The Speed Passion Thread
opps sorry man thought this was the speed passion thread..
double post..sorry
double post..sorry
Hi SpeedPassion Admin,
Is there any plan form SpeedPassion Team to update Reventon R drift profile firmware with boost or stock 1 profile with reverse. TQ.
hello, maybe someone here can help me with the reventon pro. i just picked up 2 of these used from rctech for sale threads. i've tried to hook both of them up with the same results.
the motor is a speed passion 13.5 from the durango rtr car, airtronics rec, savox 1258 servo, and venom battery. the stock cirtix speedo works fine with all of these but both reventons make a cogging sound and barley turn the motor while making a horrible noise and the motor gets hot real quick.
what's wrong with these speedos or am i doing something wrong?
all wires have been double checked and are hooked up correctly. the sensor wire works great with the cirtix speedo.
any help would be great.
Did you calibrate your TX to the ESC?
yes, i think got it programmed right. usually when i've seen anything like this in the past it's been the sensor wire. i've tried 2 different ones and they don't work with the reventons but work fine with the cirtix.
Hey guys,
I had a bad crash with my Xray T4 equipped with a reventon pro and a 10.5MMM motor.
Now the car is acting strange. When I apply a bit of throttle from standstill I have very bad stutters almost like the spur is broken (but it's not) and I'm pretty sure it's from the ESC because when i changed ESC it works fine.
Any idea what could be the issue? I really like speed passion! I changed firmwire btw from stock0 to mod0 and also sensor cable but still the same.
hello
question of what is a better esc the speed passion reventon pro 1.1 or the much more fléta
Hey all,
Just picked up a Reventon Pro 1.1 and am unable to calibrate to my radio. Holding the set button turns it on, but it will not go into set mode. Any ideas or did I get a dud?
Thanks,
Dave
Thanks,
Dave
Hey guys,
Hey guys,
I'm using a Futaba radio and have the throttle set to reverse as indicated in the instructions. I did try it with the throttle set to normal but that doesn't work either.
Dave
Dave
