Like Tree12Likes
Old 12-10-2013, 07:10 AM   #12241
Pittsdriver's Avatar
I love how there are only questions asked in this thread, and nobody answers...
Pittsdriver is offline   Reply With Quote
Old 12-10-2013, 07:26 AM   #12242
Have anyone any experience with updating Revnton Pro to Much More softwear? It is then all the same as MM Fleta 4?
DomenL is offline   Reply With Quote
Old 12-10-2013, 07:46 AM   #12243
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Stusdal View Post
I tried to Upgrade the software on a Reventon Pro and it failed halv way through. Now the esc won't Connect to the computer or work in the car.
Is there anyting I can do to bring it back or is it finnished?
Open the Reventon interface on your computer, connect with your ESC and LCD card, when the interface started, hit "S" that will go to the safe mode....then if the computer asked to connect to ESC, hit "NO"....then it should get to the back door of the ESC connection and on the left you should be able to load the software that you want...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 12-10-2013, 07:47 AM   #12244
Solara's Avatar
Originally Posted by jaank View Post
Any ideas how to work out the warranty on a motor from rcmart?
Random blowout after 3x10 of practice.
Contact RCMART first....
Old 12-10-2013, 08:14 AM   #12245
Solara's Avatar
Originally Posted by iesys View Post
I have been reading this thread and have not been able to find a good explaination of the settings on a Reventon R ESC.
I race 21.5t boosted on a track that has a 60mtr (180ft) straight.
I don't seem to be able to find a setup that works on this esc.
I have in the past used hobbywing 2.1 and I cannot relate the speed passions esc settings to that of the hobbywing.
Can someone point in the direction of a thread or something that explains clearly what the hybrib boost 150k relates to and the % hybrid boost relates to. It is a percentage of what? And the DDRS is that the same as the boost per X amount of rpm?
On a hobbywing you add an amount of boost, an amount of turbo and choose when and how quickly it is introduced. The speed passions doesnt seem to work this way.
It is because we are not HobbyWing....
Can you list your 21.5 setup here first and tell me what is lacking or missing on your setup...? One thing I have to point out is...Reventon R is a 70A ESC, comparing that to 120A or higher ESC for the same amount of performance is just not right.
Also your gearing, and your motor timing setting...(physical timing on your motor).
Hybrid Boost Active = the dynamic ramp timing adding thru out the whole throttle range.....we are not using Timing in degrees because they are not accurate and never was accurate. So we are using % instead of show the amount of timing in 10% increment....if it must be using in degrees, use 30* max and divided by 10 for each 10% increment...
Hybrid Boost Maximum = Turbo/boost. k = 1000...and it is refer to the RPM. The higher it is, the more timing adding after the WOT.
Old 12-10-2013, 08:15 AM   #12246
Solara's Avatar
Originally Posted by Gayosaka View Post
Hi, is the Reventon Pro able to run a motor in reverse direction (CW) with sensored control and boost?
No...sorry.
Old 12-10-2013, 08:16 AM   #12247
Solara's Avatar
Some of them use it...I don't. I don't see the different and I worry about after updating the MM interface to the LCD card it won't allow you to go back to the SP version.
Old 12-10-2013, 08:22 AM   #12248
Solara's Avatar
Originally Posted by Pittsdriver View Post
Is there a list that explains what firmwares do what for the Reventon line of ESCs?
Drift.....DRIFT
Rock crawler.....CRAWL ROCK
Stock 0 = BLINKY (ROAR)
Stock 1 = BOOST/TURBO/Supercharger
Mod0 = mainly used for off road, has REVERSE function.
Mod1 = same as mod0 with higher top speed, without reverse function, mainly used for the organized race.
Mod2 = best used for off road racing event...has best punch and brake power. No reverse.
Old 12-10-2013, 08:37 AM   #12249
Originally Posted by Solara View Post
Drift.....DRIFT
Thank you very much.
Any thoughts on making a Mac version of the software?
Old 12-10-2013, 11:08 AM   #12250
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
I have a GT 2.0 ESC and am having trouble stopping the wheels fast enough when I hit the brakes.
What I'm looking to do is to stop the wheels fast enough to flick the car downwards in the air over a jump. Right now, I'm at maximum brake and the wheels slow down in 2-3 tenths of a second, but they don't stop cold like my Reventon or other brands of ESCs would do. Those brakes were so hard that you can dive the nose down in the air just by hitting the brakes. My GT 2.0 doesn't work that way - the brakes are way too soft.
I've tried all types of settings in the ESC and on my radio. Any thoughts? Does anyone else have this issue?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 12-10-2013, 11:14 AM   #12251
nrtv20's Avatar
Solara... Thanks for the thread support!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 12-10-2013, 11:25 AM   #12252
Yes thank you!
Old 12-10-2013, 12:57 PM   #12253
YoDog's Avatar
Trader Rating: 26 (100%+)
Are you running a lot of boost or are you running blinky?
I have found that when I run a lot of boost on certain motors, the initial hit of the brakes are quite weak. It's fine in the infield but very weak at the end of the straight. Perhaps a delay due to the hi boost settings? My Tekin used to do that too.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-10-2013, 01:41 PM   #12254
Gayosaka's Avatar
No...sorry.
Thanks, sir.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 12-10-2013, 01:43 PM   #12255
iesys's Avatar
Thank you for taking the time to answer.
I am using a hobbywing Extreme stock 60A esc and a hobbywing XERUN 21.5 (no end bell timing).
The last big event i ran the below settings to finish 5th in the A-Main.
using the extreme stock esc.
No end bell timing
boost 50 (0.6 * 50 = 30 degrees)
Turbo 14 (0.6 * 14 = 8 degrees)
Start rpm 3000, increasing every 300 rpm
Turbo delay 0.1
FDR 5.44
99 degrees F day, motor temp 180 degrees F (outer case) after 6mins
I would like to achieve something similar using the Reventon, I like the SP esc's, they are way smoother than the Hobbywing, but I am struggling to balance speed and heat with the SP reventon esc.
So if hybrid boost active is a % of 30 degrees, that make sense.
But if the rpm on a 21.5t boosted motor is 24-30K then how is the hybrid boost of 150K related?
3Racing
iesys is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
