Like Tree34Likes
Old 03-29-2014, 07:19 PM   #12511
prosport's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Shane Parker View Post
Hey, I have a question about adjusting the timing in Speed Passion motors mainly the 21.5 Competition V3. I know to change timing you must buy a different sensor. If I bought the +20˚ green sensor would it be 20˚ moved to the right all the way or is the sensor itself +20˚?
Shane
I have the same question about the 10.5R motor, is the timing adjustable at all? Or do I have to buy a new sensor board? And who sells the sensor board?
prosport is offline   Reply With Quote
Old 03-30-2014, 09:03 AM   #12512
Hello to all,
can someone help me?
Someone has parameters for ESC speedpassion GRANTURISMO PRO 2 for fast tracks? 119 FIRMWARE MOD.
Thks in advance
Pigio
Pigiolino is offline   Reply With Quote
Old 03-31-2014, 08:17 PM   #12513
Hopefully someone can help me out here.
I purchased a Reventon Pro esc and MMM motor. I got it all wired up and everything worked just fine. I Hooked the esc up to a friends Lap top to change to firmware to Stock0 for a race I have coming up and now I lost all throttle and I cant even get the ESC to hook up to the computer? It just says connecting pc. I updated the firmware on the LCD card and no luck. I did not hook it to the computer with the battery plugged in ether. Any ideas?
NickGroves is offline   Reply With Quote
Old 04-01-2014, 01:43 AM   #12514
I need help understanding the slope rate in stock 1 hybrid boost.
S.TRIPP77 is offline   Reply With Quote
Old 04-01-2014, 03:15 AM   #12515
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Exclamation
Had the same problem myself recently after updating the firmware. I played with changing the programming on it to just about every type/adjustment and the recalibrated the throttle positions and eventually got it to start working again. Not sure how exactly but after tinkering with it for awhile it just started working and has been fine since.
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 04-01-2014, 06:04 AM   #12516
I forgot to add that I cant get into recalibration mode. If I hold the on button to try and get into recalibration mode it just turns back off. Haha. Maybe I will give speed passion a call today and see what they say.
Old 04-01-2014, 06:52 AM   #12517
prosport's Avatar
I have a SP 10.5R motor that runs perfect for about 45 seconds then it cogs and sputters and shuts off. I've tried it in two different 1/10 buggies with the same result, both have SP ReventonR esc's.
I'm in Akron Ohio, where can I send this motor to get checked or rebuilt?
Edit: Nevermind, I'm not gonna send it out.
Old 04-01-2014, 11:24 PM   #12518
RC GB's Avatar
Default Speed Passion LCD
Anyone have Speed Passion LCD program box # specpbo1 for sale?
Gary Bennett
NW Oldest Racer
RC GB is offline   Reply With Quote
Old 04-02-2014, 05:22 AM   #12519
prosport's Avatar
Does Speed Passion sell different labels for the slide-out list on the LED program box?
I'm running Mod-0 on the Reventon-R, would like to have the correct label in there.
Old 04-04-2014, 05:15 AM   #12520
Hi Guys. Help please.. i have brought a sp reventon pro combo.. i just cant get it loaded on my computor to reconise the lcd card to update firm wear etc.. let alone the esc.. im running windows 7.. it said missing driver?
black blood is offline   Reply With Quote
Old 04-04-2014, 03:18 PM   #12521
Got it sorted guys.. cheers
Old 04-05-2014, 11:43 AM   #12522
prosport's Avatar
Seems like it's really hard to get answers in this thread. Maybe my questions are just really dumb? I have come up with some answers through searching the thread but some I have not.
Old 04-05-2014, 02:17 PM   #12523
Pittster's Avatar
Timing is a adjustablevia the endbell timing v3.0 motors have a 0-10deg adjustment MMM have 10-20deg boards.
I don't know but I kind of doubt it but just Email SP about it.
Drivers should install with software install, remove it and reinstall as Administrator (right click on the .exe) then follow the firmware update procedure and it will work.
I have done 4 SP Reventons and had no issues so far.
It can get a little quite in here.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 04-05-2014, 11:00 PM   #12524
Ok ... got sto1 v21 loaded this morning. Im getting "like" low voltage cut out after 4-5mins of use.. i have even disabled 3.4v low volt cut..no difference.. disabled over heat .... no difference.. my battery volt is 7.4volt (peak over 8.1v) and system voltage runs around 5.8v-6.2v .. im unsure what the issue is.. i run 5300mah 50-100c burst.. any idea guys...
Just a thought... im not running a capacitor that i got with the combo..should i? im not getting any interferance
Ray
Old 04-06-2014, 10:11 AM   #12525
Trader Rating: 37 (100%+)
Sorry the labels are not really sold.
Ray
Ray always run a cap on the ESC.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
