The Speed Passion Thread
Thanks for the answers guys.
http://www.speedpassion.net/uploadfi...ov28th2013.pdf
Step 11 explains programming by looking at the LEDs blinking.
The easiest way is to use a programming card. If you don't own one download the instructions...
Im new to this but curious I need a combo.I am looking at the sp stock club 10.5, castle sw sct, viper vx4, or th old stanby hw and tacon. Just need some honest opinions. This will be going on a sc10 2wd.
Just so you know, the SP stock club race does not have reverse. I don't know about the others.
I have a Reventon-R with a SP 10.5R MMM motor.
The motor has the red plus-10 sensor board, the esc is set at 18.75 timing.
Is this a safe setup?
It's a 2 cell lipo, 1/10 off road dirt course.
Ok ... got sto1 v21 loaded this morning. Im getting "like" low voltage cut out after 4-5mins of use.. i have even disabled 3.4v low volt cut..no difference.. disabled over heat .... no difference.. my battery volt is 7.4volt (peak over 8.1v) and system voltage runs around 5.8v-6.2v .. im unsure what the issue is.. i run 5300mah 50-100c burst.. any idea guys...
Just a thought... im not running a capacitor that i got with the combo..should i? im not getting any interferance
Ray
Ray
- Jose
Hello,
I burned my Reventon R ESC wich is 3 month old. Maybe it was to much timing on the 13.5t v3-mmm motor? After 6 minutes running the motor stopped and it came smoke out of my Xray T4 :/ I run this combo on 2s 6000mAh turnigy lipo. The motor is «stocky» too now (it is difficult to turn the shaft). Anyway, I need help to find out of this and to get the right part to fix the problem.
Can You tell me what kind part it is on the ESC wich is shown in the pictures, and where can I get one, to solder it by myself..?
Thanks!
Thanks!
That looks like a jumper to me but someone else will chime in. You would probably do better to get a new one rather than fuss with the repair.
Send the same message to SP-service-center. Will se if they can help...
Will any of the reventon run a brushed motor?
Hello,
If you search for a data sheet using any numbers on the chip you may find the exact part number and be able to replace it. I doubt SP will tell you, Novak were no help in my case. They just point you to warranty support.
