Like Tree12Likes
Old 09-16-2014, 07:38 AM   #12691
Electr0n's Avatar
Originally Posted by asw7576 View Post
I have a question.
I have Reventon Pro 1.1 ... I bought it from RC Mart Hongkong.
How to enable reverse function ?
I have the program card ( transparent blue box ) .... however I cannot change the inside menu option to forward, brake, reverse.
Forward, brake, reverse function is only available in some of the available firmware's. being : Drift, Rock Crawler and Modify0 firmware.
You probably have to change the firmware first using the Software on a PC.
Andre
M-03, M-05, TB 03 (R+), TB-04 Pro (R), TT-02 S, TRF 417X, TRF 417V5, TRF 418, TRF 419, All TB EVO Chassis, TRF 414 and .....
Electr0n is offline   Reply With Quote
Old 09-16-2014, 07:47 AM   #12692
Electr0n's Avatar
Originally Posted by Zulianino View Post
Hi Guys,
i have a Reventon S with Competition 3.0S 3500kv. I know there is cogging a low speed; is there a way to fix it?
Which is the best firmware and settings to don't have cogging?
I also have used sensorless motors with the Speedpassion esc.
Found no way to get rid of the low speed cogging.
Use cheap Hobbywing clone now for my sensorless motors and it is almost gone. Also the break delay is gone, which is always present in speedpassion esc when used in combination with sensorless motors.
Andre
Old 09-16-2014, 08:06 AM   #12693
Electr0n's Avatar
Originally Posted by boudin4evr View Post
I have a new Reventon R esc and a new 17.5 V3
that I am using for drifting
My esc came with a blue box that lights up red digital numbers
can u please explain to me the drift software? What does it do? How does it perform?
Can I put drift software on my esc with the box that I have?
thanks
As far as i know ( Racer ) you can setup some other parameters in the Drift firmware. Other/"Better" throttle and brake curves that are useful for Drifters.
You should be able to update the Firmware using the PC Software and the included Smart LED Programmer Card via the included usb cable.
But with the correct gearing you can use it as it is.
Andre
Old 09-16-2014, 09:10 AM   #12694
asw7576's Avatar
Andre
Hello,
So ... I have to download new firmware ( modify 0 ) from speed passion.net .... flash it into the program card .... and flash it again into ESC .... and then I can select reverse function. Is this what you are reffering .?
Old 09-16-2014, 10:45 AM   #12695
Electr0n's Avatar
Hello,
Yes and no !
Firmware is loaded directly into the ESC from the PC Software, which includes the latest versions of the available firmwares. Settings can be set directly from the PC Software. Settings for the firmware in the ESC can then be altered later via the PC Software or via the program box without the connection to the PC.
You should not connect the ESC to any LIPO when connecting it to the PC and never disconnect the ESC while updating the firmware.
Andre
Old 09-16-2014, 03:25 PM   #12696
Mr_RCGuy's Avatar
Which car ?
I once had a shaft driven car with the diffs mounted opposite what is normal for most cars. Most sensored esc motor combinations will not work in these cars.
Andre
Helion Dominus 10SC. I have a new transmitter arriving tomorrow. I will keep you all posted.
Mr_RCGuy is offline   Reply With Quote
Old 09-16-2014, 10:51 PM   #12697
asw7576's Avatar
OK many thanks Elctr0n
Old 09-17-2014, 03:02 AM   #12698
Electr0n's Avatar
I do not think that will solve your problem.
Found these Specifications for the Helion Dominus 10SC :
> LiPo Compatibility: 2S
> Motor: 550 21T Brushed (Reverse Rotation)
> Battery: 1800mAh 8.4v High Output 7 Cell NiMH
> Gear Pitch: 32 Pitch
> Wheels: 12mm Hex (24mm OS, TRX and KYO Compatible)
> Length: 540mm (21.26in)
> Height: 215mm (8.46in)
> Width: 290mm (11.42in)
> Wheelbase: 327mm (12.87in)
> Weight (approx): 2545g (5.61lb)
> Internal Gear Ratio: 3.1:1
I think your problem is in :
>>> Motor: 550 21T Brushed (Reverse Rotation) <<<
Bought a cheap offroad once with the same problem.
Wondered why the car was slower with a modified brushed motor.
Due to timing on the endbell the Modified motor got real hot and could not run properly. Sold the car with a brushless sensorless combo.
A solution is, disconnect the sensor cable and switch the rotation direction by
switching for example the A and C wires on the motor. ( do not connect a sensor cable when the motor cables are switched because this could fry your ESC and motor )
>> edit
Attachment shows rear diff is opposite normal on/off road car position.
maybe it is possible to flip both the rear and front diff ?
<< edit
Andre
Old 09-17-2014, 04:16 AM   #12699
Mr_RCGuy's Avatar
>> edit
<< edit
Andre
Andre,
Thanks for the info. I knew about the rotation of the diff's. I ASSUMED... that since my Hobbywing and Radient ESC's worked and had cw/ccw options that the SpeedPassion would also.
The diff bodies are not interchangeable. Sounds like I will have to use sensorless mode. I did that originally, but the tech at SP said it was the transmitter. SO, I hope we (you and me) are both wrong, though I am sure we are right.
Take care,
Pete
Old 09-17-2014, 04:47 AM   #12700
Electr0n's Avatar
Andre,
Take care,
Pete
Most sensored motors incl Speedpassion, already have mechanical timing on the endbell.
Using them in reverse direction with the sensor cable attached would create the same problem i had with my brushed motor "ages" ago.
I think the cw/ccw option is a nice feature for sensorless use but not ideal for sensored use, due to this mechanical timing on most sensored motors.
Andre
Old 09-17-2014, 03:55 PM   #12701
Mr_RCGuy's Avatar
Andre
Andre,
We were correct. More you than me. The final fix was to go sensorless and swap out two of the esc to motor cables. A little bummed, but knowledge acquired. Most importantly, I can finally run it!
Thanks again,
Old 09-18-2014, 04:57 AM   #12702
can somebody help me pls! I have been trying to find the iphone reventon app but it looks like it has been taken down from the app store! also i've been trying to get the pc update software to work but sofar its been an absolute nightmare. I think the esc is superb but to ship it without reverse is such a bad idea.
does anybody know where to find the iphone app???
hiangoh is offline   Reply With Quote
Old 09-18-2014, 05:10 AM   #12703
Mr_RCGuy's Avatar
I have only seen it on the SP website.
Old 09-18-2014, 06:02 AM   #12704
yes and when you click on the app on the sp website it goes to iTunes and then says its been deleted from the app store....
Old 09-18-2014, 06:08 AM   #12705
well the mystery is solved. it is not available for iOS 7 or windows 8. ...... great hurry up and update the support pls!
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
