Like Tree8Likes
Old 05-14-2014, 08:24 PM   #12586
will the new 1.1. 25 revision work on the Reventon pro 1.0?
What does it do?
gdcopbdcop is offline   Reply With Quote
Old 05-15-2014, 03:58 AM   #12587
kwiksi's Avatar
Trader Rating: 103 (100%+)
Send a message via AIM to kwiksi
Originally Posted by Nexus View Post
In case you missed it on our Facebook page...
ETA?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - PT Racing Oils - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 05-17-2014, 10:18 AM   #12588
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by clfile View Post
I am having problem setup hybrid boost on my PC, I don't have any motor turns option under the hybrid boost page, I can't input any number of turns in the "Motor Turns" column. I can change or update the firmware but not hybrid boost option, am I missing something or did something wrong? any idea?
Sorry about this problem....I will get this fixed Monday.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 05-17-2014, 10:19 AM   #12589
Solara's Avatar
Originally Posted by kwiksi View Post
ETA?
Mod motors....ETA July....Spec stock, August.
Old 05-17-2014, 11:40 AM   #12590
Trader Rating: 14 (100%+)
just wanted to give you guys an update, after so many times remove and install, i finally get it working, I use the older Ver. PC software V1.1.0.23.5 and firmware STO1 V21-0B9E, then all the motor turns option available.
clfile is offline   Reply With Quote
Old 05-18-2014, 11:27 AM   #12591
rimracker's Avatar
Is there any benefit to using the plugs with 1/8 motors besides quick motor changes? Using the Blaze.
rimracker is offline   Reply With Quote
Old 05-18-2014, 12:14 PM   #12592
Trader Rating: 23 (100%+)
I don't see any other benefit besides quick motor changes. Any additional connection in a circuit adds resistance and reduced efficientcy. I don't use plugs or connectors personally.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is online now   Reply With Quote
Old 05-18-2014, 04:05 PM   #12593
Pittster's Avatar
Question for the speed passion Guru's
I have a Reventon R Esc and a MMM 17.5 combo in my durango Dex210 and it has done alot of race meet's.
On 3 separate occasions at about the 4 min mark in the race, the motor acts like its gone sensor-less, as in low throttle control is missing and when I stop and slowly takes off it cogs badly.
Now the 1st time I just turned the ESC off then on and it resolved it the other two times irrelevant of what I tried it would still cog.
I would go out and marshal the next race(6 min) and when I come back to my pit area to check it the car works normal.
Things I have replaced:
New sensor cable
New timing board (from red to a green)
New Rx
Checked motor ohm's measurement across winding's is even. 2-3 Ohm
Checked solder connection on ESC
So my logical conclusion is its the ESC and when it gets hot. The thing is after races its 40-50deg on a temp gun, and I have tried with a Fan and no fan.
Other possibility is the Capacitor is faulty.
Its really random as its only happened 3 times over 8 race meets.
and yesterday it did it once out of 5 races.
LED status remains the same but I run Blinky (Stock 0)also
Maybe its sensor circuit on the actual ESC. Any further diagnostics I could do and ideas would be great.
Thanks ahead of time.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Tekin Gen2 8.5
Team Associated B64D, Speed Passion Reventon Pro 1.1, Tekin Gen2 7.5
Team Associated B5M CE, Tekin Rs Gen2, Orion 17.5
Pittster is offline   Reply With Quote
Old 05-20-2014, 04:07 PM   #12594
Will the blinky setting have the option to switch to FWD/Brake/reverse? This would be great for club level and it seems strange why it's not available as a setting already. This is making guys I know not even consider the Reventon esc's as the Hobbywings / Fletas etc all allow this option to be used.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-20-2014, 07:48 PM   #12595
Solara's Avatar
Please try reinstall the V25 again....its fixed. I tested it. And the within STOCK1 is version 22, which is used by Viktor Wlick at ETS round 3 and he is using it at the REEDY RACE this weekend.
Old 05-20-2014, 07:49 PM   #12596
RacinJ's Avatar
Default Reventon 1.1 EX
Can anyone tell me the experience they've had with the Reventon 1.1 EX? Good or Bad?
So far I haven't had a very good one.
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 05-20-2014, 07:50 PM   #12597
Solara's Avatar
Sorry, we feel that using reverse on blinky mode is not the best to do on any kinda of racing environment. If you want to use reverse, you can choose to use MOD0 version and turn off all the timing. However, that does not mean it will be equal to blinky and is not legal to race on any no timing, blinky required event...
Old 05-20-2014, 08:19 PM   #12598
Hey guys, looking for ESC's for my 2wd 10.5t and 4wd 7.5t buggies. Looking at the Reventon S for 2wd and R for 4wd. Just looking for suggestions and or feedback.
Be better getting R's for both ?
Zonk is offline   Reply With Quote
Old 05-20-2014, 08:59 PM   #12599
Trader Rating: 36 (100%+)
What issues are you having. I have one in a 12R5.2 and it runs great. A lot of guys are using them in other 2s class racing because they like the black color.
Both would work well for each application. If you can afford it then why not go R for both. It has a higher amp rating and if you don't use turbo you can use a lower motor turn than 7.5.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-20-2014, 09:35 PM   #12600
Thanks for the answer. Would the 7.5t V3.0 motor be a good replacement for a very tired Novak motor in 4wd buggy ? Special rotor needed for offroad ?
Is the capacitor included ? Sorry about all the questions
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
