Like Tree8Likes
Old 02-10-2014, 10:26 AM   #12421
Hi i have a problem with my rev pro 1.1, it jerk when i throttle..it happen at low and high rpm..the red led will blink once (not continuous)when the jerk happen.
gnonz is offline   Reply With Quote
Old 02-10-2014, 10:31 AM   #12422
rc car guy's Avatar
is the sensor wire plugged it and did you try a new sensor wire, is it wired correctly? a to a b to b and c to c is the receiver slot good and is the cable ok that goes to the receiver
rc car guy is offline   Reply With Quote
Old 02-10-2014, 05:41 PM   #12423
Mopar's Avatar
For 17.5 Blinky sedan, what combo of can, rotor and sensor (max timing setting) would you recommend?
Mopar is offline   Reply With Quote
Old 02-10-2014, 05:45 PM   #12424
rc car guy's Avatar
Orca 17.5 with the stock rotor a ht rotor I run the revention Speedo its a bullet I heard a few motors are good as well such as the reedy mach 2 and the thunder power z3r as for he rotor and can timing its really a matter of track size and traction I believe
Old 02-10-2014, 07:16 PM   #12425
[YOUTUBE]http://m.youtube.com/watch?v=pHhDm-A-agk[/YOUTUBE]
I resoldered,change sensor wire,all wires are correct and its brand new..
Old 02-10-2014, 07:22 PM   #12426
rc car guy's Avatar
check you pinion is not hitting on any motor screws, my was and made a similar sound, if that checks out take the motor apart KEEP IN MIND THE SHIM PLACEMENT DO NOT LOSE ONE and check the bearings and see if anything is in there,
Old 02-10-2014, 07:34 PM   #12427
Don't mind with the screeching sound, the wheels are hitting my box underneath...and this rev 1.1 is brand new out from the box..what baffle me is that there is a surge of volt that trigger that jerk or cog..if you saw that video you will notice the red led blink when it reach its point
Old 02-10-2014, 07:37 PM   #12428
rc car guy's Avatar
have you tried different electronic combinations?
Old 02-12-2014, 01:30 PM   #12429
chad_h's Avatar
Trader Rating: 22 (100%+)
Repost
chad_h is offline   Reply With Quote
Old 02-12-2014, 01:30 PM   #12430
chad_h's Avatar
Why does my led program box have an unidentified setting? After #6 drag brake with 9 values, #7 is neutral range according to the manual. However It has 9 values also and it's only supposed to have 6. #8 has 6 for the neutral range
I need to update it but can't because no wifi or laptop. I really think this should work out of the box without update.
I'm referring to page 13 in reventon R manual for info.
Esc is SP REVENTON R
Update: the manual has 2 different list of values. I found the correct one on on page 3 or 4 instead of page 13.
Old 02-12-2014, 05:59 PM   #12431
Mopar's Avatar
As this is a SpeedPassion thread, my question was SP specific.
Old 02-12-2014, 09:20 PM   #12432
Any SP representative attending the upcoming TITC event?
Eazy is offline   Reply With Quote
Old 02-12-2014, 09:43 PM   #12433
Anybody with Trackstar 5.5T with Reventon PRO1.1
Need to change mechanical timing to work better with this ESC (How much)?
regards
TyoBBS is offline   Reply With Quote
Old 02-13-2014, 09:46 AM   #12434
Trader Rating: 23 (100%+)
Thumbs up
Good call! I'll be there with a brand new Reventon Pro 1.1 running in open brushless and so keen to know if there will be any factory support there!
Anyone got a good 13.5t open esc setup that'll be a good starter for ten for a TC?
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-13-2014, 07:35 PM   #12435
Wor, never seen this case before..... Just called SP they say you can just solder the wire directly. But be careful do not short any of the wires.
Originally Posted by TyoBBS View Post
OK, thank you i will test it.
Anybody with the same problem?
regards
rchobbymart is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
