Like Tree12Likes
Old 07-12-2013, 12:23 PM   #11821
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by 32819toon View Post
I would however like to know if there is a profile / firmware which will allow me to put boost onto the S esc.
No boost software for REVENTON S....
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-12-2013, 12:34 PM   #11822
Holmenkollen's Avatar
Originally Posted by Solara View Post
Yes....contact the SP HK headquarter and they will be able to handle this warranty issue.
Ok! Can you help me with an email address?
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 07-12-2013, 01:06 PM   #11823
Solara's Avatar
you have PM
Old 07-12-2013, 02:10 PM   #11824
misfitz28's Avatar
Reventon S came with a LED programmer card that you can use to adjust the parameter of the ESC....why you want to do it manually? Also...LCD card will work too.
my package did not come with it. came with the black reventon s esc and the v3 17.5 motor. nothing else.
www.tinymoneypits.com l Misfitz Motorsports l Tamiya Racing l TA-05 V.2 l Hotshot RC
misfitz28 is offline   Reply With Quote
Old 07-12-2013, 07:39 PM   #11825
I have two brand new speed passion speed controllers and I cannot get the brakes to work on either of them manually. One is a stock club and other is reventon s.Any advice on how to adjust this please.
BIGDAN is offline   Reply With Quote
Old 07-13-2013, 03:02 AM   #11826
the catman's Avatar
Questions?? Reventon Pro
hi Guys I need a Reventon pro bottom case .I have emailed my local importer here in Australia ,nil stock,emailed speed passion USA they forwarded my email to HK Speed Passion as they were closer to my local but no reply,emailed USA again, forwarded to someone else ,again no reply all I want is a replace my bottom case for which i will PAY plus postage it seems to me that because I broke the flimsy bottom case I might have to buy a whole new ESC . Can someone out there from Speed Passion help? I need to fix this before the ESC departs my car and leaves the bottom case stuck to the double sided tape on the car.
Thank You
the catman is offline   Reply With Quote
Old 07-13-2013, 03:08 AM   #11827
bertottius's Avatar
Trader Rating: 18 (100%+)
Make sure you read the instructions very carefully on how to set it. I struggled to find the brakes myself only to learn that I wasn't programming it correctly.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 07-13-2013, 07:01 AM   #11828
SamuraiJack's Avatar
Trader Rating: 34 (100%+)
Did you ensure the firmware you have installed on the ESC supports braking? Click "Firmware Support list" here: http://www.speedpassion.net/reventon/home.asp
SamuraiJack is offline   Reply With Quote
Old 07-15-2013, 07:48 AM   #11829
For whats its worth I switched receivers (from Spektrum DR3300T to SR201) and this stopped happening. Now I think my wifi router keeps throwing it reverse. Poor furniture.
I wish you could tone down the reverse. Its TOO FAST and then you can't stop it (throttle) until it slows down some. Perhaps its the same gear protection feature that keeps you from throwing it in reverse while going forward? I can't just reduce the throw of reverse on my radio since that messes with braking.
Originally Posted by SamuraiJack View Post
Reventon Pro: has anyone else had the RED LED go off during operation? All I can find in the documentation is that under normal operation both the ORANGE and RED LED's should be on during operation. The RED LED was not blinking (indicating low battery) but just goes off. I also notice some apparent receiver interefence/randomness when it happens which may or may not be related.
Also, is it OK to wire two fans into the fan power outlet (Reventon Pro)?
Generally this ESC has been easy to setup and update via the USB cable.
Old 07-15-2013, 10:17 AM   #11830
artwork's Avatar
Trader Rating: 56 (100%+)
Does anyone know why the Reventon Pro 1.1 is almost $100 more than the Reventon Pro? Seems odd to make such a big price jump for essentially the same exact speed control with a couple of very minor changes.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 07-15-2013, 10:38 AM   #11831
Magnet Top's Avatar
The 1.1's got a bigger fan base, hence the bigger salary... ehem... I mean price tag ba dump bump....tsssss
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 07-15-2013, 10:47 AM   #11832
Xpress's Avatar
Where do you see a $100 difference? I see a $40 increase?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 07-15-2013, 02:10 PM   #11833
artwork's Avatar
Reventon Pro 1.1 Brushless ESC - Metal Black Silver
Part No.# SP000739
Restock Soon
MSRP : USD 220.00
Buy Direct Special : USD 220.00
extra 10% off
USD 198.00 Factory Direct Price
Prices Subject To Change Without Notice
Reventon Pro Brushless ESC - Laser BlueBuy Direct Special
USD 99.00
Summer Special
$198
-$99
$99
I guess was over exaggerating by saying it was $100 I meant $99...
Old 07-15-2013, 06:00 PM   #11834
bkspeedo's Avatar
Those new FETs are bloody expensive i guess.
It is odd that you can buy the current Reventon Pro 1.0 Blue in the US for $99 but on the world site it's $180.
My guess is when it's officially for sale in the US it will be lower with a slight price increase due to the new FET's there using.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 07-15-2013, 07:32 PM   #11835
robk's Avatar
Trader Rating: 22 (100%+)
Seems to me the $99 deal is a blow out special, which would be typical when you have a new model. The GT2.0 can be had for a similar price.
The Reventon was not $99 when it came out.
Speed Passion GT Competition Brushless ESC v2.0 Low Profile, LPF pink_sleeve Electric On-Road 13 07-08-2009 09:17 AM
Tags
gt2, lack of help, overpriced, poor customer service, reventon, reventon pro, speed passion
