4 FDR i feel is way too much. It's in the rage of 13.5T motors gearing. Right now I really need some RPM on the straights.
Old 12-15-2009, 04:26 AM   #1327
Cribbin's Avatar
just try it, these motors have incredible torque, i started my 10.5 at 33mm and ended up at 40mm and it still doesnt get hot. it has heaps of rip and is a gun down the straight. they need to be geared waaaay higher than any other motor
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 12-15-2009, 06:36 AM   #1328
asw7576's Avatar
I don't see "the science" more rpm is being generated when the rotor closer to the sensor.
But you have nice tips to follow though ..... I will shim the rotor closer to sensor on the next rebuild.
Old 12-15-2009, 06:41 AM   #1329
asw7576's Avatar
Who use Speed Passion motor with Novak GTB ?? Is it working ??
Old 12-15-2009, 08:57 AM   #1330
Solara's Avatar
Trader Rating: 16 (100%+)
I think you are overgeared.....even the motor is still cool, but I really think 4.4 is too high for 11.5.
Also, what version of software are you using...? You should use 323a...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-15-2009, 09:06 AM   #1331
cyanyde's Avatar
Check if the sensors are working or not. My V3 arrived with dead sensors. If they are working, any timing advance will increase revs.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 12-15-2009, 09:28 AM   #1332
seaball's Avatar
Send a message via Yahoo to seaball
i did until i geared up (11 teeth from my duo) on a 13.5. i run the sp-lpf and i ran a 4.24 ratio on a 90 ft indoor track. tons or torque, but no revs. i think i was coming off at 165*F or thereabouts.
i ran two v3 motors, a duo, and a novak. all provided identical lap times at the NEGS race this past weekend. in the end, i liked the sp because it ran cooler. on larger tracks, it may have issues if you're not using an esc that revs late ... but so far, so good.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-15-2009, 10:19 PM   #1333
29TC's Avatar
I am running 323a..T
I started FDR at 5.2...no speed on the straights. So went down tooth by tooth until 4.4 with good punch and decent speed but still not enough to keep up the the other 11.5T with turbo escs.
The motor temp highest was 145F !!! Thats still pretty cool!!
Well, this weekend will try shimming the rotor closer to the sensor then i'll gear even higher...gonna squeeze every ounce of juice out of the V3.
Old 12-15-2009, 11:35 PM   #1334
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
turbo escs..
the key words....
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 12-16-2009, 05:21 AM   #1335
kschu's Avatar
Send a message via MSN to kschu
Originally Posted by alana07 View Post
the key words....
Give the best while u can !
kschu is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
SEO by vBSEO 3.5.0
