Old 12-02-2009, 01:10 AM   #1216
Magnet Top's Avatar
Originally Posted by Born2Run View Post
Skypilot,which one from the Fantasy world videos (outdoor) on Youtube is the 17.5 class?
this is 17.5
http://www.youtube.com/user/DRIVERIII#p/u/3/xGozCJpXGVg
Magnet Top is offline   Reply With Quote
Old 12-02-2009, 01:12 AM   #1217
Born2Run's Avatar
Thanks Magnet Top
Whatever
Born2Run is offline   Reply With Quote
Old 12-02-2009, 08:27 AM   #1218
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by FLAT OUT View Post
WOW thanks for that great help and advise... I tell you what I will buy a Novak esc as well as your so help full !!!!
I have answered your question...check the post # 1199 on page 80
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-02-2009, 08:31 AM   #1219
Solara's Avatar
Originally Posted by Hebiki View Post
any recommendations on a Speed Passion 17.5 on a high bite indoor asphalt track? straight is about 140-150ft. esc won't have any timing boost/type feature turned on.
I did a RCGT for about 100 feet long straight indoor carpet for 4.5 final...that is a DUO 2 17.5 with 10 degree timing but with SP V1.1 with no software advance... if yours is the old version SP 17.5, I would definitely use 4.0 and start going UP (like gear the pinion UP). However, it is all depends on what speedo that you are using...if things like TEKIN with TURBO...I have seen 17.5 using 5.7 final drive due to the crazy ass turbo thingy....
Old 12-02-2009, 09:04 AM   #1220
jeppesen's Avatar
I ran 4.5 FD this weekend with a 17.5 V3 with the timing on the motor as low as possible, i use a GM gen90 with boost, but if you gear it 3.9 it will give the same.
It was on a medium bite carpet track.
jeppesen is offline   Reply With Quote
Old 12-02-2009, 10:28 AM   #1221
skypilot's Avatar
Trader Rating: 14 (100%+)
sweet. you can always come down for the Ko Propo Grand Prix at West Coast RC Raceway on Dec. 12 and 13th. ill even cover your lunch both days
having knee surgery on the 11th, no can do. i'll buy lunch here and send you the bill
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 12-02-2009, 10:52 AM   #1222
Hebiki's Avatar
Trader Rating: 26 (100%+)
thanks for all the replies guys... time to blow up.. i mean try this motor on sunday.
ritchie... maybe fremont TCS
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-03-2009, 09:09 PM   #1223
greenstreak's Avatar
I have a Grandturismo GT 1.1 LPF.If I buy the software programmer can I download the newest software on it?What will the new software do to it?Does it have variable timming?I was thinking of buying a new esc but if I can upgrade my current one then that would be great.
greenstreak is offline   Reply With Quote
Old 12-03-2009, 09:45 PM   #1224
DaveG28's Avatar
Trader Rating: 54 (100%+)
Hi all,
looking to get a gt2.0 but not sure if I can get away with an LPF, or really need the pro. I'd be running 6.5V3 in 2wd off road and 4wd off road, and potentially 5.5v3 in 4wd off road too, which from the looks of it is right on the edge of what the lpf can do, what does everyone recommend?
DaveG28 is offline   Reply With Quote
Old 12-03-2009, 10:13 PM   #1225
Solara's Avatar
No...verion 1.1 speedo does not have the software/firmware update feature. So even if you do have the LCD software programmer, you won't be able to upload the software used for V2. onto the V1.1.
I don't know exactly what you meant by the variable timing...but the V1.1 already has 8 different timings for you to choose from, from 0* to 26.25*. GT2 speedo has the exact same options, except the hardware/software of the GT2 is alot more advance then the GT1 V1.1.
I strongly recommand to upgrade to the GT2, if you run motor like 10.5 and slower...get the LPF, anything faster, get the PRO version.
Originally Posted by DaveG28 View Post
Hi all,
I use my GT1 V1.1 speedo for my Schumacher CAT SX running 5.5 and 6.5 motor....it works just like the PRO. So I am sure the GT2 LPF will work the same, however, I use the LPF only because that was used for my on road and it is laying around for no use except for off road....if I am planning to get a new speedo dedicated for off road especially running hot motor like 6.5 or 5.5...I would definitely go for the PRO just to make sure I have the top of the line speedo running on my car...
Old 12-03-2009, 10:30 PM   #1226
Devilmanak's Avatar
Our local track is allowing 17.5 brushless as a replacement for stock motors in the SCT class. I just installed and ran a new 17.5 V3 in my Slash, and there is NO comparison to the stock Titan! It is a quick motor for sure.
TEAM TEKIN/Mugen Seiki Racing
Tony's Screws, M2C Racing
Anchorage House of Hobbies
Big Boy Toys Small Engine and Repair
Shear Madness Hair Salon
Devilmanak is offline   Reply With Quote
Old 12-04-2009, 07:30 AM   #1227
abailey21's Avatar
Trader Rating: 35 (100%+)
A 21.5 is faster than the "12T" Titan dude
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-04-2009, 08:04 AM   #1228
jammincrtjames's Avatar
What is the timing in degrees for the new 3.0 13.5 motor?
Is there timing built in? What are the degrees of timing on the end bell?
Im looking buying one.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 12-04-2009, 08:11 AM   #1229
HarryN's Avatar
Send a message via AIM to HarryN
Congrats Speed Passion!
http://www.redrc.net/2009/12/speed-p...north-america/
Josh Cyrul is now a sales rep over at Speed Passion USA!
Now, down to the nitty-gritty. When are the version 3.0 motors coming out?
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 12-04-2009, 09:12 AM   #1230
abailey21's Avatar
They're been out
K.C.C.O.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
SEO by vBSEO 3.5.0
