Old 08-19-2013, 01:10 AM   #11941
@wollow86 - well hope yours is just a case of replacing the sensor cable - SP provides a very short cable and in order to fit, we sometimes overstretch it and end up with a loose contact; or checking gear mesh (...this one produces a very loud and rough sound) or well, while your at it, check tightness of pinion grub screws - I did experience this loud and rough sound with one of my pinions (29T48P) before, i think the pitch doesn't match my spur's...replaced it with a better one.
V19 is available in my choices for update firmware at SP Interface. I do have Muchmore Fleta installed as well.
acuglass is offline   Reply With Quote
Old 08-19-2013, 02:24 AM   #11942
wollow86's Avatar
The problem is there without the motor installed in a car. I've tried just about every combination of motors, sensor wires and software I can. All the motors and sensor wires work fine with a different esc. Only possible thing left is a hardware fault with the esc sensor board.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 08-19-2013, 03:21 AM   #11943
@wollow86 - oh i get it, your motor is not installed yet. well, i have not experienced that yet.. but good luck on your search/isolation of possible cause(s) of the problem. Mine ended with using a different software version. If it didn't then definitely, i'll be looking for another potential cause... it would have been easier if SP would have simply wrote me an email on how to sort out the problem though...
Old 08-19-2013, 11:03 AM   #11944
JayL's Avatar
http://www.petitrc.com/reglages/spee...eSoftware/eng/
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 08-19-2013, 11:19 AM   #11945
Typeone's Avatar
Trader Rating: 30 (100%+)
So what would MuchMore software do for my Reventon Pro in stock0. I'm running a 17.5R MMM with 30 deg timing. Also what size rotor should I choose if I want a little bit more power. The guys at my track are running Tekin esc with RevTech motors.
Typeone is offline   Reply With Quote
Old 08-19-2013, 11:22 AM   #11946
Holmenkollen's Avatar
Angry
I got a brand new Reventon Pro today and throttle/brake does not work. I can do a radio setup and use the LCD box but it does not react on radio input. Steering works. I tried different software versions too. This is not fun. Brand new...
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 08-19-2013, 11:40 AM   #11947
Solara's Avatar
Trader Rating: 16 (100%+)
Try reverse your throttle on your radio and recalibrate...
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 08-19-2013, 01:07 PM   #11948
Tried it again and now it worked. Must be a glitch or something. Thanks! Using a KO radio.
Old 08-19-2013, 01:53 PM   #11949
Typeone's Avatar
Any help with my previous question???
Old 08-19-2013, 01:53 PM   #11950
Typeone's Avatar
Any help with my previous question I posted??
Old 08-19-2013, 03:01 PM   #11951
G-rem's Avatar
MuchMore software will make normally run your speedo cooler and the throttle curve will be a little bit smoother.
Don't change the size of your rotor, a bigger rotor will give you a little more torque but less speed...with the stock0 mode, that's not a good solution, you'll certainly have a lack of top speed in comparison to others.
Best Regards,
G-rem
G-rem is offline   Reply With Quote
Old 08-19-2013, 03:04 PM   #11952
Solara's Avatar
For 17.5...depends on the size of the track, I am using 34* timing (yellow board around middle position) and gear at 3.1 to 3.2 (that is on a large 1/8th size track...) outdoor. Rotor need to be a legal rotor.....12.3mm, stock one came with the motor is fine.
Old 08-19-2013, 07:15 PM   #11953
Trader Rating: 18 (100%+)
Originally Posted by SP CS View Post
PM us the phone # or call us at 888-928-1328 and we will walk you through.
SP CS
I'm going to PM you my number, please call at your earliest convenience. Problem is, I'm at the office from 6:30 am to 5:00 pm Pacific. A Main Hobbies sent me a replacement programming card, but I'm encountering the same problem. It really seems like the USB driver isn't installing properly. A Main says they will not accept the ESC for return, so if this doesn't work, looks like I'm out $90.
Sorcerer001 is offline   Reply With Quote
Old 08-21-2013, 08:28 AM   #11954
Trader Rating: 36 (100%+)
Not onroad, but it's SP :P
Speed Passion Thread
Nexus is offline   Reply With Quote
Old 08-21-2013, 12:35 PM   #11955
whats the difference between reventon s and reventon club spec?
both have the same specs?
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 10:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
