Like Tree3Likes
Old 12-29-2013, 12:36 PM   #12316
Trader Rating: 16 (100%+)
Originally Posted by Solara View Post
Your throttle channel need to set to reverse or normal (depends on your radio's default position)...1 of the position will get the motor turning.
Solara,
I just mounted in my new Speed Passion 1.1 Reventon Pro. Just did the software update to 1.1.0.24. I have no throttle now......I have to push the spur gear to get the motor to turn or rotate, once it turns it seems to work ok, but soon as I stop the rotation the motor will not go again.....unless I assist with moving the spur gear. Switched out about 5 sensor cables, still same thing. Switched out about 4 motors 2 of them which are new motors still same thing. Re loaded software still same thing, switched servo to reverse and then back to normal still no movement on motor. I'm stumped.... could not race today!
XRAY / KO PROPO / TEAM ORION / PRO-LINE / PRO-SPEC / P1 BRAND / PROTOFORM
I'm not a Business man, but I'm the Bizzness man!!!
Sean Williams is offline   Reply With Quote
Old 12-29-2013, 12:38 PM   #12317
Trader Rating: 36 (100%+)
Did you also recalibrate your radio to the ESC?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 12-29-2013, 12:41 PM   #12318
Yes of course...... that is routine after a firmware change or update.
Old 12-29-2013, 01:17 PM   #12319
megadep's Avatar
Default does it works with an hobbywing v10
Hi all, nice to meet you,
anyone could tell me if the new reventon pro 1.1 and also the EX version can both be mixed with the new hobbywing V10 motor, especialy the 4,5 turns. I am runing an XRAY X10 pan car wgt equiped all hobbywing v3.1 and V10 in 1S but I m also planing a 2S version with shory and the reventon could fit perfectly under the shock, the hobbywing can't be placed under the shock with the fan. I m running since last year a T4 with reventon pro and sp V3 6,5T, no problem at all, maby a litlle hot, but I m starting to be afraid cause of some bads comments concerning reventon ESC. Thx for answer
megadep is offline   Reply With Quote
Old 12-29-2013, 04:09 PM   #12320
i have seen people running hot motors with reventon 1.1 and fleta 4 escs without any problems, the problem seems to be with reventon pro
mine worked perfectly with 8.5 boost and 17.5 blinky, but with a 4.5 it was crap within 5 minutes. talked to a friend who bought a reventon pro same time as me, his went up in smoke after 2min with a 8.5t motor
and my new reventon s was a doa..
the 1,1 is probably a better esc than the first version, but with my latest experience im not gambling with my money again
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 12-29-2013, 04:21 PM   #12321
darnold's Avatar
Where you using the stock 1 "Hybrid Boost" software? If so, it appears that we are finding, at least in 12th mod on-road racing, that you may need to retard the timing on your motors a LOT. Testing is showing that on both a Revtech and on a D3.5 based modified motor (both 3.5 turn) in 1s applications the endbell timing had to be retarded nearly all the way to the left of the endbell. Once this was done the esc dropped by over 20 degrees in operating temperature while significantly increasing power and response output. Motor temps were unaffected. I can not directly speak for 2s applications, nor can I speak towards the standard Mod 1 software as this software doesn't provide enough boost options for 1s application, so I don't use or test with it.
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 12-29-2013, 04:31 PM   #12322
ran hybrid boost on 8.5, really nice feeling, i really like the brake in the reventon.
with the 4.5t i ran in blinky mode, drrs on 1, geared the same as the other drivers who could drive for 7minutes without any heat problems. motor had little or no timing on endbell.
after aprox. 4min my car just stopped. the esc was 95 degrees celsius, on the outside! (yes, i was using a fan on it )
Old 12-29-2013, 06:00 PM   #12323
cwoods34's Avatar
I ran 4.5t with blinky software today and had no heat issues at all. I run with the heat protection off, DRRS at one or two, and lots of handbraking. Did you actually temp it or are you just basing that off the heat-protection number?
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-29-2013, 06:31 PM   #12324
darnold's Avatar
I don't go by the outside temp. The best way to read the esc temp is to check it with the box immediately after pulling it from the track. If I'm not mistaken, I think that the program box actually reads the esc's internal temp. For the Reventon Pro the critical (internal) temp is 205 F. If you were to activate the thermal protection the instructions say that it will kick in if the esc senses 205+ F for a sustained period of 5 seconds. If the outside heat sink was at 95c that should be around 203 F if I'm remembering my Celsius conversion correctly (this may be off as it's been a while, lol). With an outside temp of 203 F it doesn't sound like you were anywhere near the internal thermal temp of 205 F (if that's what the box is actually reading) so my guess is that something else went wrong. Send it in for repair. Even if you've had it for longer than the warranty it would still be worth getting it fixed.
Old 12-29-2013, 06:36 PM   #12325
darnold's Avatar
Double post.
Old 12-30-2013, 01:26 AM   #12326
well temp cutoff was disabled, it would turn off early even in 17.5 boost with it on.
the outside temp was 95 degrees, inside would be alot hotter as one cable was almost unsoldered from the esc
the esc sits on my workbench here so might be a good idea to send it in even if warranty is out. do i contact rcmart where i bought it or speedpassion direct? i have registered the esc on speedpassions homepage
Old 12-30-2013, 11:39 AM   #12327
darnold's Avatar
Usually the outside temp is higher because you are reading off of the heat sink which is holding all of the heat. 95 degrees Fahrenheit is nothing so it would not have been due to temperatures that were too high if that was your reading off of the heat sink. This would indicate that something else went wrong. Now 95 degrees Celsius is a different story as that temperature is close to the threshold, if you read it using the box. Either way I would send it in.
Old 12-30-2013, 12:25 PM   #12328
You can contact RCMart to see what their return policy is. They might accept it or tell you to contact your country's Speed Passion distributor if it's under warranty still.
Old 12-30-2013, 01:22 PM   #12329
32819toon's Avatar
I have for sale 2 Speed Passion LED Program Cards :-
FOR SALE - SPEED PASSION LED PROGRAM CARD
Any questions, just ask.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 12-30-2013, 01:27 PM   #12330
as i live in sweden all temps are in celsius, and it was mesaured with a temp gun
ill shoot them a email and see what they can do! no warranty left on it
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
