Old 01-28-2015, 06:47 PM   #12826
prosport's Avatar
Trader Rating: 21 (100%+)
Originally Posted by prosport View Post
The fan broke on my speed passion GT2.0Pro esc, will part/sku number spoo1130 work on this esc? I believe this part number is a 13mm fan.
Here's the link.....http://shop.speedpowerrc.com/revento...m-cooling-fan/
It's a Speed Passion part number, just not sure if it will work on my GT2.0Pro?
prosport is offline   Reply With Quote
Old 01-28-2015, 07:02 PM   #12827
Trader Rating: 36 (100%+)
The 30mm is for the Reventon line of ESCs. The GTs used a 25mm... http://shop.speedpowerrc.com/esc-sta...ling-fan-25mm/
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-29-2015, 08:56 AM   #12828
prosport's Avatar
Ok thanks!
Old 02-06-2015, 06:57 PM   #12829
Speed Passion's Avatar
Greetings,
Can someone advise what is the best default setting Mod0, Mod1, etc for a 6.5R turn motor with a Reventon R ESC? Wont be for racing just high speed runs. Will be in a Sakuka XI with a 84 Spur and a 22 pinion. 60mm dimeter tires, 2S lipo.
Thank you kindly.
Speed Passion is offline   Reply With Quote
Old 02-16-2015, 03:34 AM   #12830
Questions?? gt2 lpf with turbo software
Hello all,
I have a speed passion gt2 lpf, hobbywing 120a v2.1 and a hobbywing lcd program card with v2.1 software installed.
I want to be able to flash the gt2 lpf with turbo software using the lcd card (and therefore tuning with it aswell) while still being able to use the card with the hobbywing 120a v2.1 at the same time. If needed i am happy to update the hobbywing stuff to the v3.0 from v2.1
Ideally if it could be done I would want them to both run hobbywing v2.1 or v3.0 software.
they will both be coupled to 13.5t motors one being in a 2wd and one in a 4wd
Thanks for any help.
carmad man is offline   Reply With Quote
Old 02-16-2015, 10:09 AM   #12831
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by carmad man View Post
Hello all,
I have never try this but by theory, it should work this way...
Update the GT2 LPF esc to the 205g software first (Must do).
Update the LCD card to the Hobbywing latest software.
Load the GT2 LPF esc to the software that you want to have turbo.
However, once it is loaded to HW version, you will not be able to load the Speed Passion version anymore. It is not reversible.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 02-16-2015, 12:36 PM   #12832
Thankyou for the quick reply.
That is the best case scenario for me.
But would I have to change the hobbywing card to speed passion software to update it to 205g? (and then of course change it back)
And also would I be able to update it from the version it would then be on to a newer version when/ if it comes out?
Thanks again.
Old 02-16-2015, 05:06 PM   #12833
EDWARD2003's Avatar
Have you checked out the Tags posted at the bottom of this forum.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-17-2015, 12:35 PM   #12834
Thumbs up
Poor customer service!!
Speed passion has the best customer service ever. My original gt2 lpf went through lots of abuse and ended when it got soaked in water more than a year after I brought it, I sent it back expecting to pay a fair bit of money for it to be fixed but it came back a few weeks later without paying a penny; and now they are telling me how to modify my speedo to use different software!
5 Star For Speed Passion Customer Service
Old 02-22-2015, 09:25 AM   #12835
I finaly got around to updating my esc a few minutes ago and it is so much better.
Thanks for all the help
Old 02-22-2015, 06:27 PM   #12836
Default LCD PROGRAM BOX
Is it intended to tell you the ESC and motor temp? I know mine is not working because after a 6min main it read 60 degrees F. Any feedback?
astgerma52sp is offline   Reply With Quote
Old 02-23-2015, 09:38 AM   #12837
V4 spec motors are now in stock and available!
http://shop.speedpowerrc.com/competition-v4-0/
We've had a lot of our top spec drivers testing them in 17.5 2wd buggy, shortcourse, 13.5 wheeler, USGT, TC, and all the other spec classes. Everyone has given positive feedback and noted they run faster with less heat than other motors they were running.
Old 02-24-2015, 08:06 PM   #12838
Hi I'm a new at this so please forgive me I have a speed passion reventon s that I put in my zx-6 with a reedy 13.5. I was checking out my settings on the car and it was moving around then it stopped the steering servo worked. So when I walked to retrieve the car I found that the red wire to the capacitor was off. I soldered the wire back on but still no go the led's were on nothing blinking. So my question is do you guys think my esc is toast?
Chitenator is offline   Reply With Quote
Old 02-25-2015, 01:31 PM   #12839
Did you smell smoke? The capacitor wire being off wouldn't really damage the ESC if you were just setting it up or even running some laps. Now if it was able to touch somehow and arc across the neg/pos it could cause problems.
If you didn't smell smoke or it doesn't smell burnt try reloading everything by hooking it up to the PC. Then use the Speed Passion software to load new firmware.
Old 02-27-2015, 08:58 PM   #12840
The Stig US's Avatar
I am having a problem with my Reventon Pro 1.0. I don't know why but I seem to have lost Blinky mode. I hooked the program box up and tried resetting it, but I still have no blinky led's. I also tried resetting my end points thinking it may be a neutral issue. Any help to get me back into blinky would be much appreciated.
The Stig US is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
