Like Tree12Likes
Old 04-18-2009, 06:35 PM   #106
Default New GT2
Hey guys just got the new SP GT2 and 10.5, does any one know of a good start off point for timing and gearing on a med/fast outdoor ashfalt track. Considering the timing on the SP 10.5 is not adjustable, does that mean I should run more ESC timing. Thanks in advance.
warpspeed57 is offline   Reply With Quote
Old 04-18-2009, 10:02 PM   #107
ok guys i have the gt 2.0 lpf speed control and wanted to know whats the best bang for the buck settings for the speed control ddrs timing etc for tc with 21.5 running in the vta class and should i advance the motor timing also or leave it stock. fdr right now is at 5.0 and its a xray t2007
wickedjester is offline   Reply With Quote
Old 04-19-2009, 02:40 AM   #108
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Does the GT2.0 have the ability to change timing on the fly? If so can I adjust the diiference between lower RPM timing and high RPM timing?
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 04-19-2009, 07:30 AM   #109
Originally Posted by Shawn Palmer View Post
memix:
Since we're re-creating some info for the moment, here's how the interplay with timing advance and gearing works:
When you're setting up a new power system or stepping onto a new track with anything faster than a 10.5 motor, always start with the timing advance LOW. If you're too slow, start to gear up to whatever the track can handle or whatever you can handle. Remember that low lap times are what you're looking for, and that blazing speed down the straight that everyone likes may end up giving you SLOWER lap times in the long run
Once you've got the gearing in the right range, then you can experiment with some higher timing advance for a bit more straight speed and punch out of the corners, but remember - adding timing advance is very much like adding a tooth or two to the pinion - The car will be faster, and the motor will get hotter. Watch your temps while you're doing it and experiment with how you like the feel of a few teeth down on the pinion combined with a few settings up on the timing. Generally low timing and faster gearing will give you a smoother softer feel in the infield - generally good for tight technical tracks. Higher timing and slower gearing gives you a punchier hard hitting feel (which some prefer on any track).
For 10.5, 13.5, 17.5 and 21.5 motors:
Racing setups for these motors has generally evolved into "max out the timing advance, and adjust gearing to keep motor temps in check".
Your temp gun and lap time sheet are your best friend here. With the timing maxxed out, a very good driver can recognize the "breaking point" of the motor very quickly. This is the point when you are adding a tooth, seeing laptimes go down and the motor is not overheating yet, and you add another tooth and repeat. At some point when you add one more tooth, usually two or three things happen all at once: You notice you have lost a lot of rip out of tight corners (the motor is maxxed out on torque), your laptimes have gotten slower, and the motor is at or beyond it's safe max temp. This is the breaking point, and for Nationals level drivers - they go down one tooth and call it a day.
For club level, I would recommend going down 2 or 3 teeth to give you some extra security from blowing motors, and here's why:
Traction conditions can change during the day, and added traction = more motor heat. Ambient temps change during the day, and higher ambient temps = more motor heat. Even something like a slight drivetrain bind, or a wheel bearing starting to go bad will add friction to the drivetrain and thus add motor heat. If you are just barely one tooth under the breaking point, there are many many factors that might come into play that will shoot you right over the edge in an instant, and then you've smoked a motor.
Max temps:
21.5 = 140F
17.5 = 145F
13.5 = 165F
10.5 = 175F
Anything faster than 10.5 = 185F
Where on the motor do you check the temps?
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 04-19-2009, 08:33 AM   #110
dameetz's Avatar
Originally Posted by Marcos.J View Post
I had similar issues but with the 1.1 GT , I ended up running around a 10.25FDR in a large outdoor track with no problems, also try dropping your timing to #2 ( i think its 3.75 degrees)
Thank you very much for the tips Marcos J. I followed your advice using 10.275FDR and step down a click of my esc timing (I think its 11 deg something). Since that I did not get any cut off any more. I ended up TQ and won in the A main mod class.
As for the melting solder from my deans connector I swap it with bullet type 3.5mm size connector and it solved my problem.
BTW where can I get a higher melting temp solder lead?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-19-2009, 11:51 AM   #111
I would like to thank, once again, to Shaw Palmer , for his advices.
Finally, i make a good race, TQ and win final-A, in 10.5 stock class, i use the Speed Passion Supercapacitor, with Nosram ISTC, and Speed Passion 10.5R, with 5.45 FDR, in Small/medium track, with Lipos.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-19-2009, 02:23 PM   #112
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
The hot spot on my 13.5 is on the can right next to the end with the solder tabs, right on the "13.5T" engraving.
-rocky b
flatspunout is offline   Reply With Quote
Old 04-19-2009, 04:12 PM   #113
I normally look at the bottom of the screen on my radio LOL!
I use a temp sensor inside the motor and it works great.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-19-2009, 05:37 PM   #114
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
Im glad it worked out for you , Im glad I can help!
Old 04-19-2009, 06:15 PM   #115
skypilot's Avatar
Trader Rating: 14 (100%+)
Finally got to run the SP2.0 today, simply amazing, ultra smooth, great brakes, and delievers on heck of a punch when needed. ran it in my Mi3 with a 6.5 geared at 89/24 and ran with the 4.0's and 4.5's.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 04-19-2009, 07:56 PM   #116
dbmartin's Avatar
Happy to report that I ran my new 2.0 GT this weekend with no thermal issues. Ran both a 3.5 and 4.5. The speedo never got hot for me, The 3.5 temped at 178 degrees F which was a little hot, But I think if I work on the setting a little, I can bring this down.
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 04-20-2009, 09:48 AM   #117
Super Moderator
Marcos.J's Avatar
Hey Dave got mine installed today, see yah at the Region 4 race!
trim the timing down some with the 3.5 and the temps should go down a bit
Old 04-20-2009, 11:30 AM   #118
Goingfast's Avatar
Trader Rating: 29 (100%+)
So that 's the secret...No wondering your fast and smooth..good run richie..
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 04-20-2009, 12:31 PM   #119
killingtime's Avatar
I'm running the older SP esc, the ver 1.0. My question/problem is that I only get about 10% power off the line and then 1/2 sec. later full power. BTW, my radio is a Helios with Spektrum.
Thanks for any help you can provide
I remember seeing this discussed/resolved in the old thread but.....
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 04-21-2009, 12:01 AM   #120
smilekt's Avatar
nice nice .. do more report about GT 2.0 ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
