Like Tree12Likes
Old 01-14-2014, 08:40 PM   #12361
Trader Rating: 20 (100%+)
Originally Posted by ECM Racing View Post
the former ex-wife
Did she die or did you re-marry her?
Sorry to hear about either.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 01-15-2014, 10:06 AM   #12362
Questions?? Fut HRS
Troy it sounds like you know a little bit about me. LOL No she's still alive and kicking. Only thing that died in that relationship was my R/C hobby.
Anyways, I got a question; can you run Futabas HRS mode with Speed Passions BL ESCs or do I need to enable PPM?
Overpowered is offline   Reply With Quote
Old 01-16-2014, 12:02 PM   #12363
daveaustin5's Avatar
I seem to be having issues programming my Reventon R.
I can't get the LED card to work.
When I plug it in it shows SP then after a second or so it shows two dashes (--).
It does the same if I try and plug it into my laptop.
Any ideas?
I've read to try with the fan disconnected but that didn't help.
daveaustin5 is offline   Reply With Quote
Old 01-16-2014, 01:14 PM   #12364
Can anyone point me in the direction to find out how to program my stock club esc without a card. I've been reading and searching the web without finding much. Right now everything works fine except that I seemingly have no brakes! Cheers!
Chris
Kacz is offline   Reply With Quote
Old 01-16-2014, 01:28 PM   #12365
Pittster's Avatar
Chris
Go to page 14 (step 11) of the Online manual
http://www.speedpassion.net/reventon/home.asp
There is a flow chart on how to program the Stock club ESC via the button.
By default that ESC has 20% drag brake and 30% braking power out of a possible 100%
Team Associated B6D, Speed Passion Reventon Pro 1.0, Tekin Gen2 8.5
Team Associated B64D, Speed Passion Reventon Pro 1.1, Tekin Gen2 7.5
Team Associated B5M CE, Tekin Rs Gen2, Orion 17.5
Pittster is offline   Reply With Quote
Old 01-16-2014, 02:07 PM   #12366
So at the bottom of the flow chart where it talks about "n" times. I'm guessing I count the orange flashes and cross reference those to the table provided later on page 16, 12.2
Old 01-16-2014, 03:04 PM   #12367
Pittster's Avatar
Noticed that the Reventon software is updated to Version: V1.1.0.24 with ROAR Approved V21 Stock0 Firmware.
Is there any difference/improvments between this version and V20 Stock0 ?? I
That is correct you would want 4 flashes to get to brakes and then set it to what ever strength you would like
Old 01-17-2014, 03:20 PM   #12368
Any ideas?
Any help would be much appreciated.
Old 01-19-2014, 09:27 PM   #12369
Pittster's Avatar
Has anyone had a sensor board fail in there SP motors??
I have new V3.0 17.5 with a red timing board that I had from a 1 year old MMM motor and has been fine for many race meets but yesterday mid way through my final race throttle became very touchy.
Brought it in and found anything less than 30% throttle it would cog like crazy (4wd team durango)
Replaced the sensor wire and it was the same, when I got home I put the 0-10 Black timing board back in and the cogging is gone.
What causes this issue anyone had it before??
Old 01-22-2014, 10:06 AM   #12370
silveraider14's Avatar
anyone have success running the reventon program on windows 8?
I get the usb driver to download but the setup doesn't work like how it did on windows 7
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 01-23-2014, 07:00 PM   #12371
Speedfreak391's Avatar
I have a reventon pro 1.1 and I have run it in my car 3-4 times at my local track. The last time that I had it at the track it worked perfectly.But 2 nights ago I was getting ready to go to the track and all I have is reverse, or if I change the running mode to forward/brake I get no movement at all. I am running a 8.5 V3 motor that came s a package with the speed control.
I have tried to reflash or resend the settings to the esc with both the lcd programmer and my PC. and no change. Any help would be appreciated.
Speedfreak391 is offline   Reply With Quote
Old 01-23-2014, 07:00 PM   #12372
Old 01-26-2014, 12:32 PM   #12373
Any ideas?
Any ideas?
I've tried contacting Speed Passion but haven't had a response.
I really need to be able to program my ESC and nothing seems to work.
The USB driver appears to be installed properly because I can see the card when I go to device manager on my laptop.
If I open the PC interface and plug it in whilst holding Reset I can update the software to v1.3 or v1.4 but neither seem to solve my problem.
I'm just stuck with two dashes! I can't program from PC or the card.
I've googled but couldn't find anything useful. The first result is my post on here!
Old 01-26-2014, 03:57 PM   #12374
is there any other place i can download the software from. downloading from sp website is like pulling teeth
rescue119 is offline   Reply With Quote
Old 01-27-2014, 12:40 AM   #12375
Hi guys and girls. I have a Reventon Pro that's done about three meetings in 1/10 TC (13.5T, stock 1 setting) Today I changed some settings and put the boost to 150k as per some guys setup sheets. I went to full throttle and it cut out. Now when you push the button to turn it on, it comes on, but as soon as you release the button it turns off. It didn't over heat or do anything silly neither did the motor. It will still connect to the computer so I reset everything back to default then reset it all again but the same thing happens, push the button down and it fires up, release the button and it turns off. Any Ideas ???
chrisware1 is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
