The Speed Passion Thread
I have 2 program boxes,
a translucent Blue one:- Reventon SMART LCD Program card, version 2 .7
and a Black one:- LCD Professional Program card, version 1.07_110119.
The black box will not connect to any of the Reventon ESC's or connect to the PC software 1.1.022
Is the black LCD Professional program card compatible with the Reventon ESC's?
What is the latest version of the Black box and how do you update it?
Fred
Fred
Just had a second club race stock esc go on me, that's 2 in 4 months. This one was a waranty replacement, I think I'll go to a different speedie next time, I have the same stock programme on a reventon S and Havnt had any problems.
It's a sensor Issue in the speedie,has anyone had similar problems.
If all else fails, the Hobbywing Justock is a killer stock ESC too.
Yogi, what brand & model motor are you using with that esc? I recall some brands & models of motors had sensor issues with the Reventon esc's, and to get around it one of the sensor wires had to be cut, could be related to your problem.
I'm using a Reventon S (is basically the same, except for the software) in my F1 car and so far haven't any problems with it, but I've only used a Speed Passion and Hobbywing 21.5 motors with it.
As metalnut said, if all else fails then grab a Justock esc, very reliable little esc.
Cheers
Rob.
That depends on where he bought it from, if he bought from Hong Kong the reps here won't help him, if he bought it from the Australian SP distributor then he'll have to ship it back to them.
Cheers
Rob.
Cheers
Rob.
As for your other comment, I believe it is Viper motors that don't work right with the SP ESCs due to the temperature sensor that Viper uses.
Used two different motors. The 1st one went with a reedy21.5 This one was a tracstar 21.5
This one was the replacement from warranty on the 1st one so I Havnt lost out and I intend to send it back again. There was no feed back as to wat was wrong with the 1st one, they just sent a new one.
The reventon S I have has never missed a beat. I just liked the idea of an esc strictly for blinky
Likewise in regards to the Reventon S, mine has performed well in my F1 car.
I helped a guy last night to set his up as he bought the 21.5 combo (Reventon S, LED Box & 21.5 motor) set from Walter Hobbies and I was surprised to see that they are finally pre loaded with the blinky software, instead of mod software like mine was.
Cheers
Rob.
speed passion reventon pro
Hi, i am having this issue with my Speed passion pro & speed passion motor 10.5r, just bought and received it couple of days, really frustrated with it. when i applied low throttle input, it bogs and the motor will stuck making weird noise, i wish someone had this issue before and has a fixed for it. or else i have no choice but to contact the seller(ebay) and request for replacement.
youtube.com/watch?v=gbAh8Am5m1g link for video i made.
please help
please help
please help
please help
anyway,thanks for your reply at least i have rough idea where to look. will try to swap motor from my another setup to see if the problem persist.
does anyone have experience with the new reventon pro 1.1
thanks
thanks
Anyone know the part number for the capacitor for the reventon pro 1.1 I got mine caught in my spur gear (don't ask) and I can't find the part number anywhere.
I guess any cap is fine I just need to know one that works for sure.
Thanks in advance.
Thanks in advance.
Hi All,
I'm looking for advice, I'm just getting back to TC after a while. I have a Xray T2R pro that I just finished building recently and have been running a Revention S esc and a V3 21.5 motor with a FDR of 3.4-3.5 with temps below 50C.
This weekend I put in a new Revention Pro esc and a new MMM 21.5, I ran about a dozen laps and on my 2nd run on the third lap the motor smoked, the motor was not very hot to touch ...... I was running a heat sink and fans. Any ideas, the FDR at the time was around 3.3.
