Like Tree12Likes
Old 04-24-2014, 05:45 PM   #12556
Default reventon s voltage cutoff failing?
I've just bought the Speed Passion Reventon S V3.0S 3500KV Combo.
Im running a 2s 5200 mah battery and i've got the voltage cutoff set to 3.4v/cell but it doesn't cutoff. ran it twice now and battery has got down to 5.8volts. Shouldn't it cut off at 6.8volts?
xxmad is offline   Reply With Quote
Old 04-24-2014, 07:01 PM   #12557
jw_rooster's Avatar
Anybody running the Hirosaka pro motors? I have a couple on the way to try with my Reventon Pro 1.1
jw_rooster is offline   Reply With Quote
Old 04-24-2014, 09:22 PM   #12558
I've upgraded the firmware and reset everything. Adjusting all the other settings appear to work. But still won't voltage cutoff and my lipo got taken down to 5.8volts again.
I have been out of the rc scene for 15years and upgraded to brushless pretty much because esc has lipo protection. So quite dissapointed.
Any Advice out there?
Old 04-25-2014, 01:08 PM   #12559
Tech Legend
Cain's Avatar
Trader Rating: 230 (100%+)
i usually do a hard cutoff under custom options. I dont' trust auto detect.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 04-29-2014, 08:53 AM   #12560
I bought a ESC Reventon Pro EX 1.1 1 Cell and they refuse to work with 1 cell. Indkator just flashes and then silence. If you connect 2 cell all works.
What do I do?
jeper is offline   Reply With Quote
Old 04-29-2014, 08:54 AM   #12561
I bought a ESC Reventon Pro EX 1.1 1 Cell and they refuse to work with 1 cell. Indikator just flashes and then silence. If you connect 2 cell all works.
What do I do?
Old 04-29-2014, 10:02 AM   #12562
Tech Legend
Cain's Avatar
try setting your voltage cutoff to what 1S would use.
It may be that to do setting changes you need to hook up a 2S lipo like we did back in the day with GT2.0s.
Old 04-30-2014, 08:29 PM   #12563
Airlmeier4422's Avatar
So I got a few issues. Just bought a Speed Passion Revention Pro 1.1 with a Speed Passion v3.0 6.5 motor. Basically this kit right here; http://http://www.ebay.com/itm/Speed...item27dc8584b5
ISSUE 1
After running a few weekends with this combo, I noticed today when I pulled off the track a light blinking on the esc. I believe it is the light on the right next to the receiver plug in. I turned on every time I ran for any amount of time.
ISSUE 2
The motor will not run cool. I have this motor in a desc210 and I have the gear set at 86/20 which is the correct gearing for that motor. Well I ran for 1 minute and the temperature would rise to 150. I changed the gearing to 86/18 and the motor still heated to 150.
ISSUE 3
During a race, the car will "stall" or act like it is off then quickly come back to life. I noticed it happens whenever power is applied.
Sorry for the book. I just purchased this combo 2 weeks ago and I am having issues already and I am getting nervous. Any help will be appreciated.
Andrew
Airlmeier4422 is offline   Reply With Quote
Old 04-30-2014, 11:05 PM   #12564
Trader Rating: 23 (100%+)
Sounds like you've got the LVC set quite high. Either set to 2.8v/cell or switch if off completely.
You need to post your esc settings as it sounds like your driving that motor too hard. Do you have a fan blowing onto the motor?
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-01-2014, 06:02 AM   #12565
I also noticed the motor has become louder. Sounds like a bearing squeaking. Also I do have a fan on the esc and I run a mid motor setup.
Here are my settings
1. Running mode - Std Forward with Brake
2. Lipo Cutoff - 3.2v/per cell
3. Timing - 0
4 Response System - Level 5
5 Braking - 40%
6. Drag - 0%
7. Neutral - 6%
8. Over Heating - Enable @ 95
Old 05-10-2014, 08:44 AM   #12566
Trader Rating: 37 (100%+)
I don't think 150deg is too high. I've seen plenty of on and offroad motors work fine at that temp....my own included.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-10-2014, 07:01 PM   #12567
ISSUE 1
ISSUE 2
ISSUE 3
Andrew
Try gearing it up. With a 7.5 i run 26/86.
capt waffles
sobiski racer is offline   Reply With Quote
Old 05-11-2014, 07:49 AM   #12568
Tech Legend
Cain's Avatar
anyone here try running a 21.5 SP motor in 1/10 2wd buggy? reason I ask is that for my daughter I am thinking of equipping her vehicle with one of these motors to start out with, but not sure for gearing, timing etc. to use. I have it laying around from USGT with a yellow timing board. Vehicle will be a dex 210.
Old 05-12-2014, 12:52 PM   #12569
Trader Rating: 14 (100%+)
I am having problem setup hybrid boost on my PC, I don't have any motor turns option under the hybrid boost page, I can't input any number of turns in the "Motor Turns" column. I can change or update the firmware but not hybrid boost option, am I missing something or did something wrong? any idea?
clfile is offline   Reply With Quote
Old 05-13-2014, 11:24 AM   #12570
In case you missed it on our Facebook page...
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
