Old 12-10-2009, 04:22 PM   #1306
J@UNE's Avatar
Originally Posted by J@UNE View Post
I Rebinded the esc, start a new model on radio to make sure. everything is at 100%
When I hit Fullthrottle, I get a green and red light but the car doesnt move. I have to hit reverse and quicly go foward to make it start... Can it just be that the esc is about to die?
I checked the sensore wire, also switch to a novak motor and samething. But I found that with the sensor wire unpluged, it launch every time. a lot of cogging at low speed but it always respond to the trigger... Any ideas?
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 12-10-2009, 06:15 PM   #1307
big_alex39301's Avatar
Default Setup Help for new racer
Hi, I'm new to racing and I was wondering if someone could give me a little advice. I am running an Xray T2 with a transmission ratio of 1.7, with a 108 spur. Racing in a 17.5 class on carpet track with rubber tires. Have a Speed Passion LPF 2.0 ESC. Any ideas on what size pinion gear I need and what settings I should run in the ESC (timing, punch, etc.). I have not adjusted the timimg in the motor. The motor is a Vector X12 from LRP. I would appreciate any help. Thanks.
big_alex39301 is offline   Reply With Quote
Old 12-10-2009, 07:28 PM   #1308
Sigearhead's Avatar
Trader Rating: 68 (100%+)
How does the 17.5 V3 compare to the Duo2 or the Ballistic? thanks
Sigearhead is offline   Reply With Quote
Old 12-10-2009, 08:00 PM   #1309
What FDR is recomended by LRP for that motor? Take that info and go to gearchart.com and you can decide on a pinion. As far as the ESC if you can download the 312A software, you need too. If not timing up on 8-9 and the same for start power, only run 2-3 minutes and check temps. Leave the motor timing alone for now. With FDR's heading the opposite direction you might be OK with 108 spur. Let us know how things turn out.
Tim
TS racing
got2bqik is offline   Reply With Quote
Old 12-13-2009, 11:59 AM   #1310
Trader Rating: 66 (100%+)
Default Software updates
Does anybody know when the software updates for the esc will be back up on the SP website, I bought the LCD programmer Thursday and have not been able to use it yet . Hopefully I can get something before I race again this thursday night.
Gwoodrc is offline   Reply With Quote
Old 12-13-2009, 02:29 PM   #1311
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Hi,
go The Speed Passion Thread you can get the latest software
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
nnick is offline   Reply With Quote
Old 12-13-2009, 03:08 PM   #1312
razzor's Avatar
You could also download the Hobbywing software which has the same esc setup.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 12-13-2009, 11:32 PM   #1313
Dustin's Avatar
Trader Rating: 111 (100%+)
Adam or Shawn- can you post what the different software versions are for?
Dustin Thompson
HB Racing
AKA Racing
Dustin is offline   Reply With Quote
Old 12-14-2009, 03:23 AM   #1314
asw7576's Avatar
Would 13mm rotor increase power ? ... is it more top speed or acceleration ?
[ The stock rotor is 12.3mm ]
Old 12-14-2009, 05:09 AM   #1315
mr crum's Avatar
Send a message via Yahoo to mr crum
if im correct its more torque more rotqating mass equals more torque
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 12-14-2009, 05:29 AM   #1316
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
I did some testing this weekend with the x12 stock spec motor from LRP...
I know a speed passion thread, but anyways, the motor was very difficult at first. But it's going to be a very good motor...
In the main I finally got my fast lap to .1 slower then I had turn in a previous weeks at the track.
but the biggest difference is the fact I have few more teeth I can go up on the motor. It recommends 210* degrees in the manual. At the end of the 6 minute A-main the motor was 138. Fast lap was a 8.4 (small track)
I was running a Duo2 with timing at 8 and the punch was maxxed out , and after the race it was temping at 187*. I found out you can not run the GT2.0 at max timing (26.75? I think)with the stock spec motor. I am running at the 22* (number 7) and the DRRS is maxxed out and right now. I'm at 4.43 on a 68x36 track.
LRP recommends 4.0 they are pretty much right on...
I'm also running a fan on the motor as well... hopefully that will help
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 12-14-2009, 01:40 PM   #1317
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Default Bearing Replacement
I am wanting to replace my bearings in my motor. What tool are you guys using to get the bearings out?
Thanks!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-14-2009, 01:47 PM   #1318
Solara's Avatar
Trader Rating: 16 (100%+)
It has more torque...less RPM. May be is a good rotor to use for very small tight track. I mean, very small track....
P.S...btw, I am not sure 13mm is nowl legal to race or not, it wasn't.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-14-2009, 07:56 PM   #1319
mr crum's Avatar
Thanks!
i use a craftsman socket that just fits in the hole set the endbell in a tc tire and tap gently with a small hammer
TEAM B.R. RACING
Old 12-14-2009, 08:17 PM   #1320
29TC's Avatar
Send a message via ICQ to 29TC
Anyone using the Speed Passion V3 motors, feeling under powered compared to other similar turn motors?
A am running 11.5T SP V3 with SP 2.0 esc. All settings at max and gearing down to 4.4 FDR. But still slow compared to ORCA & Team Powers 11.5T motors.
Tried adjusting motor timing to max.....did not feel any increase in rpm or power??
Anyone have any feedback or advise to squeeze more juice out of the V3 motor?
Only thing great about the motor is the wiring plugs and damn the motor runs way cool.
29TC is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
