Old 03-21-2014, 06:55 AM   #12496
Aza088's Avatar
Hi All Speed Passion Guru's. I have a revention 1.1 pro 2 cell ESC and the website says it can run 1 cell as well. Has anyone run 1 cell lets say a 1/12 scale before and is there anything i would have to do like run the RX of a booster battery etc or is this built in like other ESC that run 1 cell.
Thanks guys.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 03-21-2014, 07:30 AM   #12497
Thanks guys.
The REVENTON PRO 1.1 EX is the only one that will run 1s without booster or receiver pack. All others will need it. I'm currently trying the EX NOW. Will race it in a few weeks at a club race and post feedback. I have it in a WGT 1S with speed passion 13.5 motor.
astgerma52sp is offline   Reply With Quote
Old 03-21-2014, 05:48 PM   #12498
Aza088's Avatar
Nice thanks for the reply. We have been running blinky 10.5 in 1/12 here and my old speed passion is down on power. The orca speedie is much quicker so I hope this speedie will work and kick some butt
www.bluerc.net
www.hootrc.com.au
Old 03-21-2014, 08:18 PM   #12499
darnold's Avatar
Thanks guys.
Yes. I've tested and run 12th mod with it. Both an Rx 2s lipo pack, and a TQ Booster will work. The unusual thing that you must do with the Rx pack is to simply plug it directly into the power slot of your Receiver WITHOUT cutting/removing any of the wires on either the speedo or the Rx pack. Simply plug it in (of course this is assuming that your Receiver can handle 7.4v!!!!!!), and turn the unit on and off using the Rx pack switch.
For the Booster you have to connect it to the positive/negative battery terminals on the esc and then plug it into your receiver. Just like the above notation concerning the use of an Rx pack, do NOT cut any of the wires to either the esc or the booster. Simply plug the booster into the power slot of your receiver. Then, just like you would do for an Rx pack, turn the esc on using the booster switch.
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 03-23-2014, 11:02 AM   #12500
asking again, will the reventon pro 1.1ex perform egual with the regular 1.1 in touringcars with 2s? looking for a new esc, and want a black one
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-23-2014, 03:02 PM   #12501
Trader Rating: 1068 (100%+)
BTW LRP X20 motors have the same issue as Viper motors with having to remove the temp sensor wire from the sensor harness.
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 03-23-2014, 08:51 PM   #12502
hey guys i just bought the reventon r and i need help connecting it to the reciver...i did all the steps but it wont connect....the problem is that i do all the steps and turn off the esc and turn in back on it goes full throttle and i can control it....i check all the trims and are okai...so i thought it was the trim and i move the trim to reverse in 12% and it immediately stop but it wont let me go reverse or go foward..so i thought it was my control and reciver and i put another one but i did the same thing
please some one help mee
Playgnx95 is offline   Reply With Quote
Old 03-24-2014, 03:05 AM   #12503
daveaustin5's Avatar
It might sound stupid but: is the servo reversing for your throttle channel (ch2) on your transmitter setup right? Try flicking it the other way and re-calibrating the ESC.
daveaustin5 is offline   Reply With Quote
Old 03-24-2014, 06:13 AM   #12504
it seems like you need to calibrate your ESC?
Old 03-24-2014, 01:21 PM   #12505
Trader Rating: 36 (100%+)
Its works great in TC. Plenty of customers running the EX or the same reason.... Black color.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-24-2014, 02:36 PM   #12506
ok, thanks!
Old 03-25-2014, 06:31 PM   #12507
Hello Guys,
I have just purchased a Reventon Pro ESC + v3.0 4.5r Motor combo for my touring car.
I have run hobby wing in the past and thought i would give this ago for the $.
Are there any issues that i should be aware of before i install this combo.
I have read a few threads and people have had various issues. Im hoping to have none
Im a speed passion virgin so ... be easy on me
Ray
black blood is offline   Reply With Quote
Old 03-27-2014, 02:22 PM   #12508
prosport's Avatar
Trader Rating: 21 (100%+)
My son and I both ran our 1/10 scale buggies last night with the SP Reventon-R and 10.5R combo's and we LOVED them, lots of speed, cool motor/esc temps, no problems.
prosport is offline   Reply With Quote
Old 03-27-2014, 05:22 PM   #12509
Trader Rating: 31 (100%+)
Hi All,
Has anyone experienced an instance with their Reventon Pro 1.1 where the esc shuts off and when you try to power it back on it lights up when you press the button, but doesnít stay on? It happened to me and I unplugged the battery and plugged it back in, tried a different battery and it kept doing that. I plugged it into the PC to reflash it and it was showing 1.5V as the input. I reflashed it and, on the bench, it seems fine now. Iím planning on sending it back, but just curious if anyone else has seen this before? Could the caps be going bad?
Thanks,
Jose
ittjv is offline   Reply With Quote
Old 03-28-2014, 09:41 AM   #12510
Shane Parker's Avatar
Hey, I have a question about adjusting the timing in Speed Passion motors mainly the 21.5 Competition V3. I know to change timing you must buy a different sensor. If I bought the +20˚ green sensor would it be 20˚ moved to the right all the way or is the sensor itself +20˚?
Shane
Shane Parker is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
